When I select a polyline and then select a different polyline the first disappears automatically.
I would like to control the selection of at least two polyline, which means to get the first selection stay and select a second one.
My questions:
How can I get the selection Infobox to disappear only after the third selection or a different event?
Get the event that 2 selections has been pressed?
Kfir.
Hello Kfir,
This functionality is not currently supported in Cesium. You would have to make changes to the Viewer code: https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Widgets/Viewer/Viewer.js
Right now, viewer.selectedEntity is used to control what populates the infobox. You would need to add a second variable to store the other selected polyline, update the left click handler to allow selecting two entities, and then change the _onTick function to display whatever you want to appear in the infobox.
For information about downloading the code base and building the code, read our build guide: https://github.com/AnalyticalGraphicsInc/cesium/tree/master/Documentation/Contributors/BuildGuide
Hannah
Thanks a lot Hannah.
I go over it.
Kfir.
