********** BUILD COMMAND COMPLETED **********
SafeFileExists Z:\Unreal Projects\skyplex-c2\SkyPlexC2\SkyPlexC2.uproject=True
********** COOK COMMAND STARTED **********
SafeFileExists Z:\UE_5.5\Engine\Binaries\Win64\UnrealEditor-Cmd.exe=True
Cleaning cooked data.
Running UnrealEditor Cook for project Z:\Unreal Projects\skyplex-c2\SkyPlexC2\SkyPlexC2.uproject
Commandlet log file is Z:\UE_5.5\Engine\Programs\AutomationTool\Saved\Cook-2025.07.08-21.36.04.txt
Running: Z:\UE_5.5\Engine\Binaries\Win64\UnrealEditor-Cmd.exe "Z:\Unreal Projects\skyplex-c2\SkyPlexC2\SkyPlexC2.uproject" -run=Cook -TargetPlatform=Windows -unversioned -fileopenlog -abslog="Z:\UE_5.5\Engine\Programs\AutomationTool\Saved\Cook-2025.07.08-21.36.04.txt" -stdout -CrashForUAT -unattended -NoLogTimes -UTF8Output
LogWindows: Warning: Failed to set completion port for job object "UE.ShaderCompileWorker.JobGroup": The parameter is incorrect.
LogInit: Display: Running engine for game: SkyPlexC2
LogCore: Display: Requested channels: 'cpu,gpu,frame,log,bookmark,screenshot,region'
LogTrace: Display: Display Control listening on port 35572
LogCsvProfiler: Display: Metadata set : platform="Windows"
LogCsvProfiler: Display: Metadata set : config="Development"
LogCsvProfiler: Display: Metadata set : buildversion="++UE5+Release-5.5-CL-40574608"
LogCsvProfiler: Display: Metadata set : engineversion="5.5.4-40574608+++UE5+Release-5.5"
LogCsvProfiler: Display: Metadata set : os="Windows 10 (22H2) [10.0.19045.5965] "
LogCsvProfiler: Display: Metadata set : cpu="AuthenticAMD|AMD Ryzen 5 3600 6-Core Processor"
LogCsvProfiler: Display: Metadata set : pgoenabled="0"
LogCsvProfiler: Display: Metadata set : pgoprofilingenabled="0"
LogCsvProfiler: Display: Metadata set : ltoenabled="0"
LogCsvProfiler: Display: Metadata set : asan="0"
LogCsvProfiler: Display: Metadata set : commandline="" "Z:\Unreal Projects\skyplex-c2\SkyPlexC2\SkyPlexC2.uproject" -run=Cook -TargetPlatform=Windows -unversioned -fileopenlog -abslog=Z:\UE_5.5\Engine\Programs\AutomationTool\Saved\Cook-2025.07.08-21.36.04.txt -stdout -CrashForUAT -unattended -NoLogTimes -UTF8Output""
LogCsvProfiler: Display: Metadata set : loginid="6eb0e0314c05e662c1540291db3adec7"
LogCsvProfiler: Display: Metadata set : llm="0"
LogConfig: Display: Loading Mac ini files took 0.07 seconds
LogConfig: Display: Loading VulkanPC ini files took 0.07 seconds
LogConfig: Display: Loading IOS ini files took 0.07 seconds
LogConfig: Display: Loading Android ini files took 0.07 seconds
LogAssetRegistry: Display: Asset registry cache read as 53.3 MiB from ../../../../Unreal Projects/skyplex-c2/SkyPlexC2/Intermediate/CachedAssetRegistry_0.bin
LogConfig: Display: Loading Unix ini files took 0.08 seconds
LogConfig: Display: Loading TVOS ini files took 0.09 seconds
LogConfig: Display: Loading LinuxArm64 ini files took 0.10 seconds
LogConfig: Display: Loading Linux ini files took 0.10 seconds
LogConfig: Display: Loading VisionOS ini files took 0.05 seconds
LogConfig: Display: Loading Windows ini files took 0.05 seconds
EditorErrors: Warning: Click to open file Found a deprecated ini key name in ../../../Engine/Plugins/Marketplace/Cesiumfo27e669801be6V8/Config/Editor.ini. Search for [RunningThreadedRequestLimitEditor] and replace with [Removed]
LogConfig: Warning: Found a deprecated ini key name in ../../../Engine/Plugins/Marketplace/Cesiumfo27e669801be6V8/Config/Editor.ini. Search for [RunningThreadedRequestLimitEditor] and replace with [Removed]
EditorErrors: Warning: Click to open file Found a deprecated ini key name in ../../../Engine/Plugins/Marketplace/Cesiumfo27e669801be6V8/Config/Engine.ini. Search for [RunningThreadedRequestLimit] and replace with [Removed]
LogConfig: Warning: Found a deprecated ini key name in ../../../Engine/Plugins/Marketplace/Cesiumfo27e669801be6V8/Config/Engine.ini. Search for [RunningThreadedRequestLimit] and replace with [Removed]
RenderDocPlugin: Display: RenderDoc plugin will not be loaded. Use '-AttachRenderDoc' on the cmd line or enable 'renderdoc.AutoAttach' in the plugin settings.
LogStudioTelemetry: Display: Starting StudioTelemetry Module
LogStreaming: Display: AsyncLoading2 - Created: Event Driven Loader: false, Async Loading Thread: false, Async Post Load: false
LogStreaming: Display: AsyncLoading2 - Initialized
LogHAL: Display: Platform has ~ 32 GB [34283012096 / 34359738368 / 32], which maps to Largest [LargestMinGB=32, LargerMinGB=12, DefaultMinGB=8, SmallerMinGB=6, SmallestMinGB=0)
LogCsvProfiler: Display: Metadata set : extradevelopmentmemorymb="0"
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatASTC
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatDXT
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatETC2
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatIntelISPCTexComp
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatUncompressed
LogTextureFormatOodle: Display: Oodle Texture TFO init; latest sdk version = 2.9.12
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.12.dll
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.5.dll
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatOodle
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_ASTC'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_DXT'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_ETC2'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'AndroidClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_ASTCClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_DXTClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_ETC2Client'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_Multi'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Android_MultiClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'IOS'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'IOSClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Linux'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'LinuxEditor'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'LinuxServer'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'LinuxClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'LinuxArm64'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'LinuxArm64Server'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'LinuxArm64Client'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Mac'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'MacEditor'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'MacServer'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'MacClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'TVOS'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'TVOSClient'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'Windows'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'WindowsEditor'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'WindowsServer'
LogTargetPlatformManager: Display: Loaded TargetPlatform 'WindowsClient'
LogTargetPlatformManager: Display: Building Assets For Windows
LogAudioDebug: Display: Lib vorbis DLL was dynamically loaded.
LogDerivedDataCache: Display: Memory: Max Cache Size: -1 MB
LogDerivedDataCache: Display: ../../../Engine/DerivedDataCache/Compressed.ddp: Opened pak cache for reading. (1559 MiB)
LogZenServiceInstance: Display: Unreal Zen Storage Server HTTP service at [::1]:8558 status: OK!.
LogDerivedDataCache: Display: ZenLocal: Using ZenServer HTTP service at http://[::1]:8558/ with namespace ue.ddc status: OK!.
LogDerivedDataCache: Display: C:/Users/ninte/AppData/Local/UnrealEngine/Common/DerivedDataCache: Performance: Latency=0.04ms. RandomReadSpeed=190.06MBs, RandomWriteSpeed=177.28MBs. Assigned SpeedClass 'Local'
LogShaderCompilers: Display: Using Local Shader Compiler with 9 workers.
LogShaderCompilers: Display: Compiling shader autogen file: ../../../../Unreal Projects/skyplex-c2/SkyPlexC2/Intermediate/ShaderAutogen/PCD3D_SM6/AutogenShaderHeaders.ush
LogShaderCompilers: Display: Autogen file is unchanged, skipping write.
