Unreal Engine level packing error
Hello , trying to export executable file with Cesium , Luma AI and with VR controlls plugins , but every time occurs error ( already exported other .exe files of other levels ) . Is that possible to create such file ?
Please share the exact error and, ideally, the entire log.
Please :
LogStats: Stats thread started at 0.183950
LogICUInternationalization: ICU TimeZone Detection - Raw Offset: +2:00, Platform Override: ‘’
LogInit: Session CrashGUID >====================================================
Session CrashGUID > UECC-Windows-A66FC2224D87977AB57928854B55C69D
LogConfig: Display: Loading Android ini files took 0.02 seconds
LogConfig: Display: Loading Mac ini files took 0.02 seconds
LogConfig: Display: Loading VulkanPC ini files took 0.02 seconds
LogConfig: Display: Loading IOS ini files took 0.02 seconds
LogConfig: Display: Loading Windows ini files took 0.02 seconds
LogConfig: Display: Loading Unix ini files took 0.02 seconds
LogConfig: Display: Loading TVOS ini files took 0.03 seconds
LogConfig: Display: Loading Linux ini files took 0.03 seconds
LogConfig: Display: Loading LinuxArm64 ini files took 0.03 seconds
LogPluginManager: Mounting Engine plugin EnhancedInput
LogPluginManager: Found config from plugin[EnhancedInput] Input
LogPluginManager: Mounting Engine plugin FastBuildController
LogPluginManager: Mounting Engine plugin MeshPainting
LogPluginManager: Mounting Engine plugin XGEController
LogPluginManager: Mounting Engine plugin TraceUtilities
LogPluginManager: Mounting Engine plugin Bridge
LogPluginManager: Mounting Engine plugin AISupport
LogPluginManager: Mounting Engine plugin EnvironmentQueryEditor
LogPluginManager: Mounting Engine plugin AutomationUtils
LogPluginManager: Mounting Engine plugin BackChannel
LogPluginManager: Mounting Engine plugin ChaosCaching
LogPluginManager: Mounting Engine plugin ChaosCloth
LogPluginManager: Mounting Engine plugin ChaosClothEditor
LogPluginManager: Mounting Engine plugin ChaosEditor
LogPluginManager: Mounting Engine plugin ChaosNiagara
LogPluginManager: Mounting Engine plugin ChaosUserDataPT
LogPluginManager: Mounting Engine plugin ChaosSolverPlugin
LogPluginManager: Mounting Engine plugin CharacterAI
LogPluginManager: Mounting Engine plugin Dataflow
LogPluginManager: Mounting Engine plugin Fracture
LogPluginManager: Mounting Engine plugin FullBodyIK
LogPluginManager: Mounting Engine plugin GeometryCollectionPlugin
LogPluginManager: Mounting Engine plugin Landmass
LogPluginManager: Mounting Engine plugin LocalizableMessage
LogPluginManager: Mounting Engine plugin MeshModelingToolsetExp
LogPluginManager: Mounting Engine plugin OpenImageDenoise
LogPluginManager: Mounting Engine plugin PlatformCrypto
LogPluginManager: Mounting Engine plugin PlanarCut
LogPluginManager: Mounting Engine plugin ProxyLODPlugin
LogPluginManager: Mounting Engine plugin PythonScriptPlugin
LogPluginManager: Mounting Engine plugin SkeletalReduction
LogPluginManager: Mounting Engine plugin Text3D
LogPluginManager: Mounting Engine plugin ToolPresets
LogPluginManager: Mounting Engine plugin StructUtils
LogPluginManager: Mounting Engine plugin Water
LogPluginManager: Mounting Engine plugin LauncherChunkInstaller
LogPluginManager: Mounting Engine plugin AlembicImporter
LogPluginManager: Mounting Engine plugin ActorSequence
LogPluginManager: Mounting Engine plugin CesiumForUnreal
LogPluginManager: Found config from plugin[CesiumForUnreal] Engine
LogPluginManager: Mounting Engine plugin TemplateSequence
LogPluginManager: Mounting Engine plugin ActorLayerUtilities
LogPluginManager: Mounting Engine plugin SequencerScripting
LogPluginManager: Mounting Engine plugin LevelSequenceEditor
LogPluginManager: Mounting Engine plugin AndroidMoviePlayer
LogPluginManager: Mounting Engine plugin AndroidDeviceProfileSelector
LogPluginManager: Mounting Engine plugin AndroidPermission
LogPluginManager: Mounting Engine plugin AppleMoviePlayer
LogPluginManager: Mounting Engine plugin AppleImageUtils
LogAssetRegistry: Display: Asset registry cache read as 25.3 MiB from …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/CachedAssetRegistry_0.bin
LogPluginManager: Mounting Engine plugin AssetTags
LogPluginManager: Mounting Engine plugin AudioSynesthesia
LogPluginManager: Mounting Engine plugin AudioCapture
LogPluginManager: Mounting Engine plugin AndroidFileServer
LogPluginManager: Mounting Engine plugin ChunkDownloader
LogPluginManager: Mounting Engine plugin ArchVisCharacter
LogPluginManager: Mounting Engine plugin CableComponent
LogPluginManager: Mounting Engine plugin AudioWidgets
LogPluginManager: Mounting Engine plugin CustomMeshComponent
LogPluginManager: Mounting Engine plugin ExampleDeviceProfileSelector
LogPluginManager: Mounting Engine plugin GoogleCloudMessaging
LogPluginManager: Mounting Engine plugin GeometryCache
LogPluginManager: Mounting Engine plugin GeometryProcessing
LogPluginManager: Mounting Engine plugin GooglePAD
LogPluginManager: Mounting Engine plugin HDRIBackdrop
LogPluginManager: Mounting Engine plugin InputDebugging
LogPluginManager: Found config from plugin[InputDebugging] Input
LogPluginManager: Mounting Engine plugin IOSDeviceProfileSelector
LogPluginManager: Mounting Engine plugin LinuxDeviceProfileSelector
LogPluginManager: Mounting Engine plugin LocationServicesBPLibrary
LogPluginManager: Mounting Engine plugin Metasound
LogPluginManager: Mounting Engine plugin MobilePatchingUtils
LogPluginManager: Mounting Engine plugin MsQuic
LogPluginManager: Mounting Engine plugin OpenXRHandTracking
LogPluginManager: Mounting Engine plugin OpenXREyeTracker
LogPluginManager: Mounting Engine plugin PropertyAccessEditor
LogPluginManager: Mounting Engine plugin ProceduralMeshComponent
LogPluginManager: Mounting Engine plugin SignificanceManager
LogPluginManager: Mounting Engine plugin RigVM
LogPluginManager: Mounting Engine plugin ResonanceAudio
LogPluginManager: Mounting Engine plugin SoundFields
LogPluginManager: Mounting Engine plugin SunPosition
LogPluginManager: Mounting Engine plugin Synthesis
LogPluginManager: Mounting Engine plugin WaveTable
LogPluginManager: Mounting Engine plugin WebMMoviePlayer
LogPluginManager: Mounting Engine plugin WindowsMoviePlayer
LogPluginManager: Mounting Engine plugin WindowsDeviceProfileSelector
LogPluginManager: Mounting Engine plugin XRBase
LogPluginManager: Mounting Engine plugin CameraShakePreviewer
LogPluginManager: Mounting Engine plugin GameplayCameras
LogPluginManager: Mounting Engine plugin DatasmithContent
LogPluginManager: Mounting Engine plugin GLTFExporter
LogPluginManager: Mounting Engine plugin VariantManager
LogPluginManager: Mounting Engine plugin VariantManagerContent
LogPluginManager: Mounting Engine plugin OnlineBase
LogPluginManager: Mounting Engine plugin OnlineServices
LogPluginManager: Mounting Engine plugin OnlineSubsystem
LogPluginManager: Mounting Engine plugin OnlineSubsystemNull
LogPluginManager: Mounting Engine plugin OnlineSubsystemUtils
LogPluginManager: Mounting Engine plugin Takes
LogPluginManager: Mounting Engine plugin AndroidMedia
LogPluginManager: Mounting Engine plugin OodleNetwork
LogPluginManager: Mounting Engine plugin AvfMedia
LogPluginManager: Mounting Engine plugin MediaCompositing
LogPluginManager: Mounting Engine plugin ImgMedia
LogPluginManager: Mounting Engine plugin MediaPlayerEditor
LogPluginManager: Mounting Engine plugin MediaPlate
LogPluginManager: Mounting Engine plugin WebMMedia
LogPluginManager: Mounting Engine plugin TcpMessaging
LogPluginManager: Mounting Engine plugin UdpMessaging
LogPluginManager: Mounting Engine plugin InterchangeTests
LogPluginManager: Mounting Engine plugin WmfMedia
LogPluginManager: Mounting Engine plugin AnimationSharing
LogPluginManager: Mounting Engine plugin CodeLiteSourceCodeAccess
LogPluginManager: Mounting Engine plugin CLionSourceCodeAccess
LogPluginManager: Mounting Engine plugin DumpGPUServices
LogPluginManager: Mounting Engine plugin GitSourceControl
LogPluginManager: Mounting Engine plugin N10XSourceCodeAccess
LogPluginManager: Mounting Engine plugin KDevelopSourceCodeAccess
LogPluginManager: Mounting Engine plugin NullSourceCodeAccess
LogPluginManager: Mounting Engine plugin PerforceSourceControl
LogPluginManager: Mounting Engine plugin PixWinPlugin
LogPluginManager: Mounting Engine plugin RenderDocPlugin
LogPluginManager: Mounting Engine plugin PluginUtils
LogPluginManager: Mounting Engine plugin PropertyAccessNode
LogPluginManager: Mounting Engine plugin PlasticSourceControl
LogPluginManager: Mounting Engine plugin SubversionSourceControl
LogPluginManager: Mounting Engine plugin TextureFormatOodle
LogPluginManager: Mounting Engine plugin RiderSourceCodeAccess
LogPluginManager: Mounting Engine plugin UObjectPlugin
LogPluginManager: Mounting Engine plugin VisualStudioCodeSourceCodeAccess
LogPluginManager: Mounting Engine plugin VisualStudioSourceCodeAccess
LogPluginManager: Mounting Engine plugin XCodeSourceCodeAccess
LogPluginManager: Mounting Engine plugin TraceDataFilters
LogPluginManager: Mounting Engine plugin AssetManagerEditor
LogPluginManager: Mounting Engine plugin BlueprintHeaderView
LogPluginManager: Mounting Engine plugin ChangelistReview
LogPluginManager: Mounting Engine plugin CryptoKeys
LogPluginManager: Mounting Engine plugin CurveEditorTools
LogPluginManager: Mounting Engine plugin DataValidation
LogPluginManager: Mounting Engine plugin BlueprintMaterialTextureNodes
LogPluginManager: Mounting Engine plugin FacialAnimation
LogPluginManager: Mounting Engine plugin EngineAssetDefinitions
LogPluginManager: Mounting Engine plugin GameplayTagsEditor
LogPluginManager: Mounting Engine plugin GeometryMode
LogPluginManager: Mounting Engine plugin MacGraphicsSwitching
LogPluginManager: Mounting Engine plugin MaterialAnalyzer
LogPluginManager: Mounting Engine plugin MobileLauncherProfileWizard
LogPluginManager: Mounting Engine plugin EditorDebugTools
LogPluginManager: Mounting Engine plugin SpeedTreeImporter
LogPluginManager: Mounting Engine plugin EditorScriptingUtilities
LogPluginManager: Mounting Engine plugin SequencerAnimTools
LogPluginManager: Mounting Engine plugin PluginBrowser
LogPluginManager: Mounting Engine plugin UVEditor
LogPluginManager: Mounting Engine plugin InterchangeEditor
LogPluginManager: Mounting Engine plugin WorldPartitionHLODUtilities
LogPluginManager: Mounting Engine plugin Niagara
LogPluginManager: Mounting Engine plugin AnimationData
LogPluginManager: Mounting Engine plugin ACLPlugin
LogPluginManager: Mounting Engine plugin Paper2D
LogPluginManager: Mounting Engine plugin AnimationModifierLibrary
LogPluginManager: Mounting Engine plugin BlendSpaceMotionAnalysis
LogPluginManager: Mounting Engine plugin ControlRigSpline
LogPluginManager: Mounting Engine plugin LiveLink
LogPluginManager: Mounting Engine plugin IKRig
LogPluginManager: Mounting Engine plugin SQLiteCore
LogPluginManager: Mounting Engine plugin OnlineSubsystemIOS
LogPluginManager: Mounting Engine plugin ConcertMain
LogPluginManager: Mounting Engine plugin OnlineSubsystemGooglePlay
LogPluginManager: Mounting Engine plugin ContentBrowserAssetDataSource
LogPluginManager: Mounting Engine plugin ContentBrowserClassDataSource
LogPluginManager: Mounting Engine plugin PortableObjectFileDataSource
LogPluginManager: Mounting Engine plugin LightMixer
LogPluginManager: Mounting Engine plugin ObjectMixer
LogPluginManager: Mounting Engine plugin ContentBrowserFileDataSource
LogPluginManager: Mounting Engine plugin ConcertSyncClient
LogPluginManager: Mounting Engine plugin ConcertSyncCore
LogPluginManager: Mounting Project plugin LumaAIPlugin
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/TraceUtilities/Content/’ mounted to ‘/TraceUtilities/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Bridge/Content/’ mounted to ‘/Bridge/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/ChaosCaching/Content/’ mounted to ‘/ChaosCaching/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/ChaosClothEditor/Content/’ mounted to ‘/ChaosClothEditor/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/ChaosNiagara/Content/’ mounted to ‘/ChaosNiagara/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/ChaosSolverPlugin/Content/’ mounted to ‘/ChaosSolverPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/Dataflow/Content/’ mounted to ‘/Dataflow/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/FullBodyIK/Content/’ mounted to ‘/FullBodyIK/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/GeometryCollectionPlugin/Content/’ mounted to ‘/GeometryCollectionPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/Landmass/Content/’ mounted to ‘/Landmass/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/MeshModelingToolsetExp/Content/’ mounted to ‘/MeshModelingToolsetExp/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/PythonScriptPlugin/Content/’ mounted to ‘/PythonScriptPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/ToolPresets/Content/’ mounted to ‘/ToolPresets/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Experimental/Water/Content/’ mounted to ‘/Water/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Marketplace/CesiumForUnreal/Content/’ mounted to ‘/CesiumForUnreal/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/MovieScene/SequencerScripting/Content/’ mounted to ‘/SequencerScripting/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/AudioSynesthesia/Content/’ mounted to ‘/AudioSynesthesia/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/AudioWidgets/Content/’ mounted to ‘/AudioWidgets/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/GeometryProcessing/Content/’ mounted to ‘/GeometryProcessing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/HDRIBackdrop/Content/’ mounted to ‘/HDRIBackdrop/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/Metasound/Content/’ mounted to ‘/Metasound/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/MeshModelingToolset/Content/’ mounted to ‘/MeshModelingToolset/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/OpenXRHandTracking/Content/’ mounted to ‘/OpenXRHandTracking/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/OpenXR/Content/’ mounted to ‘/OpenXR/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/OpenXREyeTracker/Content/’ mounted to ‘/OpenXREyeTracker/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/RigVM/Content/’ mounted to ‘/RigVM/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/ResonanceAudio/Content/’ mounted to ‘/ResonanceAudio/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/SunPosition/Content/’ mounted to ‘/SunPosition/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/Synthesis/Content/’ mounted to ‘/Synthesis/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Runtime/WaveTable/Content/’ mounted to ‘/WaveTable/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Enterprise/DatasmithContent/Content/’ mounted to ‘/DatasmithContent/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Enterprise/GLTFExporter/Content/’ mounted to ‘/GLTFExporter/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/VirtualProduction/Takes/Content/’ mounted to ‘/Takes/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Media/MediaCompositing/Content/’ mounted to ‘/MediaCompositing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Media/MediaPlate/Content/’ mounted to ‘/MediaPlate/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Developer/AnimationSharing/Content/’ mounted to ‘/AnimationSharing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Editor/BlueprintHeaderView/Content/’ mounted to ‘/BlueprintHeaderView/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Editor/GeometryMode/Content/’ mounted to ‘/GeometryMode/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Editor/SpeedTreeImporter/Content/’ mounted to ‘/SpeedTreeImporter/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Editor/UVEditor/Content/’ mounted to ‘/UVEditor/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Interchange/Runtime/Content/’ mounted to ‘/Interchange/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/FX/Niagara/Content/’ mounted to ‘/Niagara/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Animation/ACLPlugin/Content/’ mounted to ‘/ACLPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/2D/Paper2D/Content/’ mounted to ‘/Paper2D/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Animation/ControlRigSpline/Content/’ mounted to ‘/ControlRigSpline/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Animation/IKRig/Content/’ mounted to ‘/IKRig/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Animation/ControlRig/Content/’ mounted to ‘/ControlRig/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Editor/ObjectMixer/LightMixer/Content/’ mounted to ‘/LightMixer/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Editor/ObjectMixer/ObjectMixer/Content/’ mounted to ‘/ObjectMixer/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/Developer/Concert/ConcertSync/ConcertSyncClient/Content/’ mounted to ‘/ConcertSyncClient/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Plugins/LumaAI_2023_10_26_5.3/Content/’ mounted to ‘/LumaAIPlugin/’
SourceControl: Revision control is disabled
LogInit: Using libcurl 8.4.0
LogInit: - built for Windows
LogInit: - supports SSL with OpenSSL/1.1.1t
LogInit: - supports HTTP deflate (compression) using libz 1.2.13
LogInit: - other features:
LogInit: CURL_VERSION_SSL
LogInit: CURL_VERSION_LIBZ
LogInit: CURL_VERSION_IPV6
LogInit: CURL_VERSION_ASYNCHDNS
LogInit: CURL_VERSION_LARGEFILE
LogInit: CurlRequestOptions (configurable via config and command line):
LogInit: - bVerifyPeer = true - Libcurl will verify peer certificate
LogInit: - bUseHttpProxy = false - Libcurl will NOT use HTTP proxy
LogInit: - bDontReuseConnections = false - Libcurl will reuse connections
LogInit: - MaxHostConnections = 40 - Libcurl will limit the number of connections to a host
LogInit: - LocalHostAddr = Default
LogInit: - BufferSize = 65536
Second part :
LogInit: WinSock: version 1.1 (2.2), MaxSocks=32767, MaxUdp=65467
LogOnline: OSS: Created online subsystem instance for: NULL
LogOnline: OSS: TryLoadSubsystemAndSetDefault: Loaded subsystem for type [NULL]
LogWindows: Failed to load ‘WinPixGpuCapturer.dll’ (GetLastError=126)
LogWindows: File ‘WinPixGpuCapturer.dll’ does not exist
PixWinPlugin: PIX capture plugin failed to initialize! Check that the process is launched from PIX.
LogConfig: Applying CVar settings from Section [/Script/RenderDocPlugin.RenderDocPluginSettings] File [Engine]
RenderDocPlugin: Display: RenderDoc plugin will not be loaded. Use ‘-AttachRenderDoc’ on the cmd line or enable ‘renderdoc.AutoAttach’ in the plugin settings.
LogHMD: OpenXRHMDModule::InitInstance using DefaultLoader.
LogHMD: Failed to enumerate extensions. Please check that you have a valid OpenXR runtime installed.
LogInit: ExecutableName: UnrealEditor.exe
LogInit: Build: ++UE5+Release-5.3-CL-29314046
LogInit: Engine Version: 5.3.2-29314046+++UE5+Release-5.3
LogInit: Compatible Engine Version: 5.3.0-27405482+++UE5+Release-5.3
LogInit: Net CL: 27405482
LogInit: OS: Windows 10 (21H2) [10.0.19044.3803] (), CPU: 13th Gen Intel(R) Core™ i5-13600KF, GPU: NVIDIA GeForce RTX 2060 SUPER
LogInit: Compiled (64-bit): Nov 3 2023 16:09:16
LogInit: Architecture: x64
LogInit: Compiled with Visual C++: 19.36.32537.00
LogInit: Build Configuration: Development
LogInit: Branch Name: ++UE5+Release-5.3
LogInit: Command Line:
LogInit: Base Directory: E:/epic/UE_5.3/Engine/Binaries/Win64/
LogInit: Allocator: Mimalloc
LogInit: Installed Engine Build: 1
LogInit: This binary is optimized with LTO: no, PGO: no, instrumented for PGO data collection: no
LogDevObjectVersion: Number of dev versions registered: 36
LogDevObjectVersion: Dev-Blueprints (B0D832E4-1F89-4F0D-ACCF-7EB736FD4AA2): 10
LogDevObjectVersion: Dev-Build (E1C64328-A22C-4D53-A36C-8E866417BD8C): 0
LogDevObjectVersion: Dev-Core (375EC13C-06E4-48FB-B500-84F0262A717E): 4
LogDevObjectVersion: Dev-Editor (E4B068ED-F494-42E9-A231-DA0B2E46BB41): 40
LogDevObjectVersion: Dev-Framework (CFFC743F-43B0-4480-9391-14DF171D2073): 37
LogDevObjectVersion: Dev-Mobile (B02B49B5-BB20-44E9-A304-32B752E40360): 3
LogDevObjectVersion: Dev-Networking (A4E4105C-59A1-49B5-A7C5-40C4547EDFEE): 0
LogDevObjectVersion: Dev-Online (39C831C9-5AE6-47DC-9A44-9C173E1C8E7C): 0
LogDevObjectVersion: Dev-Physics (78F01B33-EBEA-4F98-B9B4-84EACCB95AA2): 20
LogDevObjectVersion: Dev-Platform (6631380F-2D4D-43E0-8009-CF276956A95A): 0
LogDevObjectVersion: Dev-Rendering (12F88B9F-8875-4AFC-A67C-D90C383ABD29): 47
LogDevObjectVersion: Dev-Sequencer (7B5AE74C-D270-4C10-A958-57980B212A5A): 13
LogDevObjectVersion: Dev-VR (D7296918-1DD6-4BDD-9DE2-64A83CC13884): 3
LogDevObjectVersion: Dev-LoadTimes (C2A15278-BFE7-4AFE-6C17-90FF531DF755): 1
LogDevObjectVersion: Private-Geometry (6EACA3D4-40EC-4CC1-B786-8BED09428FC5): 3
LogDevObjectVersion: Dev-AnimPhys (29E575DD-E0A3-4627-9D10-D276232CDCEA): 17
LogDevObjectVersion: Dev-Anim (AF43A65D-7FD3-4947-9873-3E8ED9C1BB05): 15
LogDevObjectVersion: Dev-ReflectionCapture (6B266CEC-1EC7-4B8F-A30B-E4D90942FC07): 1
LogDevObjectVersion: Dev-Automation (0DF73D61-A23F-47EA-B727-89E90C41499A): 1
LogDevObjectVersion: FortniteMain (601D1886-AC64-4F84-AA16-D3DE0DEAC7D6): 111
LogDevObjectVersion: FortniteValkyrie (8DBC2C5B-54A7-43E0-A768-FCBB7DA29060): 2
LogDevObjectVersion: FortniteSeason (5B4C06B7-2463-4AF8-805B-BF70CDF5D0DD): 10
LogDevObjectVersion: FortniteRelease (E7086368-6B23-4C58-8439-1B7016265E91): 11
LogDevObjectVersion: Dev-Enterprise (9DFFBCD6-494F-0158-E221-12823C92A888): 10
LogDevObjectVersion: Dev-Niagara (F2AED0AC-9AFE-416F-8664-AA7FFA26D6FC): 1
LogDevObjectVersion: Dev-Destruction (174F1F0B-B4C6-45A5-B13F-2EE8D0FB917D): 10
LogDevObjectVersion: Dev-Physics-Ext (35F94A83-E258-406C-A318-09F59610247C): 41
LogDevObjectVersion: Dev-PhysicsMaterial-Chaos (B68FC16E-8B1B-42E2-B453-215C058844FE): 1
LogDevObjectVersion: Dev-CineCamera (B2E18506-4273-CFC2-A54E-F4BB758BBA07): 1
LogDevObjectVersion: Dev-VirtualProduction (64F58936-FD1B-42BA-BA96-7289D5D0FA4E): 1
LogDevObjectVersion: UE5-Main (697DD581-E64F-41AB-AA4A-51ECBEB7B628): 118
LogDevObjectVersion: UE5-Release (D89B5E42-24BD-4D46-8412-ACA8DF641779): 47
LogDevObjectVersion: UE5-PrivateFrosty (59DA5D52-1232-4948-B878-597870B8E98B): 8
LogDevObjectVersion: UE5-Dev-Cooker (26075A32-730F-4708-88E9-8C32F1599D05): 0
LogDevObjectVersion: Dev-MediaFramework (6F0ED827-A609-4895-9C91-998D90180EA4): 2
LogDevObjectVersion: UE5-Dev-LWCRendering (30D58BE3-95EA-4282-A6E3-B159D8EBB06A): 1
LogInit: Presizing for max 25165824 objects, including 0 objects not considered by GC, pre-allocating 0 bytes for permanent pool.
