1. How to hide and show billboardcollection ? Do i have to iterate through all billboards?
2, How to cluster billboards in billboardcollection?
If you want to configure clustering, you’ll need to handle the billboards as entities in a dataSource, rather than a billboardCollection. See an example here. If you use a dataSource, you will also be able to toggle the visibility of the entire set of billboards.
Gabby