LogEditorDomain: Display: EditorDomain is Disabled
LogAssetRegistry: Display: AssetDataGatherer spent 0.001s loading caches ../../../../Unreal Projects/skyplex-c2/SkyPlexC2/Intermediate/CachedAssetRegistry_*.bin.
LogStreaming: Display: FlushAsyncLoading(1): 1 QueuedPackages, 0 AsyncPackages
LogDeviceProfileManager: Display: Deviceprofile LinuxArm64Editor not found.
LogDeviceProfileManager: Display: Deviceprofile LinuxArm64 not found.
LogCsvProfiler: Display: Metadata set : deviceprofile="WindowsEditor"
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness (state: WaitingForIo) recursively from another package /Engine/EngineMaterials/DefaultTextMaterialOpaque (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness has reached state ExportsDone > CreateLinkerLoadExports, releasing request 8 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness with requester package /Engine/EngineMaterials/DefaultTextMaterialOpaque
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultTextMaterialOpaque (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness has reached state ExportsDone > CreateLinkerLoadExports, releasing request 9 to allow recursive sync load to finish
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec (state: WaitingForIo) recursively from another package /Engine/EngineMaterials/DefaultTextMaterialOpaque (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec has reached state ExportsDone > CreateLinkerLoadExports, releasing request 10 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec with requester package /Engine/EngineMaterials/DefaultTextMaterialOpaque
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultTextMaterialOpaque (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec has reached state ExportsDone > CreateLinkerLoadExports, releasing request 11 to allow recursive sync load to finish
LogStreaming: Display: Flushing package /Engine/EngineMaterials/WorldGridMaterial (state: WaitingForIo) recursively from another package /Engine/EngineMaterials/DefaultTextMaterialOpaque (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness (state: ExportsDone) recursively from another package /Engine/EngineMaterials/WorldGridMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness has reached state ExportsDone > CreateLinkerLoadExports, releasing request 13 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness with requester package /Engine/EngineMaterials/WorldGridMaterial
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec (state: ExportsDone) recursively from another package /Engine/EngineMaterials/WorldGridMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec has reached state ExportsDone > CreateLinkerLoadExports, releasing request 14 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec with requester package /Engine/EngineMaterials/WorldGridMaterial
LogStreaming: Display: Flushing package /Engine/EngineMaterials/DefaultDeferredDecalMaterial (state: WaitingForIo) recursively from another package /Engine/EngineMaterials/WorldGridMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultDeferredDecalMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness has reached state ExportsDone > CreateLinkerLoadExports, releasing request 16 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness with requester package /Engine/EngineMaterials/DefaultDeferredDecalMaterial
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultDeferredDecalMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec has reached state ExportsDone > CreateLinkerLoadExports, releasing request 17 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec with requester package /Engine/EngineMaterials/DefaultDeferredDecalMaterial
LogStreaming: Display: Flushing package /Engine/EngineMaterials/DefaultLightFunctionMaterial (state: WaitingForIo) recursively from another package /Engine/EngineMaterials/DefaultDeferredDecalMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultLightFunctionMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness has reached state ExportsDone > CreateLinkerLoadExports, releasing request 19 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness with requester package /Engine/EngineMaterials/DefaultLightFunctionMaterial
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultLightFunctionMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec has reached state ExportsDone > CreateLinkerLoadExports, releasing request 20 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec with requester package /Engine/EngineMaterials/DefaultLightFunctionMaterial
LogStreaming: Display: Flushing package /Engine/EngineMaterials/DefaultPostProcessMaterial (state: WaitingForIo) recursively from another package /Engine/EngineMaterials/DefaultLightFunctionMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/DefaultDiffuse with requester package /Engine/EngineMaterials/DefaultLightFunctionMaterial