LogInit: Object subsystem initialized
LogConfig: Set CVar [[con.DebugEarlyDefault:1]]
LogConfig: CVar [[con.DebugLateDefault:1]] deferred - dummy variable created
LogConfig: CVar [[con.DebugLateCheat:1]] deferred - dummy variable created
LogConfig: CVar [[LogNamedEventFilters:Frame *]] deferred - dummy variable created
LogConfig: Set CVar [[r.ShaderDevelopmentMode:1]]
LogConfig: Set CVar [[r.setres:1280x720]]
LogConfig: CVar [[framepro.ScopeMinTimeMicroseconds:10]] deferred - dummy variable created
LogConfig: Set CVar [[fx.NiagaraAllowRuntimeScalabilityChanges:1]]
LogConfig: CVar [[QualityLevelMapping:high]] deferred - dummy variable created
LogConfig: CVar [[r.Occlusion.SingleRHIThreadStall:1]] deferred - dummy variable created
LogConfig: Set CVar [[r.Shadow.DetectVertexShaderLayerAtRuntime:1]]
LogConfig: Set CVar [[r.VSync:0]]
LogConfig: Set CVar [[r.RHICmdBypass:0]]
LogConfig: Applying CVar settings from Section [/Script/Engine.RendererSettings] File [Engine]
LogConfig: CVar [[VisualizeCalibrationColorMaterialPath:/Engine/EngineMaterials/PPM_DefaultCalibrationColor.PPM_DefaultCalibrationColor]] deferred - dummy variable created
LogConfig: CVar [[VisualizeCalibrationGrayscaleMaterialPath:/Engine/EngineMaterials/PPM_DefaultCalibrationGrayscale.PPM_DefaultCalibrationGrayscale]] deferred - dummy variable created
LogConfig: Set CVar [[r.GPUCrashDebugging:0]]
LogConfig: CVar [[MaxSkinBones:(Default=65536,PerPlatform=((“Mobile”, 256)))]] deferred - dummy variable created
LogConfig: CVar [[r.DefaultFeature.AntiAliasing:2]] deferred - dummy variable created
LogConfig: CVar [[r.MobileMSAA:1]] deferred - dummy variable created
LogConfig: Set CVar [[r.ForwardShading:0]]
LogConfig: Set CVar [[r.Mobile.UseHWsRGBEncoding:1]]
LogConfig: Set CVar [[r.MobileHDR:0]]
LogConfig: Set CVar [[r.Mobile.EnableStaticAndCSMShadowReceivers:0]]
LogConfig: Set CVar [[r.Mobile.AllowDistanceFieldShadows:0]]
LogConfig: Set CVar [[r.Mobile.AllowMovableDirectionalLights:0]]
LogConfig: CVar [[r.MobileNumDynamicPointLights:0]] deferred - dummy variable created
LogConfig: CVar [[r.MobileDynamicPointLightsUseStaticBranch:0]] deferred - dummy variable created
LogConfig: Set CVar [[r.AntiAliasingMethod:2]]
LogConfig: Set CVar [[r.Mobile.AntiAliasing:0]]
LogConfig: Set CVar [[r.TemporalAA.Upsampling:1]]
LogConfig: Set CVar [[r.CustomDepthTemporalAAJitter:0]]
LogConfig: Set CVar [[r.ReflectionMethod:1]]
LogConfig: Set CVar [[r.RayTracing.Skylight:0]]
LogConfig: Set CVar [[r.RayTracing:0]]
LogConfig: Set CVar [[r.SeparateTranslucency:0]]
LogConfig: Set CVar [[r.CustomDepth:0]]
LogConfig: Set CVar [[r.MSAACount:1]]
LogConfig: Set CVar [[r.Nanite.ProjectEnabled:1]]
LogConfig: Set CVar [[r.AllowStaticLighting:0]]
LogConfig: Set CVar [[r.DBuffer:0]]
LogConfig: Set CVar [[r.VertexFoggingForOpaque:0]]
LogConfig: Set CVar [[r.DefaultFeature.Bloom:0]]
LogConfig: Set CVar [[r.DefaultFeature.AmbientOcclusion:0]]
LogConfig: Set CVar [[r.DefaultFeature.AmbientOcclusionStaticFraction:0]]
LogConfig: Set CVar [[r.DefaultFeature.AutoExposure:0]]
LogConfig: Set CVar [[r.DefaultFeature.MotionBlur:0]]
LogConfig: Set CVar [[r.Shadow.UnbuiltPreviewInGame:1]]
LogConfig: Set CVar [[r.EarlyZPass:1]]
LogConfig: Set CVar [[r.GenerateMeshDistanceFields:1]]
LogConfig: Set CVar [[r.DynamicGlobalIlluminationMethod:1]]
LogConfig: Set CVar [[r.VelocityOutputPass:2]]
LogConfig: Set CVar [[r.Shaders.RemoveUnusedInterpolators:1]]
LogConfig: Applying CVar settings from Section [/Script/Engine.RendererOverrideSettings] File [Engine]
LogConfig: Applying CVar settings from Section [/Script/Engine.StreamingSettings] File [Engine]
LogConfig: Set CVar [[s.MinBulkDataSizeForAsyncLoading:131072]]
LogConfig: Set CVar [[s.AsyncLoadingThreadEnabled:1]]
LogConfig: Set CVar [[s.EventDrivenLoaderEnabled:1]]
LogConfig: Set CVar [[s.WarnIfTimeLimitExceeded:0]]
LogConfig: Set CVar [[s.TimeLimitExceededMultiplier:1.5]]
LogConfig: Set CVar [[s.TimeLimitExceededMinTime:0.005]]
LogConfig: Set CVar [[s.UseBackgroundLevelStreaming:1]]
LogConfig: Set CVar [[s.PriorityAsyncLoadingExtraTime:15.0]]
LogConfig: Set CVar [[s.LevelStreamingActorsUpdateTimeLimit:5.0]]
LogConfig: Set CVar [[s.PriorityLevelStreamingActorsUpdateExtraTime:5.0]]
LogConfig: Set CVar [[s.LevelStreamingComponentsRegistrationGranularity:10]]
LogConfig: Set CVar [[s.UnregisterComponentsTimeLimit:1.0]]
LogConfig: Set CVar [[s.LevelStreamingComponentsUnregistrationGranularity:5]]
LogConfig: CVar [[s.MaxPackageSummarySize:16384]] deferred - dummy variable created
LogConfig: Set CVar [[s.FlushStreamingOnExit:1]]
LogConfig: CVar [[FixedBootOrder:/Script/Engine/Default__SoundBase]] deferred - dummy variable created
LogConfig: CVar [[FixedBootOrder:/Script/Engine/Default__MaterialInterface]] deferred - dummy variable created
LogConfig: CVar [[FixedBootOrder:/Script/Engine/Default__DeviceProfileManager]] deferred - dummy variable created
LogConfig: Applying CVar settings from Section [/Script/Engine.GarbageCollectionSettings] File [Engine]
LogConfig: Set CVar [[gc.MaxObjectsNotConsideredByGC:1]]
LogConfig: Set CVar [[gc.SizeOfPermanentObjectPool:0]]
LogConfig: Set CVar [[gc.FlushStreamingOnGC:0]]
LogConfig: Set CVar [[gc.NumRetriesBeforeForcingGC:10]]
LogConfig: Set CVar [[gc.AllowParallelGC:1]]
LogConfig: Set CVar [[gc.TimeBetweenPurgingPendingKillObjects:61.1]]
LogConfig: Set CVar [[gc.MaxObjectsInEditor:25165824]]
LogConfig: Set CVar [[gc.IncrementalBeginDestroyEnabled:1]]
LogConfig: Set CVar [[gc.CreateGCClusters:1]]
LogConfig: Set CVar [[gc.MinGCClusterSize:5]]
LogConfig: Set CVar [[gc.AssetClustreringEnabled:0]]
LogConfig: Set CVar [[gc.ActorClusteringEnabled:0]]
LogConfig: Set CVar [[gc.UseDisregardForGCOnDedicatedServers:0]]
LogConfig: Set CVar [[gc.MultithreadedDestructionEnabled:1]]
LogConfig: Set CVar [[gc.VerifyUObjectsAreNotFGCObjects:0]]
LogConfig: Set CVar [[gc.PendingKillEnabled:1]]
LogConfig: Applying CVar settings from Section [/Script/Engine.NetworkSettings] File [Engine]
LogConfig: CVar [[NetworkEmulationProfiles:(ProfileName=“Average”,ToolTip=“Simulates average internet conditions”)]] deferred - dummy variable created
LogConfig: CVar [[NetworkEmulationProfiles:(ProfileName=“Bad”,ToolTip=“Simulates laggy internet conditions”)]] deferred - dummy variable created
LogConfig: Applying CVar settings from Section [/Script/UnrealEd.CookerSettings] File [Engine]
LogConfig: CVar [[DefaultASTCQualityBySpeed:2]] deferred - dummy variable created
LogConfig: CVar [[DefaultASTCQualityBySize:3]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:WidgetBlueprint]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:GroupActor]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:MetaData]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:ObjectRedirector]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:NavMeshRenderingComponent]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:ReflectionCaptureComponent]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:TextRenderComponent]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:Font]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:InterpCurveEdSetup]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:MaterialExpression]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:NiagaraEmitter]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:NiagaraScript]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:ParticleEmitter]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:ParticleLODLevel]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:ParticleModule]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:SubUVAnimation]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:SoundNode]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedServer:GameplayEffectUIData]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedClient:WidgetBlueprint]] deferred - dummy variable created
Third part :
LogConfig: CVar [[ClassesExcludedOnDedicatedClient:GroupActor]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedClient:MetaData]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedClient:ObjectRedirector]] deferred - dummy variable created
LogConfig: CVar [[ClassesExcludedOnDedicatedClient:InterpCurveEdSetup]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.AllowStaticLighting]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.MaterialEditor.LWCTruncateMode]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.GBuffer]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.VelocityOutputPass]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.SelectiveBasePassOutputs]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.DBuffer]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.Shaders.Symbols]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.Shaders.GenerateSymbols]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.Shaders.WriteSymbols]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.Shaders.AllowUniqueSymbols]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.Shaders.ExtraData]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.Shaders.Optimize]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.CompileShadersForDevelopment]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.MobileHDR]] deferred - dummy variable created
LogConfig: CVar [[VersionedIntRValues:r.UsePreExposure]] deferred - dummy variable created
LogConfig: Applying CVar settings from Section [ViewDistanceQuality@3] File [Scalability]
LogConfig: Set CVar [[r.SkeletalMeshLODBias:0]]
LogConfig: Set CVar [[r.ViewDistanceScale:1.0]]
LogConfig: Applying CVar settings from Section [AntiAliasingQuality@3] File [Scalability]
LogConfig: Set CVar [[r.FXAA.Quality:4]]
LogConfig: Set CVar [[r.TemporalAA.Quality:2]]
LogConfig: Set CVar [[r.TSR.History.R11G11B10:1]]
LogConfig: Set CVar [[r.TSR.History.ScreenPercentage:200]]
LogConfig: Set CVar [[r.TSR.History.UpdateQuality:3]]
LogConfig: Set CVar [[r.TSR.ShadingRejection.Flickering:1]]
LogConfig: Set CVar [[r.TSR.ShadingRejection.TileOverscan:3]]
LogConfig: CVar [[r.TSR.Velocity.Extrapolation:1]] deferred - dummy variable created
LogConfig: Set CVar [[r.TSR.RejectionAntiAliasingQuality:2]]
LogConfig: Applying CVar settings from Section [ShadowQuality@3] File [Scalability]
