I have am trying to manually position the camera along the vector formed between an entity and the sun. The camera should look through the entity towards the sun. I get all the positions in inertial coordinates and then transform to fixed-frame so the camera will be positioned correctly. You will notice in my example that the camera appears to drift over time and then "snap" back to the correct position (click "view sun" and then speed up the clock to see the effect better). The odd thing is if you click 'view aircraft' you will notice I have a line that is pointing from the entity to the sun that does not show this weird drift / reset effect
infoBox: false, //Disable InfoBox widget
selectionIndicator: false, //Disable selection indicator
shouldAnimate: true, // Enable animations
terrainProvider: Cesium.createWorldTerrain()
//Enable lighting based on sun/moon positions
viewer.scene.globe.enableLighting = true;
//Enable depth testing so things behind the terrain disappear.
viewer.scene.globe.depthTestAgainstTerrain = true;
//Set the random number seed for consistent results.
Cesium.Math.setRandomNumberSeed(3);
//set labels for sun
var sunPositionProperty = new Cesium.CallbackProperty(function(time, result){
Cesium.Simon1994PlanetaryPositions.computeSunPositionInEarthInertialFrame(time, result);
return Cesium.PositionProperty.convertToReferenceFrame(
time,
result,
Cesium.ReferenceFrame.INERTIAL,
Cesium.ReferenceFrame.FIXED,
result);
}, false);
viewer.entities.add({
position : sunPositionProperty,
label : {
text : 'Sun'
var lineP1 = Cesium.Cartesian3.fromDegrees(-75, 35);
var lineP2 = Cesium.Cartesian3.fromDegrees(-175, 35);
var line_positions = [lineP1, lineP2];
function line_callback(time, result){
var sun_pos = {};
var curr_pos = {};
entity.position.getValue(time, lineP1);
sunPositionProperty.getValue(time, sun_pos);
Cesium.Cartesian3.subtract(sun_pos, lineP1, curr_pos);
Cesium.Cartesian3.normalize(curr_pos, curr_pos);
Cesium.Cartesian3.multiplyByScalar(curr_pos, 30, curr_pos);
Cesium.Cartesian3.add(curr_pos, lineP1, lineP2);
return line_positions;
var lineEntity = viewer.entities.add({
polyline : {
positions : new Cesium.CallbackProperty(line_callback, false),
width : 5,
material : new Cesium.PolylineArrowMaterialProperty(Cesium.Color.YELLOW),
//Compute the entity position property.
var position = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706, 10000000);
var heading = Cesium.Math.toRadians(135);
var pitch = 0;
var roll = 0;
var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
position : position,
orientation : orientation,
model : {
uri : '../../../../Apps/SampleData/models/CesiumAir/Cesium_Air.glb',
minimumPixelSize : 128,
maximumScale : 20000
var VIEW_TYPE = 0;
Sandcastle.addToolbarButton('View Sun', function() {
viewer.trackedEntity = undefined;
lineEntity.show = false;
VIEW_TYPE = 2;
//Add button to track the entity as it moves
Sandcastle.addToolbarButton('View Aircraft', function() {
VIEW_TYPE = 3;
lineEntity.show = true;
viewer.scene.sun.glowFactor = 25;
viewer.clock.onTick.addEventListener(function(clock)
if(VIEW_TYPE != 2)
return;
const Vec3 = Cesium.Cartesian3;
var currPos = new Vec3();
var sunPos = new Vec3();
var sunDir= new Vec3();
var offset = new Vec3();
var currPosInert = new Vec3();
var sunPosInert = new Vec3();
var sunDirInert = new Vec3();
var offsetInert = new Vec3();
var result = new Vec3();
//first method get sun position in inertial frame
Cesium.Simon1994PlanetaryPositions.computeSunPositionInEarthInertialFrame(clock.currentTime, sunPosInert);
//get entity / airplane position in inertial frame
entity.position.getValueInReferenceFrame(clock.currentTime, Cesium.ReferenceFrame.INERTIAL, currPosInert);
entity.position.getValueInReferenceFrame(clock.currentTime, Cesium.ReferenceFrame.FIXED, currPos);
//create the directional vector pointing to the sun from the entity / airplane
Vec3.subtract(sunPosInert, currPosInert, sunDirInert);
Vec3.normalize(sunDirInert, sunDirInert);
//scale the directional vector to create an offset for viewing (behind airplane)
Vec3.multiplyByScalar(sunDirInert, -300, offsetInert);
Vec3.add(currPosInert, offsetInert, currPosInert);
var icrfToFixedMat = new Cesium.Matrix3();
Cesium.Transforms.computeIcrfToFixedMatrix(clock.currentTime, icrfToFixedMat);
if(typeof icrfToFixedMat != 'undefined') {
Cesium.Matrix3.multiplyByVector(icrfToFixedMat, currPosInert, currPos);
Cesium.Matrix3.multiplyByVector(icrfToFixedMat, sunDirInert, sunDirInert);
viewer.camera.position = currPos;
viewer.camera.direction = sunDirInert;
In my actual application the position of the aircraft entity will be set by data sent from a realtime source. I need to manually position the camera to ensure it stays synced up with the aircraft and the sun.
4. The Cesium version you're using, your operating system and browser. Latest, MacOSX, Chrome
