I am using the plane cropping example in the sandbox. I found that when the camera is at a certain distance from the cropping plane, the flat display is incomplete, but it does not seem to be caused by the camera’s near plane. Who has the same experience?
sandcastle: https://sandcastle.cesium.com/?src=3D%20Tiles%20Clipping%20Planes.html&label=All
