Spawn World3Dtileset by Blueprints
Hi, happy new year,
The quick start guide is good, but I want to spawn my Cesium actors with blueprints that provides better flexibility (e.g. when to start loading the tiles, when to hide the tiles when not necessary). After some tests I have arrived to the following blueprint which spawns a CesiumTileset and automatically creates a CesiumCreditSystem and CesiumGeoreference. However, the tileset does not have textures ??? PS: I had to set Ion Asset ID to 1 otherwise the tileset geometries were also missing.
Actually It is a duplicate of this
which is solved by Add Raster Ion Overlay !
Mark as solved
Hi there friends and distinguished community members,
It seems to be the problem you are facing is resovled. I would like offer you a more useful method.
1 Create Cesium3DTileset Actor Blueprint.
2 Edit Ion Access Token and ID
3 Click on the Add Component and select the CesiumIonRasterOverlay, and finally edit “Ion Access Token” and “ID”
4 Create One Fuction for test functionality
5 Open Level Blueprint spawn CustomMapActor and call function.
6 Click on the Play and see results
