Serving maps through Geoserver (running on windows) using wms to cesium globe
I am able to connect (probably) Geoserver to Cesium. However, the map layer that i have published is not visible on the globe. It shows the basic blue colored globe on the browser. When i use the same url and paste it on the web browser address bar, the image opens up nicely.
var layers = viewer.scene.globe.imageryLayers;
var WMSProvider = layers.addImageryProvider(new Cesium.WebMapServiceImageryProvider({
url: ‘http://localhost:8084//geoserver/ows?service=wms&version=1.3.0&request=GetMap’,
layers: ‘Demo:100k’
The map only covers the continent of asia. However, the entire globe appears blue in color. I require the asia map to be available. The remaining globe may remain blue in color.
Cesiumjs Version 1.2 is being used.
Most likely you need to enable CORS on your Geoserver in order to allow the images to be used from the server where you’re running Cesium.
https://enable-cors.org/
http://docs.geoserver.org/latest/en/user/production/container.html#enable-cors
