security error for amc bridge cesium
n error occurred while rendering. Rendering has stopped.
SecurityError: Failed to execute 'texImage2D' on 'WebGLRenderingContext': The image element contains cross-origin data, and may not be loaded.
    at new _ (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:478:20786)
    at F.update (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:479:15422)
    at E.update (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:521:6667)
    at f.update (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:525:11149)
    at rt (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:531:27383)
    at ht (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:532:1397)
    at pt (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:532:1594)
    at xe.render (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:532:9343)
    at A.render (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:538:25310)
    at t (http://10.150.35.18/cadtoearth.amcbridge.com/Scripts/Cesium/Cesium.js?v=0906132915:538:18760)
i like extracting terrains off cesium to do my projects
windows 10, chrome,
Where are you loading the image from? Can you show the piece of code you have for loading and visualizing the image?
