Steps
1) go to the https://cesiumjs.org/
2) click on tap to interact.
3) Select open street map view.
4) Go to under the ground level by zooming and rotating.
5) Following error was occurred when trying to rotate, zoom in or zoom out in under the ground level.
RangeError: invalid array length
E@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:510:12639
T.prototype.createPotentiallyVisibleSet@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:510:15752
Ke@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:511:6256
Xe@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:511:3641
st@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:511:12803
lt@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:511:12990
Ae.prototype.render@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:511:23308
S.prototype.render@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:512:31579
t@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:512:25039
just used the demo provided in the https://cesiumjs.org/.
operating system - windows 10
Browser- google chrome