LogConfig: Set CVar [[r.LightFunctionQuality:1]]
LogConfig: Set CVar [[r.ShadowQuality:5]]
LogConfig: Set CVar [[r.Shadow.CSM.MaxCascades:10]]
LogConfig: Set CVar [[r.Shadow.MaxResolution:2048]]
LogConfig: Set CVar [[r.Shadow.MaxCSMResolution:2048]]
LogConfig: Set CVar [[r.Shadow.RadiusThreshold:0.01]]
LogConfig: Set CVar [[r.Shadow.DistanceScale:1.0]]
LogConfig: Set CVar [[r.Shadow.CSM.TransitionScale:1.0]]
LogConfig: Set CVar [[r.Shadow.PreShadowResolutionFactor:1.0]]
LogConfig: Set CVar [[r.DistanceFieldShadowing:1]]
LogConfig: Set CVar [[r.VolumetricFog:1]]
LogConfig: Set CVar [[r.VolumetricFog.GridPixelSize:8]]
LogConfig: Set CVar [[r.VolumetricFog.GridSizeZ:128]]
LogConfig: Set CVar [[r.VolumetricFog.HistoryMissSupersampleCount:4]]
LogConfig: Set CVar [[r.LightMaxDrawDistanceScale:1]]
LogConfig: Set CVar [[r.CapsuleShadows:1]]
LogConfig: Set CVar [[r.Shadow.Virtual.MaxPhysicalPages:4096]]
LogConfig: Set CVar [[r.Shadow.Virtual.ResolutionLodBiasDirectional:-1.5]]
LogConfig: Set CVar [[r.Shadow.Virtual.ResolutionLodBiasDirectionalMoving:-1.5]]
LogConfig: Set CVar [[r.Shadow.Virtual.ResolutionLodBiasLocal:0.0]]
LogConfig: Set CVar [[r.Shadow.Virtual.ResolutionLodBiasLocalMoving:1.0]]
LogConfig: Set CVar [[r.Shadow.Virtual.SMRT.RayCountDirectional:8]]
LogConfig: Set CVar [[r.Shadow.Virtual.SMRT.SamplesPerRayDirectional:4]]
LogConfig: Set CVar [[r.Shadow.Virtual.SMRT.RayCountLocal:8]]
LogConfig: Set CVar [[r.Shadow.Virtual.SMRT.SamplesPerRayLocal:4]]
LogConfig: Applying CVar settings from Section [GlobalIlluminationQuality@3] File [Scalability]
LogConfig: Set CVar [[r.DistanceFieldAO:1]]
LogConfig: Set CVar [[r.AOQuality:2]]
LogConfig: Set CVar [[r.Lumen.DiffuseIndirect.Allow:1]]
LogConfig: Set CVar [[r.LumenScene.Radiosity.ProbeSpacing:4]]
LogConfig: Set CVar [[r.LumenScene.Radiosity.HemisphereProbeResolution:4]]
LogConfig: Set CVar [[r.Lumen.TraceMeshSDFs.Allow:1]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.RadianceCache.ProbeResolution:32]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.RadianceCache.NumProbesToTraceBudget:300]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.DownsampleFactor:16]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.TracingOctahedronResolution:8]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.IrradianceFormat:0]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.StochasticInterpolation:0]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.FullResolutionJitterWidth:1]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.TwoSidedFoliageBackfaceDiffuse:1]]
LogConfig: Set CVar [[r.Lumen.ScreenProbeGather.ScreenTraces.HZBTraversal.FullResDepth:1]]
LogConfig: Set CVar [[r.Lumen.TranslucencyVolume.GridPixelSize:32]]
LogConfig: Set CVar [[r.Lumen.TranslucencyVolume.TraceFromVolume:1]]
LogConfig: Set CVar [[r.Lumen.TranslucencyVolume.TracingOctahedronResolution:3]]
LogConfig: Set CVar [[r.Lumen.TranslucencyVolume.RadianceCache.ProbeResolution:8]]
LogConfig: Set CVar [[r.Lumen.TranslucencyVolume.RadianceCache.NumProbesToTraceBudget:200]]
LogConfig: Applying CVar settings from Section [ReflectionQuality@3] File [Scalability]
LogConfig: Set CVar [[r.SSR.Quality:3]]
LogConfig: Set CVar [[r.SSR.HalfResSceneColor:0]]
LogConfig: Set CVar [[r.Lumen.Reflections.Allow:1]]
LogConfig: Set CVar [[r.Lumen.Reflections.DownsampleFactor:1]]
LogConfig: Set CVar [[r.Lumen.Reflections.MaxRoughnessToTraceForFoliage:0.4]]
LogConfig: Set CVar [[r.Lumen.Reflections.ScreenSpaceReconstruction.TonemapStrength:0]]
LogConfig: Set CVar [[r.Lumen.TranslucencyReflections.FrontLayer.Allow:1]]
LogConfig: Set CVar [[r.Lumen.TranslucencyReflections.FrontLayer.Enable:0]]
LogConfig: Applying CVar settings from Section [PostProcessQuality@3] File [Scalability]
LogConfig: Set CVar [[r.MotionBlurQuality:4]]
LogConfig: Set CVar [[r.MotionBlur.HalfResGather:0]]
LogConfig: Set CVar [[r.AmbientOcclusionMipLevelFactor:0.4]]
LogConfig: Set CVar [[r.AmbientOcclusionMaxQuality:100]]
LogConfig: Set CVar [[r.AmbientOcclusionLevels:-1]]
LogConfig: Set CVar [[r.AmbientOcclusionRadiusScale:1.0]]
LogConfig: Set CVar [[r.DepthOfFieldQuality:2]]
LogConfig: Set CVar [[r.RenderTargetPoolMin:400]]
LogConfig: Set CVar [[r.LensFlareQuality:2]]
LogConfig: Set CVar [[r.SceneColorFringeQuality:1]]
LogConfig: Set CVar [[r.EyeAdaptationQuality:2]]
LogConfig: Set CVar [[r.BloomQuality:5]]
LogConfig: Set CVar [[r.Bloom.ScreenPercentage:50.000]]
LogConfig: Set CVar [[r.FastBlurThreshold:100]]
LogConfig: Set CVar [[r.Upscale.Quality:3]]
LogConfig: Set CVar [[r.LightShaftQuality:1]]
LogConfig: Set CVar [[r.Filter.SizeScale:1]]
LogConfig: Set CVar [[r.Tonemapper.Quality:5]]
LogConfig: Set CVar [[r.DOF.Gather.ResolutionDivisor:2 ; lower gathering resolution]]
LogConfig: Set CVar [[r.DOF.Gather.AccumulatorQuality:1 ; higher gathering accumulator quality]]
LogConfig: Set CVar [[r.DOF.Gather.PostfilterMethod:1 ; Median3x3 postfilering method]]
LogConfig: Set CVar [[r.DOF.Gather.EnableBokehSettings:0 ; no bokeh simulation when gathering]]
LogConfig: Set CVar [[r.DOF.Gather.RingCount:4 ; medium number of samples when gathering]]
LogConfig: Set CVar [[r.DOF.Scatter.ForegroundCompositing:1 ; additive foreground scattering]]
LogConfig: Set CVar [[r.DOF.Scatter.BackgroundCompositing:2 ; additive background scattering]]
LogConfig: Set CVar [[r.DOF.Scatter.EnableBokehSettings:1 ; bokeh simulation when scattering]]
LogConfig: Set CVar [[r.DOF.Scatter.MaxSpriteRatio:0.1 ; only a maximum of 10% of scattered bokeh]]
LogConfig: Set CVar [[r.DOF.Recombine.Quality:1 ; cheap slight out of focus]]
LogConfig: Set CVar [[r.DOF.Recombine.EnableBokehSettings:0 ; no bokeh simulation on slight out of focus]]
LogConfig: Set CVar [[r.DOF.TemporalAAQuality:1 ; more stable temporal accumulation]]
LogConfig: Set CVar [[r.DOF.Kernel.MaxForegroundRadius:0.025]]
LogConfig: Set CVar [[r.DOF.Kernel.MaxBackgroundRadius:0.025]]
LogConfig: Applying CVar settings from Section [TextureQuality@3] File [Scalability]
LogConfig: Set CVar [[r.Streaming.MipBias:0]]
LogConfig: Set CVar [[r.Streaming.AmortizeCPUToGPUCopy:0]]
LogConfig: Set CVar [[r.Streaming.MaxNumTexturesToStreamPerFrame:0]]
LogConfig: Set CVar [[r.Streaming.Boost:1]]
LogConfig: Set CVar [[r.MaxAnisotropy:8]]
LogConfig: Set CVar [[r.VT.MaxAnisotropy:8]]
LogConfig: Set CVar [[r.Streaming.LimitPoolSizeToVRAM:0]]
LogConfig: Set CVar [[r.Streaming.PoolSize:1000]]
LogConfig: Set CVar [[r.Streaming.MaxEffectiveScreenSize:0]]
LogConfig: Applying CVar settings from Section [EffectsQuality@3] File [Scalability]
LogConfig: Set CVar [[r.TranslucencyLightingVolumeDim:64]]
LogConfig: Set CVar [[r.RefractionQuality:2]]
LogConfig: Set CVar [[r.SceneColorFormat:4]]
LogConfig: Set CVar [[r.DetailMode:2]]
LogConfig: Set CVar [[r.TranslucencyVolumeBlur:1]]
LogConfig: Set CVar [[r.MaterialQualityLevel:1 ; High quality]]
LogConfig: Set CVar [[r.SSS.Scale:1]]
LogConfig: Set CVar [[r.SSS.SampleSet:2]]
LogConfig: Set CVar [[r.SSS.Quality:1]]
LogConfig: Set CVar [[r.SSS.HalfRes:0]]
LogConfig: Set CVar [[r.SSGI.Quality:3]]
LogConfig: Set CVar [[r.EmitterSpawnRateScale:1.0]]
LogConfig: Set CVar [[r.ParticleLightQuality:2]]
LogConfig: Set CVar [[r.SkyAtmosphere.AerialPerspectiveLUT.FastApplyOnOpaque:1 ; Always have FastSkyLUT 1 in this case to avoid wrong sky]]
LogConfig: Set CVar [[r.SkyAtmosphere.AerialPerspectiveLUT.SampleCountMaxPerSlice:4]]
LogConfig: Set CVar [[r.SkyAtmosphere.AerialPerspectiveLUT.DepthResolution:16.0]]
LogConfig: Set CVar [[r.SkyAtmosphere.FastSkyLUT:1]]
LogConfig: Set CVar [[r.SkyAtmosphere.FastSkyLUT.SampleCountMin:4.0]]
LogConfig: Set CVar [[r.SkyAtmosphere.FastSkyLUT.SampleCountMax:128.0]]
LogConfig: Set CVar [[r.SkyAtmosphere.SampleCountMin:4.0]]
LogConfig: Set CVar [[r.SkyAtmosphere.SampleCountMax:128.0]]
LogConfig: Set CVar [[r.SkyAtmosphere.TransmittanceLUT.UseSmallFormat:0]]
LogConfig: Set CVar [[r.SkyAtmosphere.TransmittanceLUT.SampleCount:10.0]]
LogConfig: Set CVar [[r.SkyAtmosphere.MultiScatteringLUT.SampleCount:15.0]]
LogConfig: Set CVar [[r.SkyLight.RealTimeReflectionCapture:1]]
LogConfig: Set CVar [[fx.Niagara.QualityLevel:3]]
LogConfig: Set CVar [[r.Refraction.OffsetQuality:1]]
LogConfig: Applying CVar settings from Section [FoliageQuality@3] File [Scalability]
LogConfig: Set CVar [[foliage.DensityScale:1.0]]
LogConfig: Set CVar [[grass.DensityScale:1.0]]
LogConfig: Applying CVar settings from Section [ShadingQuality@3] File [Scalability]
LogConfig: Set CVar [[r.HairStrands.SkyLighting.IntegrationType:2]]
LogConfig: Set CVar [[r.HairStrands.SkyAO.SampleCount:4]]
LogConfig: Set CVar [[r.HairStrands.Visibility.MSAA.SamplePerPixel:4]]
LogConfig: Set CVar [[r.AnisotropicMaterials:1]]
LogRHI: Using Default RHI: D3D11
LogRHI: Using Highest Feature Level of D3D11: SM5
LogRHI: Loading RHI module D3D11RHI
LogD3D11RHI: Loaded GFSDK_Aftermath_Lib.x64.dll
LogRHI: Checking if RHI D3D11 with Feature Level SM5 is supported by your system.
LogD3D11RHI: D3D11 min allowed feature level: 11_0
LogD3D11RHI: D3D11 max allowed feature level: 11_1
LogD3D11RHI: D3D11 adapters:
LogD3D11RHI: Testing D3D11 Adapter 0:
LogD3D11RHI: Description : NVIDIA GeForce RTX 2060 SUPER
LogD3D11RHI: VendorId : 10de
LogD3D11RHI: DeviceId : 1f06
LogD3D11RHI: SubSysId : 87481043
LogD3D11RHI: Revision : 00a1
LogD3D11RHI: DedicatedVideoMemory : 8408530944 bytes
LogD3D11RHI: DedicatedSystemMemory : 0 bytes
LogD3D11RHI: SharedSystemMemory : 17095618560 bytes
LogD3D11RHI: AdapterLuid : 0 74727
LogD3D11RHI: 0. ‘NVIDIA GeForce RTX 2060 SUPER’ (Feature Level 11_1)
LogD3D11RHI: 8019/0/16303 MB DedicatedVideo/DedicatedSystem/SharedSystem, Outputs:1, VendorId:0x10de
LogD3D11RHI: Testing D3D11 Adapter 1:
LogD3D11RHI: Description : Microsoft Basic Render Driver
LogD3D11RHI: VendorId : 1414
LogD3D11RHI: DeviceId : 008c
LogD3D11RHI: SubSysId : 0000
LogD3D11RHI: Revision : 0000
LogD3D11RHI: DedicatedVideoMemory : 0 bytes
LogD3D11RHI: AdapterLuid : 0 77711
LogD3D11RHI: 1. ‘Microsoft Basic Render Driver’ (Feature Level 11_1)
LogD3D11RHI: 0/0/16303 MB DedicatedVideo/DedicatedSystem/SharedSystem, Outputs:0, VendorId:0x1414
LogD3D11RHI: Chosen D3D11 Adapter:
LogRHI: RHI D3D11 with Feature Level SM5 is supported and will be used.
