Should batchId start from 0?
I am working on my open source project to convert gltf to 3dtiles And here's my unfinished repository:
https://github.com/nxddsnc/gltf-to-3dtiles.
"Tileset.json" and the corresponding glb files(with batchIds) are successfully created. But I can not manage to do the correct picking in cesium.I
I looked into the code in cesium and found this snippet
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Scene/Batched3DModel3DTileContent.js#L416.
My question is:
1. Does that indicate the batchId should start from 0?
2. How the picking works and how can cesium tell that vertices in different lods with same batchId belong to the same "feature"?
        geocoder: false,
        fullscreenButton: false,
        sceneModePicker: false,
        animation: false,
        selectionIndicator: false,
        baseLayerPicker: false,
        homeButton: false,
        infoBox: false,
        timeline: false,
        navigationHelpButton: false,
        navigationInstructionsInitiallyVisible: false,
        creditContainer: ‘dummy’,
        globe: false
    var tileset = new Cesium.Cesium3DTileset({
        url: ‘http://localhost:8081/tileset.json
    tileset.readyPromise.then(function(tileset) {
        viewer.zoomTo(tileset, new Cesium.HeadingPitchRange(0.5, -0.2,
     tileset.boundingSphere.radius * 2.0));
    }).otherwise(function(error) {
        console.log(error);
    viewer.extend(Cesium.viewerCesium3DTilesInspectorMixin);
1.52. chrome latest.
Update.
My test results show that it should be start at 0.
For your picking question, from what I can tell it looks like each type of content has a special pick shader or a texture it renders for the picking pass, this would be a good place to look:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Scene/Cesium3DTileBatchTable.js#L1484
Thank you for you reply. I've looked into the picking code. In my understanding, the batchId should be started from 0 and increment continuesly since cesium uses "batchId" to compute the uv to get the corresponding color of "pickTexture". I'm not sure if I'm right, but the experimental result seems good so far.
