I’m interesting does Cesium in Unreal support quantized mesh in .qmesh format?
Thank you!
Thank you!
It definitely supports terrain in quantized-mesh format. I’ve never heard of .qmesh, though, (despite having designed the quantized-mesh format myself approximately a lifetime ago) so I guess maybe it doesn’t support that?
Hi @Kevin_Ring ,
The .qmesh is just the extension used for cesium quantized mesh in VRTW. I don’t know what Cesium uses for the extension? But it is Cesium quantized mesh the same as Cesium uses.
Our quantized-mesh tiles usually have the extension .terrain. But if .qmesh is the same quantized-mesh format that Cesium uses, then yes, it should be supported in Cesium for Unreal.
