Is there a tool which converts a CZML to a 3d corridor?
Context: If CZML is underground, lifting up the CZML an amount of meters like
https://groups.google.com/forum/#!searchin/cesium-dev/czml$202019|sort:date/cesium-dev/ioU_gWnaldE/1nHRFTquFQAJ
does not satisfy.
I think that a prismatic formed corridor with a proper height that is pulled along a CZML based skeleton would be a better solution.
Thx in advance for your useful hints
Josef
Remark - this is a rather bad solution:
Remain the CZML as original “underground” and change the path to width 100 (example).
Reason: it looks bad because of the zig-zag of the CZML.
Josef
omar
3
Can you describe a bit more what you’re trying to visualize? Maybe share a screenshot of your CZML file visualized in CesiumJS?
You could set an extruded height like in this example to extrude your corridor in 3D with CZML: https://sandcastle.cesium.com/index.html?src=CZML%20Corridor.html
Thx for your information. I will further use czml polylines although they do not clamp to ground.
Example:
My problem is solved for this time.
Josef
