RuntimeError: Fragment shader failed to compile
Hello everyone.
CesiumJS is throwing a “RuntimeError: Fragment shader failed to compile” (full trace at the end).
After searching the forums, the suggestion has been to update the graphic card’s drivers, however I’m using the latest ones.
The problem occurs only if the GUI widgets are included.
If they are deactivated during initialization, the exception is not raised.
homeButton : false,
fullscreenButton : false,
navigationHelpButton : false,
navigationInstructionsInitiallyVisible: false,
sceneModePicker: false,
selectionIndicator: false,
infoBox: false,
terrainProvider : new Cesium.CesiumTerrainProvider({
url : ‘//assets.agi.com/stk-terrain/world’
Cesium version: 1.42
Browser: CEF 3.2987.1601.gf035232 (Chromium 57.0.2987.133)
Graphics card: Intel HD Graphics 520
OS: Windows 10
Traceback
Error
at new t (http://localhost:8080/Build/Cesium/Cesium.js:471:28582)
at f (http://localhost:8080/Build/Cesium/Cesium.js:497:25773)
at y (http://localhost:8080/Build/Cesium/Cesium.js:497:28190)
at d._bind (http://localhost:8080/Build/Cesium/Cesium.js:497:29205)
at V (http://localhost:8080/Build/Cesium/Cesium.js:523:2208)
at k.draw (http://localhost:8080/Build/Cesium/Cesium.js:523:5843)
at n.execute (http://localhost:8080/Build/Cesium/Cesium.js:496:30018)
at Ue (http://localhost:8080/Build/Cesium/Cesium.js:544:22509)
at He (http://localhost:8080/Build/Cesium/Cesium.js:544:24572)
at Ke (http://localhost:8080/Build/Cesium/Cesium.js:545:375)
I’m having a hard time figuring what could be going on here. Is it possible to run your application against Build/CesiumUnminified rather than Build/Cesium? It will give us a more description stack trace.
Gabby
Hello Gabby.
I was unable to find instructions on how to use CesiumUnminified. How can I use it instead?
Thanks.
-Jack
You should be able to use the Getting Started tutorial instructions and replace “/Build/Cesium/Cesium.js” with “/Build/CesiumUnminified/Cesium.js”.
You should also be able to put your code in this version of Sandcastle.
Gabby
