The browser supports WebGL, but initialization failed (mobile)
Fairly simple. Developing an app with Cesium view on Android and the viewer was loading properly until this morning, when I randomly received this error: "The browser supports WebGL, but initialization failed" and relatedly saying it has failed to create the Cesium Widget.
Issue is similar to this: https://groups.google.com/forum/#!topic/cesium-dev/RGbPxa4t4gY
However I am able to see the spinning cube, so there is no WebGL issue.
Any ideas on what to try?
I'm loading a built version of Cesium as an asset in Android Studio, which I inject into a Webview in React Native. Again, this all worked well until recently, and there were no relevant changes to that part of the code. Also, this works fine on iOS.
Cesium: 1.7.1
Android Galaxy S7 8.0 Oreo
Browser is default Android (Chrome, I believe)
Can you show the output you get from http://webglreport.com/ for WebGL 1?
That’s peculiar that it suddenly stopped working. Does the error/stack trace give any more info on what check might be failing that would be causing it to throw that error?
Cesium 1.7.1 is pretty old at this point. I wonder if the same issue is in the latest Cesium. We’d definitely like to know if you have a chance to test that.
Sure. I've attached screenshots of the main error as well as what is displayed when I click on the WebGL check. I can confirm that I tried updating to the latest version of Cesium and am receiving the same exact error, so it's not a matter of updating.
I'm not sure what to make of the error, but perhaps it will mean something to you:
error at new t (file:///android_asset/cesium/Cesium) ... etc..
followed by:
error at new B
error at new Ee
then A, J and keeps going...
I'll attach a screenshot of that as well as the WebGL report in a moment.
Omar, here are the attachments showing the Android errors.
Jordan
Can you try http://webglreport.com/ ? (Not get.webgl.org).
Looks like it’s failing to get the context:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Renderer/Context.js#L213-L217
It must be an Android specific issue. This seems relevant: https://github.com/mrdoob/three.js/issues/5793#issuecomment-100657954
I've resolved this issue. My solution was to add "allowUniversalAccessFromFileURLs={true}" to the React Native Webview. Android/Chrome throws a CORS error when you try to request JS from assets ('file://' vs http or https), but you can disable it by adding this property.
This is not what causes the initial error, which I was never able to isolate, but you can get around that error by firing a reload command to the Webview when the component loads (in React, on componentDidMount). That reload command will throw a CORS error unless you follow the step above, which should put you in the clear.
Hope this helps someone else!
Awesome, this is definitely going to be a useful resource for anyone else running into this. Thanks so much for digging into it and posting your solution!
