Problems with Compiling with Cmake error
The Cmake version is 3.26.3
Use the command
cmake - B build - S- DCMAKE_ BUILD_ TYPE=Debug
The error message is
CMake Error at C:/Program Files/CMake/share/cmake-3.26/Modules/FindPackageHandleStandardArgs. cmake: 230 (message):
Could NOT find Bash (missing: BASH_EXECUTABLE)
Call Stack (most recent call first):
C: /Program Files/CMake/share/cmake-3.26/Modules/FindPackageHandleStandardArgs. cmake: 600 (FPHSA-FAILURE-MESSAGE)
Extern/cesium native/extern/KTX Software/cmake/modules/FindBash. cmake: 96 (find_package_handle_standard_args)
Extern/cesium native/extern/KTX Software/CMakeLists. txt: 8 (find_package)
How to solve it?
It looks like your command has a lot of spaces, unless you mistyped it. The spacing should be
cmake -B build -S -DCMAKE_ BUILD_TYPE=Debug
But if that doesn’t make a difference, maybe try git submodule update --init --recursive to re-update the cesium-native dependencies.
Can you specify the location of Bash? Updating the cesium native dependencies is still the same error
implement cmake -B build -S . -DCMAKE_BUILD_TYPE=Debug all outputs
F:\Cesium001>cd cesium-unity-samples/Packages/com.cesium.unity/native~
F:\Cesium001\cesium-unity-samples\Packages\com.cesium.unity\native~>cmake -B build -S . -DCMAKE_BUILD_TYPE=Debug
-- Building for: Visual Studio 17 2022
-- The CXX compiler identification is MSVC 19.37.32822.0
-- The C compiler identification is MSVC 19.37.32822.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.37.32822/bin/Hostx64/x64/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.37.32822/bin/Hostx64/x64/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
CMake Warning (dev) at extern/tidy-html5/CMakeLists.txt:26 (project):
  Policy CMP0048 is not set: project() command manages VERSION variables.
  Run "cmake --help-policy CMP0048" for policy details.  Use the cmake_policy
  command to set the policy and suppress this warning.
  The following variable(s) would be set to empty:
    PROJECT_VERSION
    PROJECT_VERSION_MAJOR
    PROJECT_VERSION_MINOR
    PROJECT_VERSION_PATCH
This warning is for project developers.  Use -Wno-dev to suppress it.
-> TIDY_SO_VERSION = 59. This is an ODD (development) release.
CMake Warning (dev) at extern/tidy-html5/CMakeLists.txt:96 (option):
  Policy CMP0077 is not set: option() honors normal variables.  Run "cmake
  --help-policy CMP0077" for policy details.  Use the cmake_policy command to
  For compatibility with older versions of CMake, option is clearing the
  normal variable 'BUILD_SHARED_LIB'.
CMake Warning (dev) at extern/tidy-html5/CMakeLists.txt:145 (option):
  normal variable 'SUPPORT_CONSOLE_APP'.
-- *** Debug Logging is NOT enabled.
-- Using /MD DYNAMIC runtime
-- *** Also building DLL library SHARED, version 5.9.14, date 2021.08.17
CMake Error at C:/Program Files/CMake/share/cmake-3.26/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  C:/Program Files/CMake/share/cmake-3.26/Modules/FindPackageHandleStandardArgs.cmake:600 (_FPHSA_FAILURE_MESSAGE)
  extern/cesium-native/extern/KTX-Software/cmake/modules/FindBash.cmake:96 (find_package_handle_standard_args)
  extern/cesium-native/extern/KTX-Software/CMakeLists.txt:8 (find_package)
-- Configuring incomplete, errors occurred!
It seems one of the third-party components we use requires bash as part of its build process. The easiest way to get bash on Windows is to install git for Windows:
Found the reason, git and git bash are not in the same directory. You need to add the directory of git bash to the system environment variable. The location of git bash is: C: Program Files Git git is: C: Program Files Git cmd
The following figure
