Quantized-Mesh revolution
I’m just raising a possible evolution for Cesium terrain model.
So far I have used and generated HeightMap and later on QuantizedMesh terrains over the past years.
Today 3D-Tiles Next is available, everything is a GLTF extension.
The idea here would be to do the same with QuantizedMesh, after all everything in a QMesh can go in a GLB with all the benefits it can bring in compression, speed and source code simplification.
  • QMesh vertices → GLTF primitive positions
  • QMesh lightning → GLTF primitive normals
  • QMesh watermask → GLTF texture
  • QMesh metadata → GLTF extras
The missing elements : Center; MinimumHeight; MaximumHeight; BoundingSphereCenter; BoundingSphereRadius; HorizonOcclusionPoint;
  • Could be used if present in the metadata
  • Or use the clipping/frustum culling technique from the 3d-tiles implicit-tiling
This would allow users to have a 3dtiles data both as terrain and scene, which is often the case.
What do you think ?
