ue5.1.1
cesiumForUnreal 2.4.0
Below are some errors reported:
UATHelper: 打包 (Linux): Running: G:\UE\ueinstallFile\UE_5.1\UE_5.1\Engine\Binaries\ThirdParty\DotNet\6.0.302\windows\dotnet.exe “G:\UE\ueinstallFile\UE_5.1\UE_5.1\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll” cesium5_1 Linux Development -Project=G:\UE\3d_projectDemo\bridge_project\cesium5.1\cesium5_1\cesium5_1.uproject G:\UE\3d_projectDemo\bridge_project\cesium5.1\cesium5_1\cesium5_1.uproject -NoUBTMakefiles -remoteini=“G:\UE\3d_projectDemo\bridge_project\cesium5.1\cesium5_1” -skipdeploy -Manifest=G:\UE\3d_projectDemo\bridge_project\cesium5.1\cesium5_1\Intermediate\Build\Manifes
t.xml -NoHotReload -log=“C:\Users\Administrator\AppData\Roaming\Unreal Engine\AutomationTool\Logs\G+UE+ueinstallFile+UE_5.1+UE_5.1\UBT-cesium5_1-Linux-Development.txt”
UATHelper: 打包 (Linux): Log file: C:\Users\Administrator\AppData\Roaming\Unreal Engine\AutomationTool\Logs\G+UE+ueinstallFile+UE_5.1+UE_5.1\UBT-cesium5_1-Linux-Development.txt
UATHelper: 打包 (Linux): Missing precompiled manifest for ‘CesiumRuntime’, ‘G:\UE\ueinstallFile\UE_5.1\UE_5.1\Engine\Plugins\Marketplace\CesiumForUnreal\Intermediate\Build\Linux\B4D820EA\UnrealGame\Development\CesiumRuntime\CesiumRuntime.precompiled’. This module was most likely not flagged for being included in a precompiled build - set ‘PrecompileForTargets = PrecompileTargetsType.Any;’ in CesiumRuntime.build.cs to override. If part of a plugin, also check if its ‘Type’ is correct.
UATHelper: 打包 (Linux): Took 1.4345672999999999s to run dotnet.exe, ExitCode=6
UATHelper: 打包 (Linux): UnrealBuildTool failed. See log for more details. (C:\Users\Administrator\AppData\Roaming\Unreal Engine\AutomationTool\Logs\G+UE+ueinstallFile+UE_5.1+UE_5.1\UBT-cesium5_1-Linux-Development.txt)
UATHelper: 打包 (Linux): AutomationTool executed for 0h 0m 4s
UATHelper: 打包 (Linux): AutomationTool exiting with ExitCode=6 (6)
UATHelper: 打包 (Linux): BUILD FAILED
PackagingResults: Error: Unknown Error
Hi @958627869,
Thanks for your report, and for including the error logs!
First, it would be helpful to know how you installed the plugin. Did you install it through the Unreal Marketplace? Or did you download it from Github? It may be worth a try to build the plugin locally.
Second, I noticed that you are using an older version of Unreal Engine and Cesium for Unreal. It would be helpful if you could upgrade your project version to check whether the latest version of the plugin has this issue (v2.7.0). If you’re worried about upgrading, you can always make a backup copy of your project.
Let us know what happens!
Yes, I installed the cesium plugin through the Unreal Market. Due to severe memory leakage issues with higher versions of UE, I am unable to upgrade UE. Alternatively, you can try creating a simple project that includes pixel stream plugins and cesium plugins, and try packaging it to see if it reports any errors
