Timezone change in Play in Editor mode
it seems that timezone can not change in PIE mode. I have made the following BP for my slider widget. All the others are changing fine (time, day, month).
Is there any workaround to make timezone change in PIE mode ?
D.
Try calling UpdateSun on CesiumSunSky after changing the time zone. The node should look like this:
Please let me know if that helps with your problem.
-Alex
Yes this fixed the issue. Thanks a lot !
Here is the full solution
