Hey! I have a quick question about skybox. Do the images used have to be a specific size? Whenever I try to change the SkyBox it just decides not to render one at all.
Also is it possible to use a static image in the background instead of using a skybox so the globe could rotate freely while the image remains the same?
I am trying to render a globe with a skybox that appears to be under water. A static image would be ideal but if I could use a collection of pictures to give the illusion that the globe was underwater that would work too.
I am running Cesium 1.39 in Chrome.
