I have a question about placing two canvases on the screen. In HTML, I declared two containers, cesiumContainerTop and cesiumContainerBottom, to hold the two viewers. The top container takes up the top 50% of the screen and the bottom takes up the bottom 50% of the screen. After, I declared two viewers, viewerTop and viewerBottom, and set up a handler for each that will execute at MOUSE_MOVE.
A problem that I noticed is that when I am hovering over the top div, it tells me that I am hovering over both the top viewer and the bottom viewer. How is this possible if they're located in separate divs? And to make the problem worse, because I am 'hovering' over both viewers, it is executing both handlers (which I do not want).
Has anybody else noticed this? Is there a solution?
Lydia
