I am trying to visualize ~19000 entities on the Cesium widget in order to render the buildings of a city.
I have the coordinates of the perimeter of every building in the city and I generate a different polygon and put it on the map.
The problem I am facing is the following: whenever the number of buildings to render is quite high (around 1000) Cesium starts lagging and after a while WebGL completely crashes and this error box from Cesium appears:
TypeError: Failed to execute 'shaderSource' on 'WebGLRenderingContext': parameter 1 is not of type 'WebGLShader'.
at p (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:475:9438)
at v (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:475:12575)
at c._bind (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:475:13590)
at V (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:497:5280)
at L.draw (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:497:8769)
at n.execute (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:474:15256)
at h.execute (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:496:9324)
at i.execute (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:496:7838)
at ke (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:508:17491)
at We (http://localhost:8080/Cesium/Build/Cesium/Cesium.js:508:21479)
OK
This is my code:
var buildings = new Cesium.CustomDataSource();
$.ajax({
url: SERVER_URL + "/building/max=46.061271,8.875321&min=45.940576,8.996019/", //COORDINATES TO GET BUILDINGS
type: "GET",
success: function (data) {
viewer.entities.suspendEvents();
for (var i = 0; i < data.length; i++) {
if (data[i]) {
var list = createList(data[i].ringGlobalCoords);
var height = (data[i].floors + 2) * 2;
viewer.entities.add({
id: 'building_' + data[i].id,
description: 'edificio desc',
polygon: {
hierarchy: Cesium.Cartesian3.fromDegreesArray(list),
height: data[i].altitude,
extrudedHeight: (data[i].floors + 2) * 2,
material: Cesium.Color.WHITE,
outline: false,
closeTop: true,
closeBottom: false,
distanceDisplayCondition: new Cesium.DistanceDisplayCondition(0, 15000.0)
viewer.entities.resumeEvents();
Do you have any idea how could I solve this problem or optimize the rendering of the buildings?
Thank you,
Andrea