LogInit: Selected Device Profile: [WindowsEditor]
LogHAL: Display: Platform has ~ 32 GB [34191237120 / 34359738368 / 32], which maps to Largest [LargestMinGB=32, LargerMinGB=12, DefaultMinGB=8, SmallerMinGB=6, SmallestMinGB=0)
LogDeviceProfileManager: Going up to parent DeviceProfile [Windows]
LogConfig: Applying CVar settings from Section [Startup] File […/…/…/Engine/Config/ConsoleVariables.ini]
LogConfig: Set CVar [[r.DumpShaderDebugInfo:2]]
LogConfig: Set CVar [[p.chaos.AllowCreatePhysxBodies:1]]
LogConfig: Set CVar [[fx.SkipVectorVMBackendOptimizations:1]]
LogConfig: Applying CVar settings from Section [ConsoleVariables] File [Engine]
LogConfig: Applying CVar settings from Section [ConsoleVariables] File [E:/loads/LumaAIStarterProject_5.3_2023_10_26/Saved/Config/WindowsEditor/Editor.ini]
LogInit: Computer: DESKTOP-NCTA41U
LogInit: User: убийцаа
LogInit: CPU Page size=4096, Cores=14
LogInit: High frequency timer resolution =10.000000 MHz
LogMemory: Memory total: Physical=31.8GB (32GB approx)
LogMemory: Platform Memory Stats for WindowsEditor
LogMemory: Process Physical Memory: 511.94 MB used, 520.87 MB peak
LogMemory: Process Virtual Memory: 516.48 MB used, 519.47 MB peak
LogMemory: Physical Memory: 6989.79 MB used, 25617.52 MB free, 32607.30 MB total
LogMemory: Virtual Memory: 9880.50 MB used, 30918.80 MB free, 40799.30 MB total
LogCsvProfiler: Display: Metadata set : extradevelopmentmemorymb=“0”
LogWindows: WindowsPlatformFeatures enabled
LogInit: Physics initialised using underlying interface: Chaos
LogInit: Using OS detected language (uk-UA).
LogInit: Using OS detected locale (uk-UA).
LogTextLocalizationManager: No localization for ‘uk-UA’ exists, so ‘en’ will be used for the language.
LogInit: Setting process to per monitor DPI aware
LogWindowsTextInputMethodSystem: Available input methods:
LogWindowsTextInputMethodSystem: - Українська (Україна) - (Keyboard).
LogWindowsTextInputMethodSystem: - Англійська (США) - (Keyboard).
LogWindowsTextInputMethodSystem: Activated input method: Українська (Україна) - (Keyboard).
LogSlate: New Slate User Created. Platform User Id 0, User Index 0, Is Virtual User: 0
LogSlate: Slate User Registered. User Index 0, Is Virtual User: 0
LogWindows: Attached monitors:
LogWindows: resolution: 1920x1080, work area: (0, 0) → (1920, 1040), device: ‘\.\DISPLAY1’ [PRIMARY]
LogWindows: Found 1 attached monitors.
LogWindows: Gathering driver information using Windows Setup API
LogRHI: RHI Adapter Info:
LogRHI: Name: NVIDIA GeForce RTX 2060 SUPER
LogRHI: Driver Version: 537.58 (internal:31.0.15.3758, unified:537.58)
LogRHI: Driver Date: 10-4-2023
LogD3D11RHI: Creating new Direct3DDevice
LogD3D11RHI: GPU DeviceId: 0x1f06 (for the marketing name, search the web for “GPU Device Id”)
LogRHI: Texture pool is 5613 MB (70% of 8019 MB)
LogD3D11RHI: Creating D3DDevice using adapter:
LogD3D11RHI: RHI has support for 64 bit atomics
LogD3D11RHI: Async texture creation enabled
LogD3D11RHI: D3D11_MAP_WRITE_NO_OVERWRITE for dynamic buffer SRVs is supported
LogD3D11RHI: Array index from any shader is supported
LogVRS: Current RHI does not support Variable Rate Shading
LogD3D11RHI: GPU Timing Frequency: 1000.000000 (Debug: 2 2)
LogTurnkeySupport: Running Turnkey SDK detection: ’ -ScriptsForProject=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” Turnkey -utf8output -WaitForUATMutex -command=VerifySdk -ReportFilename=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyReport_0.log” -log=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyLog_0.log” -project=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” -platform=all’
LogMonitoredProcess: Running Serialized UAT: [ cmd.exe /c ““E:/epic/UE_5.3/Engine/Build/BatchFiles/RunUAT.bat” -ScriptsForProject=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” Turnkey -utf8output -WaitForUATMutex -command=VerifySdk -ReportFilename=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyReport_0.log” -log=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyLog_0.log” -project=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” -platform=all” ]
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatASTC
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatDXT
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatETC2
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatIntelISPCTexComp
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatUncompressed
LogTextureFormatOodle: Display: Oodle Texture TFO init; latest sdk version = 2.9.10
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.5.dll
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.6.dll
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.7.dll
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.8.dll
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.9.dll
LogTextureFormatOodle: Display: Oodle Texture loading DLL: oo2tex_win64_2.9.10.dll
LogTextureFormatManager: Display: Loaded Base TextureFormat: TextureFormatOodle
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_ASTC’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_DXT’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_ETC2’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘AndroidClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_ASTCClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_DXTClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_ETC2Client’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_Multi’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Android_MultiClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘IOS’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘IOSClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Linux’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘LinuxEditor’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘LinuxServer’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘LinuxClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘LinuxArm64’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘LinuxArm64Server’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘LinuxArm64Client’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Mac’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘MacEditor’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘MacServer’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘MacClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘TVOS’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘TVOSClient’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘Windows’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘WindowsEditor’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘WindowsServer’
LogTargetPlatformManager: Display: Loaded TargetPlatform ‘WindowsClient’
LogTargetPlatformManager: Display: Building Assets For WindowsEditor
LogAudioDebug: Display: Lib vorbis DLL was dynamically loaded.
LogTargetPlatformManager: Unable to find shader format SF_METAL from hinted modules, loading all potential format modules to find it
LogTargetPlatformManager: Loaded format module MetalShaderFormat
4 part :
LogTargetPlatformManager: SF_METAL
LogTargetPlatformManager: SF_METAL_MRT
LogTargetPlatformManager: SF_METAL_TVOS
LogTargetPlatformManager: SF_METAL_MRT_TVOS
LogTargetPlatformManager: SF_METAL_SM5
LogTargetPlatformManager: SF_METAL_SM6
LogTargetPlatformManager: SF_METAL_SIM
LogTargetPlatformManager: SF_METAL_MACES3_1
LogTargetPlatformManager: SF_METAL_MRT_MAC
LogTargetPlatformManager: Loaded format module ShaderFormatD3D
LogTargetPlatformManager: PCD3D_SM6
LogTargetPlatformManager: PCD3D_SM5
LogTargetPlatformManager: PCD3D_ES31
LogTargetPlatformManager: Loaded format module ShaderFormatOpenGL
LogTargetPlatformManager: GLSL_150_ES31
LogTargetPlatformManager: GLSL_ES3_1_ANDROID
LogTargetPlatformManager: Loaded format module ShaderFormatVectorVM
LogTargetPlatformManager: VVM_1_0
LogTargetPlatformManager: Loaded format module VulkanShaderFormat
LogTargetPlatformManager: SF_VULKAN_SM5
LogTargetPlatformManager: SF_VULKAN_ES31_ANDROID
LogTargetPlatformManager: SF_VULKAN_SM5_ANDROID
LogTargetPlatformManager: SF_VULKAN_SM6
LogRendererCore: Ray tracing is disabled. Reason: disabled through project setting (r.RayTracing=0).
LogDerivedDataCache: Display: Memory: Max Cache Size: -1 MB
LogDerivedDataCache: FDerivedDataBackendGraph: Pak pak cache file …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/DerivedDataCache/DDC.ddp not found, will not use a pak cache.
LogDerivedDataCache: Unable to find inner node Pak for hierarchy Hierarchy.
LogDerivedDataCache: FDerivedDataBackendGraph: CompressedPak pak cache file …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/DerivedDataCache/Compressed.ddp not found, will not use a pak cache.
LogDerivedDataCache: Unable to find inner node CompressedPak for hierarchy Hierarchy.
LogDerivedDataCache: Display: …/…/…/Engine/DerivedDataCache/Compressed.ddp: Opened pak cache for reading. (2383 MiB)
LogDerivedDataCache: FDerivedDataBackendGraph: EnterprisePak pak cache file …/…/…/Enterprise/DerivedDataCache/Compressed.ddp not found, will not use a pak cache.
LogDerivedDataCache: Unable to find inner node EnterprisePak for hierarchy Hierarchy.
LogDerivedDataCache: C:/Users/убийцаа/AppData/Local/UnrealEngine/Common/DerivedDataCache: Speed tests took 0.00 seconds.
LogDerivedDataCache: Display: C:/Users/убийцаа/AppData/Local/UnrealEngine/Common/DerivedDataCache: Performance: Latency=0.01ms. RandomReadSpeed=4066.87MBs, RandomWriteSpeed=633.35MBs. Assigned SpeedClass ‘Local’
LogDerivedDataCache: Local: Using data cache path C:/Users/убийцаа/AppData/Local/UnrealEngine/Common/DerivedDataCache: Writable
LogDerivedDataCache: Shared: Disabled because no path is configured.
LogDerivedDataCache: Unable to find inner node Shared for hierarchy Hierarchy.
LogDerivedDataCache: Cloud: Disabled because Host is set to ‘None’
LogDerivedDataCache: Unable to find inner node Cloud for hierarchy Hierarchy.
LogShaderCompilers: Guid format shader working directory is -8 characters bigger than the processId version (…/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/Shaders/WorkingDirectory/4252/).
LogShaderCompilers: Cleaned the shader compiler working directory ‘C:/Users/убийцаа/AppData/Local/Temp/UnrealShaderWorkingDir/18E0B98F47526B9499D0A1AFC1F9D46B/’.
LogXGEController: Cannot use XGE Controller as Incredibuild is not installed on this machine.
LogShaderCompilers: Display: Using Local Shader Compiler with 10 workers.
LogShaders: InitializeShaderTypes() begin
LogShaders: Shader directory mapping /Engine → …/…/…/Engine/Shaders
LogShaders: Shader directory mapping /ShaderAutogen → E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/ShaderAutogen
LogShaders: Shader directory mapping /Plugin/Water → …/…/…/Engine/Plugins/Experimental/Water/Shaders
LogShaders: Shader directory mapping /Plugin/CesiumForUnreal → …/…/…/Engine/Plugins/Marketplace/CesiumForUnreal/Shaders
LogShaders: Shader directory mapping /Plugin/GLTFExporter → …/…/…/Engine/Plugins/Enterprise/GLTFExporter/Shaders
LogShaders: Shader directory mapping /Plugin/ExrReaderShaders → …/…/…/Engine/Plugins/Media/ImgMedia/Shaders
LogShaders: Shader directory mapping /Plugin/WmfMedia → …/…/…/Engine/Plugins/Media/WmfMedia/Shaders
LogShaders: Shader directory mapping /Plugin/FX/Niagara → …/…/…/Engine/Plugins/FX/Niagara/Shaders
LogTurnkeySupport: Completed SDK detection: ExitCode = 0
LogShaders: InitializeShaderTypes() end
LogShaderCompilers: Display: Compiling shader autogen file: …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/ShaderAutogen/PCD3D_SM5/AutogenShaderHeaders.ush
LogShaderCompilers: Display: Autogen file is unchanged, skipping write.
LogSlate: Using FreeType 2.10.0
LogSlate: SlateFontServices - WITH_FREETYPE: 1, WITH_HARFBUZZ: 1
LogAssetRegistry: FAssetRegistry took 0.0014 seconds to start up
LogAssetRegistry: Display: AssetDataGatherer spent 0.000s loading caches …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/CachedAssetRegistry_*.bin.
LogEditorDomain: Display: EditorDomain is Disabled
LogTextureEncodingSettings: Display: Texture Encode Speed: FinalIfAvailable (editor).
LogTextureEncodingSettings: Display: Oodle Texture Encode Speed settings: Fast: RDO Off Lambda=0, Effort=Normal Final: RDO Off Lambda=0, Effort=Normal
LogTextureEncodingSettings: Display: Shared linear texture encoding: Disabled
LogDeviceProfileManager: Display: Deviceprofile LinuxArm64Editor not found.
LogDeviceProfileManager: Display: Deviceprofile LinuxArm64 not found.
LogDeviceProfileManager: Available device profiles:
LogDeviceProfileManager: [0000053DCA856200][0000053DC31EC800 66] GlobalDefaults,
LogDeviceProfileManager: [0000053DCA855A00][0000053DC31E7800 66] Windows,
LogDeviceProfileManager: [0000053DCA856800][0000053DC2E7A000 66] WindowsEditor,
LogDeviceProfileManager: [0000053DCA856E00][0000053DC2E77800 66] WindowsServer,
LogDeviceProfileManager: [0000053DCA857000][0000053DC2E75000 66] WindowsClient,
LogDeviceProfileManager: [0000053DCA857200][0000053DC2E70000 66] IOS,
LogDeviceProfileManager: [0000053DCA857400][0000053DBCE47800 66] iPadAir2,
LogDeviceProfileManager: [0000053DCA857600][0000053D9DB32800 66] IPadPro,
LogDeviceProfileManager: [0000053DCA857800][0000053DCAD10000 66] iPadAir3,
LogDeviceProfileManager: [0000053DCA857A00][0000053DCAD12800 66] iPadAir4,
LogDeviceProfileManager: [0000053DCA857C00][0000053DCAD15000 66] iPadAir5,
LogDeviceProfileManager: [0000053DCA857E00][0000053DCAD17800 66] iPadMini4,
LogDeviceProfileManager: [0000053DCA858000][0000053DCAD1A000 66] iPadMini5,
LogDeviceProfileManager: [0000053DCA858200][0000053DCAD1C800 66] iPadMini6,
LogDeviceProfileManager: [0000053DCA858400][0000053DCAD20000 66] iPhone6S,
LogDeviceProfileManager: [0000053DCA858600][0000053DCAD22800 66] iPhone7,
LogDeviceProfileManager: [0000053DCA858800][0000053DCAD25000 66] iPodTouch7,
LogDeviceProfileManager: [0000053DCA858A00][0000053DCAD27800 66] iPhone6SPlus,
LogDeviceProfileManager: [0000053DCA858C00][0000053DCAD2A000 66] iPhone7Plus,
LogDeviceProfileManager: [0000053DCA858E00][0000053DCAD2C800 66] iPhoneSE,
LogDeviceProfileManager: [0000053DCA859000][0000053DCAD30000 66] iPhone8,
LogDeviceProfileManager: [0000053DCA859200][0000053DCAD32800 66] iPhone8Plus,
LogDeviceProfileManager: [0000053DCA859400][0000053DCAD35000 66] iPhoneX,
LogDeviceProfileManager: [0000053DCA859600][0000053DCAD37800 66] iPhoneXS,
LogDeviceProfileManager: [0000053DCA859800][0000053DCAD3A000 66] iPhoneXSMax,
LogDeviceProfileManager: [0000053DCA859A00][0000053DCAD3C800 66] iPhoneXR,
LogDeviceProfileManager: [0000053DCA859C00][0000053DCAD40000 66] iPhone11,
LogDeviceProfileManager: [0000053DCA859E00][0000053DCAD42800 66] iPhone11Pro,
LogDeviceProfileManager: [0000053DCA85A000][0000053DCAD45000 66] iPhone11ProMax,
LogDeviceProfileManager: [0000053DCA85A200][0000053DCAD47800 66] iPhoneSE2,
LogDeviceProfileManager: [0000053DCA85A400][0000053DCAD4A000 66] iPhone12Mini,
LogDeviceProfileManager: [0000053DCA85A600][0000053DCAD4C800 66] iPhone12,
LogDeviceProfileManager: [0000053DCA85A800][0000053DCAC70000 66] iPhone12Pro,
LogDeviceProfileManager: [0000053DCA85AA00][0000053DCAC72800 66] iPhone12ProMax,
LogDeviceProfileManager: [0000053DCA85AC00][0000053DCAC75000 66] iPhone13Mini,
LogDeviceProfileManager: [0000053DCA85AE00][0000053DCAC77800 66] iPhone13,
LogDeviceProfileManager: [0000053DCA85B000][0000053DCAC7A000 66] iPhone13Pro,
LogDeviceProfileManager: [0000053DCA85B200][0000053DCAC7C800 66] iPhone13ProMax,
LogDeviceProfileManager: [0000053DCA85B400][0000053DCAC80000 66] iPhoneSE3,
LogDeviceProfileManager: [0000053DCA85B600][0000053DCAC82800 66] iPhone14,
LogDeviceProfileManager: [0000053DCA85B800][0000053DCAC85000 66] iPhone14Plus,
LogDeviceProfileManager: [0000053DCA85BA00][0000053DCAC87800 66] iPhone14Pro,
LogDeviceProfileManager: [0000053DCA85BC00][0000053DCAC8A000 66] iPhone14ProMax,
LogDeviceProfileManager: [0000053DCA85BE00][0000053DCAC8C800 66] iPhone15,
LogDeviceProfileManager: [0000053DCA85C000][0000053DCAC90000 66] iPhone15Plus,
LogDeviceProfileManager: [0000053DCA85C200][0000053DCAC92800 66] iPhone15Pro,
LogDeviceProfileManager: [0000053DCA85C400][0000053DCAC95000 66] iPhone15ProMax,
LogDeviceProfileManager: [0000053DCA85C600][0000053DCAC97800 66] iPadPro105,
LogDeviceProfileManager: [0000053DCA85C800][0000053DCAC9A000 66] iPadPro129,
LogDeviceProfileManager: [0000053DCA85CA00][0000053DCAC9C800 66] iPadPro97,
LogDeviceProfileManager: [0000053DCA85CC00][0000053DCACA0000 66] iPadPro2_129,
LogDeviceProfileManager: [0000053DCA85CE00][0000053DCACA2800 66] iPad5,
LogDeviceProfileManager: [0000053DCA85D000][0000053DCACA5000 66] iPad6,
LogDeviceProfileManager: [0000053DCA85D200][0000053DCACA7800 66] iPad7,
LogDeviceProfileManager: [0000053DCA85D400][0000053DCACAA000 66] iPad8,
LogDeviceProfileManager: [0000053DCA85D600][0000053DCACAC800 66] iPad9,
LogDeviceProfileManager: [0000053DCA85D800][0000053DCAD00000 66] iPad10,
LogDeviceProfileManager: [0000053DCA85DA00][0000053DCAD02800 66] iPadPro11,
LogDeviceProfileManager: [0000053DCA85DC00][0000053DCAD05000 66] iPadPro2_11,
LogDeviceProfileManager: [0000053DCA85DE00][0000053DCAD07800 66] iPadPro3_11,
LogDeviceProfileManager: [0000053DCA85E000][0000053DCAD0A000 66] iPadPro4_11,
LogDeviceProfileManager: [0000053DCA85E200][0000053DCAD0C800 66] iPadPro3_129,
LogDeviceProfileManager: [0000053DCA85E400][0000053DCACB0000 66] iPadPro4_129,
LogDeviceProfileManager: [0000053DCA85E600][0000053DCACB2800 66] iPadPro5_129,
LogDeviceProfileManager: [0000053DCA85E800][0000053DCACB5000 66] iPadPro6_129,
LogDeviceProfileManager: [0000053DCA85EA00][0000053DCACB7800 66] AppleTV,
LogDeviceProfileManager: [0000053DCA85EC00][0000053DCACBA000 66] AppleTV4K,
LogDeviceProfileManager: [0000053DCA85EE00][0000053DCACBC800 66] AppleTV2_4K,
LogDeviceProfileManager: [0000053DCA85F000][0000053DCACC0000 66] TVOS,
LogDeviceProfileManager: [0000053DCA85F200][0000053DCACC2800 66] Mac,
LogDeviceProfileManager: [0000053DCA85F400][0000053DCACC5000 66] MacEditor,
LogDeviceProfileManager: [0000053DCA85F600][0000053DCACC7800 66] MacClient,
LogDeviceProfileManager: [0000053DCA85F800][0000053DCACCA000 66] MacServer,
LogDeviceProfileManager: [0000053DCA85FA00][0000053DCACCC800 66] Linux,
LogDeviceProfileManager: [0000053DCA85FC00][0000053DCACD0000 66] LinuxEditor,
LogDeviceProfileManager: [0000053DCA85FE00][0000053DCACD2800 66] LinuxArm64Editor,
LogDeviceProfileManager: [0000053DCA26E400][0000053DCACD5000 66] LinuxArm64,
LogDeviceProfileManager: [0000053D9D91D200][0000053DCACD7800 66] LinuxClient,
LogDeviceProfileManager: [0000053DCACE0000][0000053DCACDA000 66] LinuxArm64Client,
LogDeviceProfileManager: [0000053DCACE0200][0000053DCACDC800 66] LinuxServer,
LogDeviceProfileManager: [0000053DCACE0400][0000053DCAD90000 66] LinuxArm64Server,
LogDeviceProfileManager: [0000053DCACE0600][0000053DCAD92800 66] Android,
LogDeviceProfileManager: [0000053DCACE0800][0000053DCAD95000 66] Android_Preview_OpenGL,
LogDeviceProfileManager: [0000053DCACE0A00][0000053DCAD97800 66] Android_Preview_Vulkan,
LogDeviceProfileManager: [0000053DCACE0C00][0000053DCAD9A000 66] Android_Low,
LogDeviceProfileManager: [0000053DCACE0E00][0000053DCAD9C800 66] Android_Mid,
LogDeviceProfileManager: [0000053DCACE1000][0000053DCADA0000 66] Android_High,
LogDeviceProfileManager: [0000053DCACE1200][0000053DCADA2800 66] Android_Default,
LogDeviceProfileManager: [0000053DCACE1400][0000053DCADA5000 66] Android_Adreno4xx,
LogDeviceProfileManager: [0000053DCACE1600][0000053DCADA7800 66] Android_Adreno5xx_Low,
LogDeviceProfileManager: [0000053DCACE1800][0000053DCADAA000 66] Android_Adreno5xx,
LogDeviceProfileManager: [0000053DCACE1A00][0000053DCADAC800 66] Android_Adreno6xx,
LogDeviceProfileManager: [0000053DCACE1C00][0000053DCACF0000 66] Android_Adreno6xx_Vulkan,
LogDeviceProfileManager: [0000053DCACE1E00][0000053DCACF2800 66] Android_Adreno7xx,
LogDeviceProfileManager: [0000053DCACE2000][0000053DCACF5000 66] Android_Adreno7xx_Vulkan,
LogDeviceProfileManager: [0000053DCACE2200][0000053DCACF7800 66] Android_Mali_T6xx,
LogDeviceProfileManager: [0000053DCACE2400][0000053DCACFA000 66] Android_Mali_T7xx,
LogDeviceProfileManager: [0000053DCACE2600][0000053DCACFC800 66] Android_Mali_T8xx,
LogDeviceProfileManager: [0000053DCACE2800][0000053DCADB0000 66] Android_Mali_G71,
LogDeviceProfileManager: [0000053DCACE2A00][0000053DCADB2800 66] Android_Mali_G72,
LogDeviceProfileManager: [0000053DCACE2C00][0000053DCADB5000 66] Android_Mali_G72_Vulkan,
LogDeviceProfileManager: [0000053DCACE2E00][0000053DCADB7800 66] Android_Mali_G76,
LogDeviceProfileManager: [0000053DCACE3000][0000053DCADBA000 66] Android_Mali_G76_Vulkan,
LogDeviceProfileManager: [0000053DCACE3200][0000053DCADBC800 66] Android_Mali_G77,
LogDeviceProfileManager: [0000053DCACE3400][0000053DCADC0000 66] Android_Mali_G77_Vulkan,
LogDeviceProfileManager: [0000053DCACE3600][0000053DCADC2800 66] Android_Mali_G78,
LogDeviceProfileManager: [0000053DCACE3800][0000053DCADC5000 66] Android_Mali_G78_Vulkan,
LogDeviceProfileManager: [0000053DCACE3A00][0000053DCADC7800 66] Android_Mali_G710,
LogDeviceProfileManager: [0000053DCACE3C00][0000053DCADCA000 66] Android_Mali_G710_Vulkan,
LogDeviceProfileManager: [0000053DCACE4000][0000053DCADCC800 66] Android_Mali_G7xx,
LogDeviceProfileManager: [0000053DCACE4200][0000053DCADD0000 66] Android_Mali_G7xx_Vulkan,
LogDeviceProfileManager: [0000053DCACE4400][0000053DCADD2800 66] Android_Xclipse_920,
LogDeviceProfileManager: [0000053DCACE4600][0000053DCADD5000 66] Android_Xclipse_920_Vulkan,
LogDeviceProfileManager: [0000053DCACE4A00][0000053DCADD7800 66] Android_Vulkan_SM5,
LogDeviceProfileManager: [0000053DCACE4C00][0000053DCADDA000 66] Android_PowerVR_G6xxx,
LogDeviceProfileManager: [0000053DCACE4E00][0000053DCADDC800 66] Android_PowerVR_GT7xxx,
LogDeviceProfileManager: [0000053DCACE5000][0000053DCADE0000 66] Android_PowerVR_GE8xxx,
LogDeviceProfileManager: [0000053DCACE5200][0000053DCADE2800 66] Android_PowerVR_GM9xxx,
LogDeviceProfileManager: [0000053DCACE5400][0000053DCADE5000 66] Android_PowerVR_GM9xxx_Vulkan,
LogDeviceProfileManager: [0000053DCACE5600][0000053DCADE7800 66] Android_TegraK1,
LogDeviceProfileManager: [0000053DCACE5800][0000053DCADEA000 66] Android_Unknown_Vulkan,
LogDeviceProfileManager: [0000053DCACE5A00][0000053DCADEC800 66] Oculus_Quest,
LogDeviceProfileManager: [0000053DCACE5C00][0000053DCAE00000 66] Oculus_Quest2,
LogDeviceProfileManager: [0000053DCACE5E00][0000053DCAE02800 66] Meta_Quest_Pro,
LogDeviceProfileManager: [0000053DCACE6000][0000053DCAE05000 66] Meta_Quest_3,
LogDeviceProfileManager: [0000053DCACE6200][0000053DCAE07800 66] HoloLens,
LogDeviceProfileManager: [0000053DCACE6400][0000053DCAE0A000 66] MagicLeap_Vulkan,
LogDeviceProfileManager: Active device profile: [0000053DCA856800][0000053DC2E7A000 66] WindowsEditor
LogCsvProfiler: Display: Metadata set : deviceprofile=“WindowsEditor”
5 part :
6 part :
LogTurnkeySupport: Turnkey Platform: Android: (Status=Invalid, Allowed_Sdk=r25b, Current_Sdk=, Allowed_AutoSdk=r25b, Current_AutoSdk=, Flags=“Platform_InvalidHostPrerequisites”, Error=“Android Studio is not installed correctly.”)
LogTurnkeySupport: Turnkey Platform: IOS: (Status=Invalid, MinAllowed_Sdk=1100.0.0.0, MaxAllowed_Sdk=8999.0, Current_Sdk=, Allowed_AutoSdk=14.1, Current_AutoSdk=, Flags=“Platform_ValidHostPrerequisites”)
LogTurnkeySupport: Turnkey Platform: Linux: (Status=Invalid, Allowed_Sdk=v22_clang-16.0.6-centos7, Current_Sdk=, Allowed_AutoSdk=v22_clang-16.0.6-centos7, Current_AutoSdk=, Flags=“Platform_ValidHostPrerequisites”)
LogTurnkeySupport: Turnkey Platform: LinuxArm64: (Status=Invalid, Allowed_Sdk=v22_clang-16.0.6-centos7, Current_Sdk=, Allowed_AutoSdk=v22_clang-16.0.6-centos7, Current_AutoSdk=, Flags=“Platform_ValidHostPrerequisites”)
LogTurnkeySupport: Turnkey Platform: Win64: (Status=Valid, MinAllowed_Sdk=10.0.00000.0, MaxAllowed_Sdk=10.9.99999.0, Current_Sdk=10.0.22621.0, Allowed_AutoSdk=10.0.18362.0, Current_AutoSdk=, Flags=“InstalledSdk_ValidVersionExists”)
LogTurnkeySupport: Running Turnkey device detection: ’ -ScriptsForProject=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” Turnkey -utf8output -WaitForUATMutex -command=VerifySdk -ReportFilename=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyReport_1.log” -log=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyLog_1.log” -project=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” -Device=Win64@DESKTOP-NCTA41U’
LogMonitoredProcess: Running Serialized UAT: [ cmd.exe /c ““E:/epic/UE_5.3/Engine/Build/BatchFiles/RunUAT.bat” -ScriptsForProject=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” Turnkey -utf8output -WaitForUATMutex -command=VerifySdk -ReportFilename=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyReport_1.log” -log=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/TurnkeyLog_1.log” -project=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” -Device=Win64@DESKTOP-NCTA41U” -nocompile -nocompileuat ]
LogMaterial: WorldGridMaterial-SM5-Default: MATSM_DA9E5626FCAE01590760E73DF088B4B4_PCD3D_SM5_-86156035__BC5N_NoCCBN_NoIris_DEV_NoSL_LWC2_PreExp_NoDBuf_UnInt_DXC0_SKYATM_SKYHF_SLWSMDLT_gs1_sdct_VT-0-0-1-0_MIN_DF_VED_Aniso-1_ComprOodle_Compr2_Lev4_ExclNonPipSh-1_LWC-2097152_347391141DB6FCC63A5C44EA751315CBC3EF5DDED_Num_SM5_FL_0000000d_MFA_00000008_V_B6A0A753ED62499D8F30931E61FCAB05_0_DB3E993F4E2E98B305AD13B92D8C5DA5_A05E64F5EBD44C64BD24277E1DB8EBB792FC705C___TShadowDepthPSPixelShadowDepth_PerspectiveCorrect0_0_0421FA051313F8E4A7602E1BED561A378F2017ADF1D3D5B5AF4A6D9ADE7391C36E24BD5A02F4BAF61_FLum
enCardPS0_0_0EA0D6ECCFD45BA4EFD0846897C2FBB83778A2113C200DC679A410C1D8AF12A00F0044876007851BC_TShadowDepthPSPixelShadowDepth_NonPerspectiveCorrect0_0_0421FA051313F8E4A7602E1BED561A378F2017ADF5F6D284012F74DD2CFC45AAEF7606EB9D574CE14_TShadowDepthVSVertexShadowDepth_OutputDepthPositionOnly0_0_0BCCF9F50BDA7334AA7665DF76CBF4468F053BCD14E731E4363CF47597678D99A2AE4FAE80343B3DC_FLandscapeGrassWeightVS0_0_0DAD0836FAE0059410131FB044108B9976B09A2EE47C0690A66AEBFB62A3248327AB8B3401F67DA0D_FHitProxyVS0_0_0DE545DAFCCBCFE15E7C12101EEA0D6665E191B3352D62CB854026D5374EC4E8A00F09A8B1D3302B8_FHitProxyPS0_0
_00E673AA4381A9D6CBED31E757AFC58370E8DA501591AC01CFB8D5107B679B4AC4E6A2D25CEE2821A_FLandscapeGrassWeightPS0_0_0DAD0836FAE0059410131FB044108B9976B09A2EEB0B2C106151A19D437E6A81208418E180C9A94FC_TBasePassPSFNoLightMapPolicy0_0_07557316D79D0111C15D881AE298B469FF57CADCFAA7AFF0410210797DA8DBFDCE4DCE7BD73648BF2_TShadowDepthVSVertexShadowDepth_OutputDepth0_0_0BCCF9F50BDA7334AA7665DF76CBF4468F053BCD1F87CEE5C05DBEF9DC24EE7C0F6CF60618ED0AF73_TDepthOnlyVS0_0_06E61CD7BC799FFBC598D239D1565E08F1C2214DE6C2F9E9E0F29C1CC4BD070290C8B56F4775CBAE7_FLandscapePhysicalMaterialPS0_0_026A870FC083264FC0D21F3FDD871
C3591E7C0DC2EB9F96523E4AC1F2529D86D76BDF869A153FCD4A_FLumenCardVS0_0_02D9B904C107EDAD770242D58250768F8F6681816CC43E529207B75738B69C90E919763AEC6FA2C8A_FTranslucentLightingInjectPS0_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS1_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS2_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS3_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B650
8EB252_FTranslucentLightingInjectPS4_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS5_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS6_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS7_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS8_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInj
ectPS9_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS10_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS11_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS12_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS13_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS14_0_03ACE2F2CDBA587F
8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FTranslucentLightingInjectPS15_0_03ACE2F2CDBA587F8520BF1DD1323E488708562039F4E9EF4CCC371C10E4840E2DBD313B6508EB252_FVelocityPS0_0_0D83744A6B13BA99CF41E005CBE641FBF7D30E809424AC0BEE559BE53397AB3C2FC130F4C90538CDB_TShadowDepthVSVertexShadowDepth_PerspectiveCorrect0_0_0BCCF9F50BDA7334AA7665DF76CBF4468F053BCD19396F3B9CB091423F82674523BC72504438631DE_FLandscapePhysicalMaterialVS0_0_026A870FC083264FC0D21F3FDD871C3591E7C0DC211D5D4108CFDB5B6CBE8F3ADC4BE30C19859186B_TBasePassPSFNoLightMapPolicySkylight0_0_07557316D79D0111C15D881AE298B469
FF57CADCF23AEF5FC38580B9DD682422255AA9EC62059678A_TShadowDepthPSPixelShadowDepth_OnePassPointLight0_0_0421FA051313F8E4A7602E1BED561A378F2017ADF3189543DEB1E5450A6398EF5AC45B9A88DC3459B_TShadowDepthVSVertexShadowDepth_PerspectiveCorrectPositionOnly0_0_0BCCF9F50BDA7334AA7665DF76CBF4468F053BCD1FD365E6D701BA2F152E8623339642107E5FF7FC6_TShadowDepthVSVertexShadowDepth_OnePassPointLight0_0_0BCCF9F50BDA7334AA7665DF76CBF4468F053BCD195DED9C73DC5F223F091004CF57334C099017CF0_FDebugViewModePS0_0_0C6E4946C477F7EE212BE4DA3CF56C974369251330074CFCF9A67BE69CCE53140F9193C858B3006EA_TDepthOnlyVS0_0_00BF065A
D4189CC448D35F173DE3060713CAA7EEDB419F3F2046DFF016D3871BF8CD05BB9BBEB725B_FVelocityVS0_0_0D83744A6B13BA99CF41E005CBE641FBF7D30E809FAAC9A9CF81E62F8A1951C16ACC22C4E57F44BC0_FDebugViewModeVS0_0_0B61C82EA9AD3F54A3B16388EDF657EA2167B9CE096E81C67446F25BC2AFD5BB735073ABD7EC8AFCB_TShadowDepthVSVertexShadowDepth_OnePassPointLightPositionOnly0_0_0BCCF9F50BDA7334AA7665DF76CBF4468F053BCD16B4B2EFE52CC3161DCE6CD93F30EE731E991F313_TBasePassVSFNoLightMapPolicy0_0_0A65244200AED86218CD27E7A52551E5171B436D0DDD2F7DEF5574DB43546D80EEC3EF30B7E0E7148_DepthPosOnlyNoPixelPipeline6E61CD7BC799FFBC598D239D1565E08F1C2214D
E_VelocityPipeline20C344F555ACDF7E1F406DCAE5BD939BDE9085F4_DepthNoPixelPipeline0BF065AD4189CC448D35F173DE3060713CAA7EED_FGPUSpriteVertexFactory1B105ACF19156A8E47C60A6765F47C9C0E713DCE5C5BE91DA01DC2B25B1018F3EDA7A6FC7D1D30AEB9CA513CCBA4F1E3AF7D9556DD0F2FF45E951E1A_FNiagaraRibbonVertexFactoryE95E07B2B5A719DA06E8D11B2FB0CC54B6B56E76A5C2BD7C8E1CB8C2C0438E13767AF67A0D5B5966DE03DD13CEAD2D60503F2AAC85D4762994EF4025A5C2BD7C8E1CB8C2C0438E13767AF67A0D5B5966A5C2BD7C8E1CB8C2C0438E13767AF67A0D5B5966_TGPUSkinAPEXClothVertexFactoryDefaultCF64B0EF7E81EBA72A0526CEAFDC06D033915AAABBEDF5F2F99060D3A4E705A02AFC0D4
CFF550703_TWaterVertexFactory< false>95445228BFA342317091AF0431C2627F9B982BD5295D256B82891294744045A87BB9B9F11F889491295D256B82891294744045A87BB9B9F11F889491295D256B82891294744045A87BB9B9F11F889491_FParticleSpriteVertexFactoryF6C8B1ED0A25136B9413B8ED0252A7B130446DF7F99E1B0FB635933CEEAC41CF9441DF5EA4A994CA9DAE5A7C55936FD50BC3B20BD063C1832A4D4247_TGPUSkinVertexFactoryUnlimitedCF64B0EF7E81EBA72A0526CEAFDC06D033915AAA180376A7171B50BD465E9983F32BCB5A07542FE7_FVectorFieldVisualizationVertexFactory8046109C676F9DB08B031AF55E8EE558AB0D6BCACC854D8E74FEAEF90804D69AF6B78BD07A141ACC_FNiagaraMeshVertexFacto
ry052C263B69D53BB70C92B9E40B293E4126B3B3924B3A20E0CA93D5CA5A60C16EF2EB14EA073FC9571BD81B2CBA1F364F28A837532353718EB814537B4B3A20E0CA93D5CA5A60C16EF2EB14EA073FC9574B3A20E0CA93D5CA5A60C16EF2EB14EA073FC957_FParticleBeamTrailVertexFactory40D7A56177FF0069290A4EF2E07EDCA981B1C3B4378BBDDEC2CEAC35A309C357B38D702E7981D5D3_TGPUSkinVertexFactoryDefaultCF64B0EF7E81EBA72A0526CEAFDC06D033915AAA180376A7171B50BD465E9983F32BCB5A07542FE7_TGPUSkinAPEXClothVertexFactoryUnlimitedCF64B0EF7E81EBA72A0526CEAFDC06D033915AAABBEDF5F2F99060D3A4E705A02AFC0D4CFF550703_FGeometryCollectionVertexFactoryBFCBA239089CED72643DACC7
EAE4F0DD9FDED75F49D716CAD02F0AC031CC93ACB2AFCB9C42E7DC4149D716CAD02F0AC031CC93ACB2AFCB9C42E7DC4149D716CAD02F0AC031CC93ACB2AFCB9C42E7DC41_FLandscapeXYOffsetVertexFactoryF93AC2298DAB32583F62E042E13F0BF24F1C98C1B1684FBEF19B946A8709F4309D7CC4E5FC6044ADEBA49461CECB1EA5D21E2BF8918B91C7C3994DCEB1684FBEF19B946A8709F4309D7CC4E5FC6044ADB1684FBEF19B946A8709F4309D7CC4E5FC6044AD_FMeshParticleVertexFactory63D2076FC477AD68B3E41F1BA95A65FD7FBC4A2CF773920348F231C490A74B1A551F8CE3ABF04791_FCesiumPointAttenuationVertexFactoryFEE2197321762F93197BD0FC33F8B26D2AA27030C8E67C27A64AE201DFA6C7409BEA87B97017C9DA_FInstan
cedStaticMeshVertexFactoryA536A59BC2FAF6BB7B735065D9A5DFE24BE34A2939A00A3AF8434811E9EA9890B934C37C364D15CD39A00A3AF8434811E9EA9890B934C37C364D15CD39A00A3AF8434811E9EA9890B934C37C364D15CD39A00A3AF8434811E9EA9890B934C37C364D15CD_FSplineMeshVertexFactoryA536A59BC2FAF6BB7B735065D9A5DFE24BE34A29A747D67BD07743C1BEA1DE549F682B82EB7B9965A747D67BD07743C1BEA1DE549F682B82EB7B9965A747D67BD07743C1BEA1DE549F682B82EB7B9965_TWaterVertexFactory< true>95445228BFA342317091AF0431C2627F9B982BD5F06C64CCD77B1C9E345ED2D7F6053A0AC8701007F06C64CCD77B1C9E345ED2D7F6053A0AC8701007F06C64CCD77B1C9E345ED2D7F6053A0AC8701007_F
