this what it give me
How did you open the file? Did you double click on the HTML file?
You need to setup a local web server. The quick start guide here might be easier to follow:
Scroll down until you see the 3 steps in the “Quick start”. Make sure you download and install and Nodejs, and that you open the localhost:8080 link to access the app.
yes, i do that … is the three steps for lunix ? i use window what i should do ? thank you for help
بتاريخ الجمعة، 21 ديسمبر، 2018 5:37:33 م UTC+2، كتب Omar Shehata:
ok, i understand …in cmd command i will run this
بتاريخ الجمعة، 21 ديسمبر، 2018 6:35:07 م UTC+2، كتب Ikhlass Ramadan:
