Hello everyone, just look at image! The lines is not right ,does anyone know?
PlaneTrack.cpp:
// Copyright 2020-2021 CesiumGS, Inc. and Contributors
#include "PlaneTrack.h"
// Sets default values
APlaneTrack::APlaneTrack()
// Set this actor to call Tick() every frame. You can turn this off to improve performance if you don't need it.
PrimaryActorTick.bCanEverTick = true;
// Initialize the track
SplineTrack = CreateDefaultSubobject<USplineComponent>(TEXT("SplineTrack"));
// This lets us visualize the spline in Play mode
SplineTrack->SetDrawDebug(true);
// Set the color of the spline
SplineTrack->SetUnselectedSplineSegmentColor(FLinearColor(1.f, 0.f, 0.f));
// Called when the game starts or when spawned
void APlaneTrack::BeginPlay()
Super::BeginPlay();
// Called every frame
void APlaneTrack::Tick(float DeltaTime)
Super::Tick(DeltaTime);
void APlaneTrack::LoadSplineTrackPoints()
if (this->AircraftsRawDataTable != nullptr && this->CesiumGeoreference != nullptr)
int32 PointIndex = 0;
for (auto& row : this->AircraftsRawDataTable->GetRowMap())
FAircraftRawData* Point = (FAircraftRawData*)row.Value;
// Get row data point in lat/long/alt and transform it into UE4 points
double PointLatitude = Point->latitude;
double PointLongitude = Point->longitude;
double PointHeight = Point->height;
// Compute the position in UE coordinates
glm::dvec3 UECoords = this->CesiumGeoreference->TransformLongitudeLatitudeHeightToUnreal(glm::dvec3(PointLongitude, PointLatitude, PointHeight));
FVector SplinePointPosition = FVector(UECoords.x, UECoords.y, UECoords.z);
this->SplineTrack->AddSplinePointAtIndex(SplinePointPosition, PointIndex, ESplineCoordinateSpace::World, false);
// Get the up vector at the position to orient the aircraft
const CesiumGeospatial::Ellipsoid& Ellipsoid = CesiumGeospatial::Ellipsoid::WGS84;
glm::dvec3 upVector = Ellipsoid.geodeticSurfaceNormal(CesiumGeospatial::Cartographic(FMath::DegreesToRadians(PointLongitude), FMath::DegreesToRadians(PointLatitude), FMath::DegreesToRadians(PointHeight)));
// Compute the up vector at each point to correctly orient the plane
glm::dvec4 ecefUp(upVector, 0.0);
const GeoTransforms& geoTransforms = this->CesiumGeoreference->GetGeoTransforms();
const glm::dmat4& ecefToUnreal = geoTransforms.GetEllipsoidCenteredToAbsoluteUnrealWorldTransform();
glm::dvec4 unrealUp = ecefToUnreal * ecefUp;
this->SplineTrack->SetUpVectorAtSplinePoint(PointIndex, FVector(unrealUp.x, unrealUp.y, unrealUp.z), ESplineCoordinateSpace::World, false);
PointIndex++;
this->SplineTrack->UpdateSpline();
PlaneTrack.h:
#pragma once
#include "Components/SplineComponent.h"
#include "CesiumGeoreference.h"
#include "Engine/DataTable.h"
#include <glm/vec3.hpp>
#include "CesiumGeospatial/Ellipsoid.h"
#include "CesiumGeospatial/Cartographic.h"
#include "CoreMinimal.h"
#include "GameFramework/Actor.h"
#include "PlaneTrack.generated.h"
// Add import paths. Make sure they go above the PlaneTrack.generated.h line
USTRUCT(BlueprintType)
struct FAircraftRawData : public FTableRowBase
GENERATED_USTRUCT_BODY()
public:
FAircraftRawData()
: longitude(0.0)
, latitude(0.0)
, height(0.0)
UPROPERTY(EditAnywhere, Category = "FlightTracker")
double longitude;
double latitude;
double height;
UCLASS()
class CESIUMFORUNREALSAMPLES_API APlaneTrack : public AActor
GENERATED_BODY()
public:
// Sets default values for this actor's properties
APlaneTrack();
// Function to parse the data table and create the spline track
UFUNCTION(BlueprintCallable, Category = "FlightTracker")
void LoadSplineTrackPoints();
// Spline variable to represent the plane track
UPROPERTY(BlueprintReadOnly, Category = "FlightTracker")
USplineComponent* SplineTrack;
// Cesium class that contain many useful coordinate conversion functions
ACesiumGeoreference* CesiumGeoreference;
// An Unreal Engine data table to store the raw flight data
UDataTable* AircraftsRawDataTable;
protected:
virtual void BeginPlay() override;
public:
virtual void Tick(float DeltaTime) override;
