Hi all,
I have a task which I need to achieve for my project. The task is very complicated for me to explain. I will just give you an example. In cesium I create an label entity which contain the name called Singapore.Then I want to take a session or video of the map and put in a mini 3D globe.
Let me give you another example, in this link, https://www.fireeye.com/cyber-map/threat-map.html.
You can see the mini globe in the bottom left corner. If there are arrows travelling in the big map, then you can see arrows in the mini globe. So it is like a duplicate session of the big map. Is it possible to achieve the video of the big map using Cesium function.
Please help me.
Thank you.
