Problem loading tiff file for bathymetry
I downloaded an area from the EMODnet website (https://portal.emodnet-bathymetry.eu/#) with bathymetry data in .tiff and uploaded it to Cesium ION without errors. But when importing the asset in the code the terrain does not appear and I have no error or warning, even though i can see the globe and other 3D objects I’m rendering.
Before that I tried this tutorial (https://bertt.wordpress.com/2018/11/26/visualizing-terrains-with-cesium-ii/), which converted the .tiff zone to TileJson however I can’t upload it (error: json is not a valid format) or access via a local server.
var viewer = new Cesium.Viewer('cesiumContainer',{
    terrainProvider : new Cesium.CesiumTerrainProvider({
        url: Cesium.IonResource.fromAssetId(85779)
I need to render bathymetry data. Is this the best way to do it ?
Cesium: 1.62
Ubuntu 16.04
Chromium 80.0.3987.87
You can also use Geoserver and then Cesium.WebMapServiceImageryProvider
I’m interested in this as well. Have you had much success?
