Hi, I’m trying to run the terrain code example.
where it uses the data from VRtheworld like
var vrTheWorldProvider = new Cesium.VRTheWorldTerrainProvider({
credit : ‘Terrain data courtesy VT MÄK’
But it says in terminal: an error occurred in "VRTheWorldTerrainProvider": Request has failed.
However, I can open the url www.vr-theworld.com/vr-theworld/tiles1.0.0/73 successfully, which is a xml file.
a strange thing is, at first it is not a xml file, it is a page with sentence Hawaii World elev layer to make cesium work right EPSG:4326, then jump to the xml file.
Is it the reason of failure? How could I fix it?
Thanks!
