Hello.
I encountered an error which appears in the logs when I run dedicated server build with the Cesium plugin enabled. I’m using UE v5.1.0 Source Build from GitHub and Cesium for Unreal v1.21.0. It seems to be related to the the plugin’s ScreenCreditsWidget:
[2023.01.16-07.20.16:401][ 0]LogDeviceProfileManager: Active device profile: [000001DC5EA15380][000001DC5EC8B6E0 52] WindowsServer
[2023.01.16-07.20.16:401][ 0]LogCsvProfiler: Display: Metadata set : deviceprofile="WindowsServer"
[2023.01.16-07.20.16:411][ 0]LogNetVersion: CesiumServerTest 1.0.0, NetCL: 0, EngineNetVer: 30, GameNetVer: 0 (Checksum: 1387022388)
[2023.01.16-07.20.16:417][ 0]LogStreaming: Warning: LoadPackage: SkipPackage: /Engine/EngineFonts/Roboto (0x6DC6E590848F5708) - The package to load does not exist on disk or in the loader
[2023.01.16-07.20.16:417][ 0]LogUObjectGlobals: Warning: Failed to find object 'Font /Engine/EngineFonts/Roboto.Roboto'
[2023.01.16-07.20.16:418][ 0]Error: CDO Constructor (ScreenCreditsWidget): Failed to find /Engine/EngineFonts/Roboto
[2023.01.16-07.20.16:419][ 0]Error: CDO Constructor (ScreenCreditsWidget): Failed to find /Engine/EngineFonts/Roboto
[2023.01.16-07.20.16:419][ 0]LogSlate: Warning: FSlateFontInfo was constructed with a null UFont. Slate will be forced to use the fallback font path which may be slower.
[2023.01.16-07.20.16:420][ 0]LogSlate: Warning: FSlateFontInfo was constructed with a null UFont. Slate will be forced to use the fallback font path which may be slower.
[2023.01.16-07.20.16:437][ 0]LogAudioCaptureCore: Display: No Audio Capture implementations found. Audio input will be silent.
[2023.01.16-07.20.16:438][ 0]LogAudioCaptureCore: Display: No Audio Capture implementations found. Audio input will be silent.
[2023.01.16-07.20.16:465][ 0]LogUObjectBase: Warning: -------------- Default Property warnings and errors:
[2023.01.16-07.20.16:466][ 0]LogUObjectBase: Warning: Error: CDO Constructor (ScreenCreditsWidget): Failed to find /Engine/EngineFonts/Roboto
[2023.01.16-07.20.17:712][ 0]Message dialog closed, result: Ok, title: Message, text: Default Property warnings and errors:
This error goes away when I remove the plugin from my project. Fortunately, the error does not cause any bugs. Only a warning every time I run a server build.
