UE5.2 | windows to linux Package Fail
5.1 was successful 5.2 Packaging Failure
The plugins downloaded and installed by others in the market can be successfully packaged, but I copied them and still failed to package them
Can you explain in more detail what you mean by:
I can’t quite follow what you did leading up to these errors.
Don’t consider the above content,When using cesium and pixel-stream together, this issue occurs when packaging Linux
Sorry, I still don’t know what you’re saying or asking. If it helps, we don’t mind if users post in their native language and we’ll translate it.
There is a problem currently with packaging Cesium for Unreal and Pixel Streaming together in UE 5.4 (perhaps you even wrote this issue!):
If that’s what you’re running into, it will be fixed in next week’s release.
If you’re running into a different problem (you mention UE 5.2 above), then please describe it in more detail, because I can’t help solve a problem that I don’t understand.
Thanks for your reply
