skybox background is vague,can it change HD
You can definitely create your own SkyBox if that’s what you mean! Just pass your images as Scott describes in this post:
https://groups.google.com/d/msg/cesium-dev/3LU5KQKDvjU/A46KT-D9DAAJ
