Hi there,
I’ve followed the flight tracker tutorial and overcome my compile issues.
However upon reaching the end my spline does not show, also when I press play the animation does not seem correct.
The plane track actor is compiled and loaded as you’ll see from the screenshots.
What have I done wrong?
Can you share how you solved your compile issues, in case others run into them?
It’s really hard to say what the new problem is. No obvious problems jumps out at me in your screenshots. You’ll probably just need to double-check that you didn’t miss any steps in the tutorial. Perhaps someone else here that has run through the tutorial recently has some ideas?
