I've been working with Cesium for a while, but I just started with 3D Tiles now.
So I need to call a function that goes into the 3D tiles attributes and fetch the data under a certain name for example ${population} and then put them into a loop and find me the max and min values.
I do that simply with GeoJSONs and CZMLs... but no idea how it's done with 3D tiles..
But if you need to do something more complex than that you’ll need to loop over the features of loaded tiles.
One difference from GeoJSON and CZML is that not all the tiles will be loaded right away so the min/max of a property may change as tiles stream in. You can listen to the tileset.tileLoad and tileset.tileUnload events, and from there do something like:
*tileset.tileLoad.addEventListener(function(tile) {
var content = tile.content;
for (var i = 0; i < content.featuresLength; ++i) {
var feature = content.getFeature(i);
var value = feature.getProperty('population');
// Do min and max here
It looks easy enough
but turns out my problem is when I converted my data into 3D Tiles...
and try a simple styling function for a given attribute I get the following error
"An error occurred while rendering. Rendering has stopped.
undefined
RuntimeError: Operator ">=" requires number arguments. Arguments are 0 and 1."
Which I figure is due to double quotations around the attribute values.
is there a way to hack it?
and another question,
how do I remove the tiles from the scene?
I mean with other data sources you use: viewer.dataSources.removeAll();
is there a similar function for the tiles?
The dark shading is controlled by the shaders and materials inside the glTF models. There are a few different ways to edit the glTFs to get different lighting effects, if you send over a b3dm tile I could try seeing what’s best for your case.
Changing the line vec3 l = normalize(czm_sunDirectionEC); to vec3(0.0,0.0,1.0); in the fragment shader would probably do the trick. Just curious, what converters are you using? There may be options to output shaders that don’t use the cesium sun direction.
If you can’t control it from the FME side then it does sound like you’ll have to fix it manually or write a script to batch process the b3dms. I have seen tilesets exported from FME that don’t have the shaders built-in though, so there might be a hidden setting somewhere or supported in a different version of FME. You might have more luck contacting them. Ask about exporting b3dms with the KHR_materials_common extension.
