ThrowOnDestroyed called when changing silhouette parameters of a model loaded .fromGltf
Hi!
I've loaded a couple of models into my scene and want to apply a color highlight upon mouse hovering a picking and a silhouette when picked. When selecting a model that was already selected at some point I get hit with
DeveloperError: This object was destroyed, i.e., destroy() was called.
Error
    at new DeveloperError (webpack-internal:///./node_modules/cesium/Source/Core/DeveloperError.js:43:19)
    at ShaderProgram.throwOnDestroyed (webpack-internal:///./node_modules/cesium/Source/Core/destroyObject.js:45:19)
    at beginDraw (webpack-internal:///./node_modules/cesium/Source/Renderer/Context.js:967:23)
    at Context.draw (webpack-internal:///./node_modules/cesium/Source/Renderer/Context.js:1033:9)
    at DrawCommand.execute (webpack-internal:///./node_modules/cesium/Source/Renderer/DrawCommand.js:523:17)
    at executeCommand (webpack-internal:///./node_modules/cesium/Source/Scene/Scene.js:2093:21)
    at executeCommands (webpack-internal:///./node_modules/cesium/Source/Scene/Scene.js:2442:17)
    at executeCommandsInViewport (webpack-internal:///./node_modules/cesium/Source/Scene/Scene.js:2853:9)
    at updateAndExecuteCommands (webpack-internal:///./node_modules/cesium/Source/Scene/Scene.js:2701:13)
    at render (webpack-internal:///./node_modules/cesium/Source/Scene/Scene.js:3265:9)
I load my models...
const origin = Cesium.Cartesian3.fromDegrees(lon, lat, 0.0);
            const modelMatrix = Cesium.Transforms.eastNorthUpToFixedFrame(origin);
            const model = Cesium.Model.fromGltf({
                scene,
                url,
                modelMatrix,
                maximumScale: 1,
                minimumPixelSize: 128,
                scale: 1,
                incrementallyLoadTextures: false,
                heightReference: Cesium.HeightReference.CLAMP_TO_GROUND,
                colorBlendAmount: 1.0,
                colorBlendMode: Cesium.ColorBlendMode.HIGHLIGHT,
                silhouetteSize: 0.0,
                silhouetteColor: Cesium.Color.fromAlpha(Cesium.Color.GREENYELLOW, 1.0)
I am attaching a fairly simple handler...
viewer.screenSpaceEventHandler.setInputAction((movement) => {
    const pickedFeature = viewer.scene.pick(movement.endPosition);
    unitSelection.hover(pickedFeature);
    const pickedFeature = viewer.scene.pick(movement.position);
    if (Cesium.defined(pickedFeature)) unitSelection.select(pickedFeature);
    else {
        unitSelection.deselect();
        clickHandler(movement);
and my style application looks like so...
applyHoverStyle(target) {
                    target.primitive.color = Cesium.Color.fromAlpha(Cesium.Color.WHITE, 1.0);
                    target.primitive.colorBlendAmount = 0.6;
                    target.primitive.colorBlendMode = Cesium.ColorBlendMode.MIX;
                applySelectStyle(target) {
                    target.primitive.silhouetteSize = 2.0;
                    target.primitive.color = Cesium.Color.fromAlpha(Cesium.Color.GREENYELLOW, 1.0);
                resetStyle(target) {
                    target.primitive.colorBlendAmount = 1.0;
                    target.primitive.colorBlendMode = Cesium.ColorBlendMode.HIGHLIGHT;
                    target.primitive.silhouetteSize = 0.0;
Cesium: 1.47
Browser: Chrome 69.0.3497.81 and Firefox 62.0 (64-bit)
OS: Ubunt 18.04
Thanks a lot for the help!
You guys are doing an amazing job.
Hey Jan,
I don’t see anything wrong with your code off the top of my head. Are you able to recreate this error in a Sandcastle example you can share? That’ll help track this down.
Hey Omar,
I will do that and get back with the demo. Is there a Sandcastle JSFiddle like thing for that? Or should I just paste the code here?
Yes! On Sandcastle (https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/) just click “share” and paste the link you get from there here. That’d be the easiest.
