Shadowmap darkness parameter does not work well with softshadows. If darkness is set to produce light shadows, like 0.9, we cannot see any soft edges.
How we fixed this:
float czm_private_shadowVisibility(float visibility, float nDotL, float normalShadingSmooth, float darkness)
#ifdef USE_NORMAL_SHADING
#ifdef USE_NORMAL_SHADING_SMOOTH
float strength = clamp(nDotL / normalShadingSmooth, 0.0, 1.0);
#else
float strength = step(0.0, nDotL);
#endif
visibility *= strength;
#endif
__ visibility = darkness + visibility * (1.0 - darkness);__
return visibility;