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultPostProcessMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness has reached state ExportsDone > CreateLinkerLoadExports, releasing request 22 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/PowerToRoughness with requester package /Engine/EngineMaterials/DefaultPostProcessMaterial
LogStreaming: Display: Flushing package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultPostProcessMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec has reached state ExportsDone > CreateLinkerLoadExports, releasing request 23 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Shading/ConvertFromDiffSpec with requester package /Engine/EngineMaterials/DefaultPostProcessMaterial
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions02/Utility/BreakOutFloat2Components with requester package /Engine/EngineMaterials/DefaultLightFunctionMaterial
LogStreaming: Display: Package /Engine/EngineMaterials/DefaultPostProcessMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 21 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/DefaultPostProcessMaterial with requester package /Engine/EngineMaterials/DefaultLightFunctionMaterial
LogStreaming: Display: Flushing package /Engine/EngineMaterials/DefaultPostProcessMaterial (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultLightFunctionMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/EngineMaterials/DefaultPostProcessMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 24 to allow recursive sync load to finish
LogStreaming: Display: Package /Engine/EngineMaterials/DefaultLightFunctionMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 18 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/DefaultLightFunctionMaterial with requester package /Engine/EngineMaterials/DefaultDeferredDecalMaterial
LogStreaming: Display: Flushing package /Engine/EngineMaterials/DefaultLightFunctionMaterial (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultDeferredDecalMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/EngineMaterials/DefaultLightFunctionMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 25 to allow recursive sync load to finish
LogStreaming: Display: Package /Engine/EngineMaterials/DefaultDeferredDecalMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 15 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/DefaultDeferredDecalMaterial with requester package /Engine/EngineMaterials/WorldGridMaterial
LogStreaming: Display: Flushing package /Engine/EngineMaterials/DefaultDeferredDecalMaterial (state: ExportsDone) recursively from another package /Engine/EngineMaterials/WorldGridMaterial (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/EngineMaterials/DefaultDeferredDecalMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 26 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/Functions/Engine_MaterialFunctions01/Opacity/CameraDepthFade with requester package /Engine/EngineMaterials/DefaultTextMaterialOpaque
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/T_Default_Material_Grid_M with requester package /Engine/EngineMaterials/DefaultTextMaterialOpaque
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/T_Default_Material_Grid_N with requester package /Engine/EngineMaterials/DefaultTextMaterialOpaque
LogStreaming: Display: Package /Engine/EngineMaterials/WorldGridMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 12 to allow recursive sync load to finish
LogStreaming: Display: Merging postload groups of package /Engine/EngineMaterials/WorldGridMaterial with requester package /Engine/EngineMaterials/DefaultTextMaterialOpaque
LogStreaming: Display: Flushing package /Engine/EngineMaterials/WorldGridMaterial (state: ExportsDone) recursively from another package /Engine/EngineMaterials/DefaultTextMaterialOpaque (state: CreateLinkerLoadExports) will result in a partially loaded package to avoid a deadlock.
LogStreaming: Display: Package /Engine/EngineMaterials/WorldGridMaterial has reached state ExportsDone > CreateLinkerLoadExports, releasing request 27 to allow recursive sync load to finish
LogTextureEncodingSettings: Display: Texture Encode Speed: Final (cook).
LogTextureEncodingSettings: Display: Oodle Texture Encode Speed settings: Fast: RDO Off Lambda=0, Effort=Normal Final: RDO Off Lambda=0, Effort=Normal
LogTextureEncodingSettings: Display: Shared linear texture encoding: Disabled
LogMeshReduction: Display: Using QuadricMeshReduction for automatic static mesh reduction
LogMeshReduction: Display: Using SkeletalMeshReduction for automatic skeletal mesh reduction
LogMeshReduction: Display: Using ProxyLODMeshReduction for automatic mesh merging
LogMeshReduction: Display: No distributed automatic mesh merging module available
LogVirtualization: Display: VirtualizationSystem name found in ini file: None
LogVirtualization: Display: FNullVirtualizationSystem mounted, virtualization will be disabled
LogWorldPartition: Display: FWorldPartitionClassDescRegistry::Initialize started...
