Showing latitude/longitude grids
Is there a way for toggling on/off latitude and longitude lines on the Earth via CZML?
Thank you.
This isn’t something that is built into Cesium, but you can add your own polylines to the earth to create a grid. See this example for how to create polylines using CZML: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=CZML%20Polyline.html&label=CZML
Hannah
I worked up a sample Sandcastle application for this if anyone is curious. It’s only for ~ one forth of the earth could easily be expanded to cover the entire earth.
Sample file attached.
CZML Polyline (3).html (2.65 KB)
