Unreal Engine Version: 5.3.2
Hi! I’m following the “Build a Flight Tracker with Cesium for Unreal” for a school project. I’ve managed to succesfully follow all the steps without errors until Step 4.2. From this point, I’m not able to compile the code and the “Load Spline Track Points” is unavailable in step 4.7. I get the following errors below. I’m really stuck and would appreciate any kind of help! Thank you.
...\FlightTracker\Private\PlaneTrack.cpp(52): error C2039: 'TransformLongitudeLatitudeHeightToUnreal': is not a member of 'ACesiumGeoreference'
...\Public\CesiumGeoreference.h(35): note: see declaration of 'ACesiumGeoreference'
...\FlightTracker\Private\PlaneTrack.cpp(62): warning C4996: 'ACesiumGeoreference::GetGeoTransforms': Use transformation functions on ACesiumGeoreference and UCesiumWgs84Ellipsoid instead. Please update your code to the new API before upgrading to the next release, otherwise your project will no longer compile.
Image of the Level Blueprint, no “Load Spline Track Points” option:
PlaneTrack.h
// Fill out your copyright notice in the Description page of Project Settings.
#pragma once
#include "CoreMinimal.h"
#include "GameFramework/Actor.h"
// Step 2.3
#include "Components/SplineComponent.h"
#include "CesiumGeoreference.h"
#include "Engine/DataTable.h"
// Step 4.1
#include <glm/vec3.hpp>
#include "CesiumGeospatial/Ellipsoid.h"
#include "CesiumGeospatial/Cartographic.h"
#include "PlaneTrack.generated.h"
// Step 3.1
USTRUCT(BlueprintType)
struct FAircraftRawData : public FTableRowBase
GENERATED_USTRUCT_BODY()
public:
FAircraftRawData()
: Longitude(0.0)
, Latitude(0.0)
, Height(0.0)
UPROPERTY(EditAnywhere, Category = "FlightTracker")
double Longitude;
double Latitude;
double Height;
UCLASS()
class FLIGHTTRACKER_API APlaneTrack : public AActor
GENERATED_BODY()
public:
// Sets default values for this actor's properties
APlaneTrack();
// Spline variable to represent the plane track
UPROPERTY(BlueprintReadOnly, Category = "FlightTracker")
USplineComponent* SplineTrack;
// Cesium class that contain many useful coordinate conversion functions
ACesiumGeoreference* CesiumGeoreference;
// An Unreal Engine data table to store the raw flight data
UDataTable* AircraftsRawDataTable;
protected:
// Called when the game starts or when spawned
virtual void BeginPlay() override;
public:
// Called every frame
virtual void Tick(float DeltaTime) override;
// Step 4.1
// Function to parse the data table and create the spline track
UFUNCTION(BlueprintCallable, Category = "FlightTracker")
void LoadSplineTrackPoints();
PlaneTrack.cpp
#include "PlaneTrack.h"
APlaneTrack::APlaneTrack()
// Step 2.4
// Set this actor to call Tick() every frame. You can turn this off to improve performance if you don't need it.
PrimaryActorTick.bCanEverTick = true;
// Initialize the track
SplineTrack = CreateDefaultSubobject<USplineComponent>(TEXT("SplineTrack"));
// This lets us visualize the spline in Play mode
SplineTrack->SetDrawDebug(true);
// Set the color of the spline
SplineTrack->SetUnselectedSplineSegmentColor(FLinearColor(1.f, 0.f, 0.f));
void APlaneTrack::BeginPlay()
Super::BeginPlay();
void APlaneTrack::Tick(float DeltaTime)
Super::Tick(DeltaTime);
// Step 4.2
void APlaneTrack::LoadSplineTrackPoints()
if (this->AircraftsRawDataTable != nullptr && this->CesiumGeoreference != nullptr)
int32 PointIndex = 0;
for (auto& row : this->AircraftsRawDataTable->GetRowMap())
FAircraftRawData* Point = (FAircraftRawData*)row.Value;
// Get row data point in lat/long/alt and transform it into UE4 points
double PointLatitude = Point->Latitude;
double PointLongitude = Point->Longitude;
double PointHeight = Point->Height;
// Compute the position in UE coordinates
glm::dvec3 UECoords = this->CesiumGeoreference->TransformLongitudeLatitudeHeightToUnreal(glm::dvec3(PointLongitude, PointLatitude, PointHeight));
FVector SplinePointPosition = FVector(UECoords.x, UECoords.y, UECoords.z);
this->SplineTrack->AddSplinePointAtIndex(SplinePointPosition, PointIndex, ESplineCoordinateSpace::World, false);
// Get the up vector at the position to orient the aircraft
const CesiumGeospatial::Ellipsoid& Ellipsoid = CesiumGeospatial::Ellipsoid::WGS84;
glm::dvec3 upVector = Ellipsoid.geodeticSurfaceNormal(CesiumGeospatial::Cartographic(FMath::DegreesToRadians(PointLongitude), FMath::DegreesToRadians(PointLatitude), FMath::DegreesToRadians(PointHeight)));
// Compute the up vector at each point to correctly orient the plane
glm::dvec4 ecefUp(upVector, 0.0);
const GeoTransforms& geoTransforms = this->CesiumGeoreference->GetGeoTransforms();
const glm::dmat4& ecefToUnreal = geoTransforms.GetEllipsoidCenteredToAbsoluteUnrealWorldTransform();
glm::dvec4 unrealUp = ecefToUnreal * ecefUp;
this->SplineTrack->SetUpVectorAtSplinePoint(PointIndex, FVector(unrealUp.x, unrealUp.y, unrealUp.z), ESplineCoordinateSpace::World, false);
PointIndex++;
this->SplineTrack->UpdateSpline();