LogWorldPartition: Display: FWorldPartitionClassDescRegistry::Initialize took 2.578 ms
LogMetaSound: Display: MetaSound Page Target Initialized to 'Default'
LogAudio: Display: Registering Engine Module Parameter Interfaces...
Took 12.17s to run UnrealEditor-Cmd.exe, ExitCode=3
SafeDeleteFile C:\Users\ninte\AppData\Roaming\Unreal Engine\AutomationTool\Logs\Z+UE_5.5\Cook-2025.07.08-21.36.16.txt
SafeCopyFile Z:\UE_5.5\Engine\Programs\AutomationTool\Saved\Cook-2025.07.08-21.36.04.txt C:\Users\ninte\AppData\Roaming\Unreal Engine\AutomationTool\Logs\Z+UE_5.5\Cook-2025.07.08-21.36.16.txt
SafeDeleteFile Z:\UE_5.5\Engine\Programs\AutomationTool\Saved\Cook-2025.07.08-21.36.04.txt
Cook failed.
(see C:\Users\ninte\AppData\Roaming\Unreal Engine\AutomationTool\Logs\Z+UE_5.5\Log.txt for full exception trace)
CommandletException: Editor terminated with exit code 3 while running Cook for Z:\Unreal Projects\skyplex-c2\SkyPlexC2\SkyPlexC2.uproject; see log C:\Users\ninte\AppData\Roaming\Unreal Engine\AutomationTool\Logs\Z+UE_5.5\Cook-2025.07.08-21.36.16.txt
at AutomationTool.CommandUtils.FinishRunCommandlet(FileReference ProjectFile, String Commandlet, DateTime StartTime, IProcessResult RunResult, String LocalLogFile, String& DestLogFile, UInt32 ErrorLevel) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\CommandletUtils.cs:line 477
at AutomationTool.CommandUtils.RunCommandlet(FileReference ProjectFile, String UnrealExe, String Commandlet, String Parameters, String& DestLogFile, UInt32 ErrorLevel) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\CommandletUtils.cs:line 281
at AutomationTool.CommandUtils.RunCommandlet(FileReference ProjectFile, String UnrealExe, String Commandlet, String Parameters, UInt32 ErrorLevel) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\CommandletUtils.cs:line 247
at AutomationTool.CommandUtils.CookCommandlet(FileReference ProjectFile, String UnrealExe, String[] Maps, String[] Dirs, String InternationalizationPreset, String[] CulturesToCook, String TargetPlatform, String Parameters) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\CommandletUtils.cs:line 93
at AutomationScripts.Project.Cook(ProjectParams Params) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\Scripts\CookCommand.Automation.cs:line 295Wrapped by AutomationException: Cook failed.
at AutomationScripts.Project.Cook(ProjectParams Params) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\Scripts\CookCommand.Automation.cs:line 305
at BuildCookRun.DoBuildCookRun(ProjectParams Params) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\Scripts\BuildCookRun.Automation.cs:line 253
at BuildCookRun.ExecuteBuild() in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\Scripts\BuildCookRun.Automation.cs:line 43
at AutomationTool.BuildCommand.Execute() in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\BuildCommand.cs:line 372
at AutomationTool.BuildCommand.ExecuteAsync() in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\BuildCommand.cs:line 381
at AutomationTool.Automation.ExecuteAsync(List`1 CommandsToExecute, Dictionary`2 Commands) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\Automation.cs:line 284
at AutomationTool.Automation.ExecuteAsync(List`1 CommandsToExecute, Dictionary`2 Commands) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\Automation.cs:line 308
at AutomationTool.Automation.ProcessAsync(ParsedCommandLine AutomationToolCommandLine, StartupTraceListener StartupListener, HashSet`1 ScriptModuleAssemblies) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\AutomationTool\AutomationUtils\Automation.cs:line 168
AutomationTool executed for 0h 1m 35s
AutomationTool exiting with ExitCode=25 (Error_UnknownCookFailure)
So sorry about the multiple replies, the full log was passed the character limit and I couldnt upload a zip file as a new user