LocalVertexFactoryA536A59BC2FAF6BB7B735065D9A5DFE24BE34A2981418F8992AC49B8E2AFD31AF3B57530A23E085E81418F8992AC49B8E2AFD31AF3B57530A23E085E81418F8992AC49B8E2AFD31AF3B57530A23E085E_FLandscapeVertexFactoryF93AC2298DAB32583F62E042E13F0BF24F1C98C1B1684FBEF19B946A8709F4309D7CC4E5FC6044ADEBA49461CECB1EA5D21E2BF8918B91C7C3994DCEB1684FBEF19B946A8709F4309D7CC4E5FC6044ADB1684FBEF19B946A8709F4309D7CC4E5FC6044AD_FNiagaraSpriteVertexFactory2D699768682F604347476E0BAAD3E63203C9B0B35957CFEE095AEFFBA7F83F09F020F15CF6555718EFF166204144512228FF7A163011544EEF3FD2265957CFEE095AEFFBA7F83F09F020F15CF65557185957CFEE09
5AEFFBA7F83F09F020F15CF6555718_FGeometryCacheVertexVertexFactoryF7A2A7134F95BD0D46418459582942D14D992DC476143182082C57C6F98756E7AE927ED26DD4479A76143182082C57C6F98756E7AE927ED26DD4479A_FLandscapeFixedGridVertexFactoryF93AC2298DAB32583F62E042E13F0BF24F1C98C13F5F45F5620EF6411E27211E3D675CEA50B38DFBEBA49461CECB1EA5D21E2BF8918B91C7C3994DCE3F5F45F5620EF6411E27211E3D675CEA50B38DFB3F5F45F5620EF6411E27211E3D675CEA50B38DFB_FLandscapeTileVertexFactoryF93AC2298DAB32583F62E042E13F0BF24F1C98C1B1684FBEF19B946A8709F4309D7CC4E5FC6044ADEBA49461CECB1EA5D21E2BF8918B91C7C3994DCE27021014141444441444144414141414144
444740101010101013145444414331401013401010142446451214141414240241414141414131330444444372414444444440444444444444444444443414141414241404444444444442434141414141510100031313131233131434341434131423121444044444131313131444031010101510101010101131616564343434341161616161616662431616161613034343444144444444414151515101030010131151616161662444444444444000404040404040404040404040404343434343444444444444444440404040404040444444444040404044444444444444443444444442414421414444444241414144414441414141414141313131313131314443444444444141414141414141414141414343434444444444444344404441414141444141414141
414341414144414141414444414441414141334444244444414141432341414141413141414142412343424242424242414343434143414144414141313131343244414141244141313134444443414141212124242131444444444442122226141142210121212121243444444444444041415101510153043410133141400515151516161616161010101010151514012121316161616363161611210100140141313131433140441010101010101010101510101010101010143141500010101010101010101010101010101010101010101010116000444140404242431313141440101010161010101010101013101010140121313131416160601616161244431313121212121212121214141414444444444214044441412121212121212121212121213121212121
212121212121412121212121212123244141304313131316161616161616161211043444444341444141414142424141212121212121212121213121212121212121212121212121212424424242434343414144414141414144444444444444444144214023131313131316161616161101010121010101015101200444444444043424044423151014044444444444443033131312143314040404040434144433143314443314331434143414331433131433143214241314141413131441114424644444404446444444444404440141010151015101510011010101010101010101010101010002222434242313131313110000444140404141210101000010101010101014444424231310101404444444444444444444444444444444444444444444444444444444
444444444444444444404444444444444434144414141414342411010121213232222221210101010100001010101014444424241210101010101010101414101015101010101010044444414151510504340404341000404040404040404040404040404343434343434344444343434340404040404040434343434040404044444242444444443444444242414121414444444241414143414141414141414141313131313131314443444444444141414141414141414141414343434444444444444344404441414141444141414141414341414144414141414444414141414141334144244444414141432341414141413141414142412343424242424242414343434143414144414141313131343244414141244141313134444443414141212124212131444444
44414101015151515151515151515101010101010101010151515151010101510151015101510151015101010101010101510161510151015101510151015101510151015101510131315151515101510151015101510101510151016461414154014151010161617363404313131313131313144222231414141010101010113464444412121210011000000130000001300000013000000130000001300000013000000140000000C00000013000000130000000D000000090000001400000010000000100000000800000009000000080000002500000010000000100000001300000009000000080000000800000010000000100000001000000010000000100000000800000008000000080000001000000010000000D80000001000000010000000100000001000000
0100000001000000010000000100000001000000010000000100000001000000010000000100000001000000010000000100000001000000010000000100000001000000010000000100000001000000010000000100000001000000014000000100000000800000008000000080000001400000014000000100000000800000008000000080000000800000008000000080000001300000010000000140000000800000012000000130000001300000013000000130000001300000013000000130000000D0000001300000008000000100000001100000009000000080000000900000008000000080000001700000009000000080000000900000008000000090000000800000009000000080000000C00000009000000080000000900000009000000090000000900000
0090000000900000009000000080000000800000008000000080000000800000013000000100000001000000010000000170000001000000010000000100000001000000009000000090000000900000009000000100000001000000010000000100000001000000010000000080000001A00000014000000280000000D000000440000000B0000000B00000013000000130000000900000009000000090000001400000008000000100000000D0000000C0000001000000008000000080000002D00000010000000100000001000000010000000100000001000000010000000090000000900000008000000080000000800000008000000130000000E000000090000000900000009000000090000000900000009000000090000000900000009000000090000000900000
0090000000C000000080000000A0000000C00000013000000100000001000000010000000100000001000000010000000100000000D0000000F00000009000000080000000900000008000000090000000C00000008000000130000001300000026000000100000000F000000140000000900000009000000090000000900000009000000100000001D000000130000001300000013000000130000001300000009000000080000000C000000080000000900000008000000090000000800000014000000140000000800000010000000090000000800000013000000080000001000000008000000080000001000000010000000410100001000000010000000100000001000000010000000100000001000000010000000100000001000000010000000100000001000000
01000000010000000100000001000000010000000100000001000000010000000100000001000000010000000100000001000000010000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000080000000800000008000000140000001000000010000000100000001000000009000000433AFC833894B7681A1D3DDBA35F7F5A9509A899000000000000000
00000000000000000000000006E2AD9D86FE73F9DF5783D7E68BD0915331357DA_000_100_5;
LogMeshReduction: Display: Using QuadricMeshReduction for automatic static mesh reduction
LogMeshReduction: Display: Using SkeletalMeshReduction for automatic skeletal mesh reduction
LogMeshReduction: Display: Using ProxyLODMeshReduction for automatic mesh merging
LogMeshReduction: Display: No distributed automatic mesh merging module available
LogMeshMerging: No distributed automatic mesh merging module available
LogTurnkeySupport: Completed device detection: Code = 0
LogVirtualization: Display: VirtualizationSystem name found in ini file: None
LogVirtualization: Display: FNullVirtualizationSystem mounted, virtualization will be disabled
LogUObjectArray: 25480 objects as part of root set at end of initial load.
LogUObjectAllocator: 7694376 out of 0 bytes used by permanent object pool.
LogUObjectArray: CloseDisregardForGC: 0/0 objects in disregard for GC pool
LogLiveCoding: Display: Starting LiveCoding
LogLiveCoding: Display: LiveCodingConsole Arguments: UnrealEditor Win64 Development
LogLiveCoding: Display: First instance in process group “UE_LumaAIStarterProject_0x68558d14”, spawning console
LogLiveCoding: Display: Waiting for server
LogSlate: Border
LogSlate: BreadcrumbButton
LogSlate: Brushes.Title
LogSlate: Default
LogSlate: Icons.Save
LogSlate: Icons.Toolbar.Settings
LogSlate: ListView
LogSlate: SoftwareCursor_CardinalCross
LogSlate: SoftwareCursor_Grab
LogSlate: TableView.DarkRow
LogSlate: TableView.Row
LogSlate: TreeView
LogWorldPartition: Display: FWorldPartitionClassDescRegistry::Initialize started…
LogWorldPartition: Display: FWorldPartitionClassDescRegistry::Initialize took 2 ms
LogInit: XR: Instanced Stereo Rendering is Disabled
LogInit: XR: MultiViewport is Disabled
LogInit: XR: Mobile Multiview is Disabled
LogTurnkeySupport: Turnkey Device: Win64@DESKTOP-NCTA41U: (Name=DESKTOP-NCTA41U, Type=Computer, Status=Valid, MinAllowed=10.0.18362.0, MaxAllowed=, Current=10.0.19044.0, Flags=“Device_InstallSoftwareValid”)
LogPython: Using Python 3.9.7
LogLiveCoding: Display: Successfully initialized, removing startup thread
LogAudio: Display: Registering Engine Module Parameter Interfaces…
LogMetasoundEngine: MetaSound Engine Initialized
LogTcpMessaging: Initializing TcpMessaging bridge
LogUdpMessaging: Initializing bridge on interface 0.0.0.0:0 to multicast group 230.0.0.1:6666.
LogUdpMessaging: Display: Added local interface ‘192.168.0.116’ to multicast group ‘230.0.0.1:6666’
LogNiagaraDebuggerClient: Niagara Debugger Client Initialized | Session: 139DC36548A0A999C9FAE8A986D2947A | Instance: D1989A0942B784987B797AB85FCFB20E (DESKTOP-NCTA41U-4252).
LogShaders: Mapping virtual shader directory /Plugin/Experimental/ChaosNiagara to …/…/…/Engine/Plugins/Experimental/ChaosNiagara/Shaders
LogOpenImageDenoise: OIDN starting up
LogAndroidPermission: UAndroidPermissionCallbackProxy::GetInstance
LogAudioCaptureCore: Display: No Audio Capture implementations found. Audio input will be silent.
LogTemp: OpenXR ignores max viewport resolution in editor to support full HMD resolutions.
SourceControl: Revision control is disabled
LogUProjectInfo: Found projects:
LogVSAccessor: Display: Unable to create Visual Studio setup instance: 80040154
LogCollectionManager: Loaded 0 collections in 0.000444 seconds
Final :
LogFileCache: Scanning file cache for directory ‘E:/loads/LumaAIStarterProject_5.3_2023_10_26/Saved/Collections/’ took 0.00s
LogFileCache: Scanning file cache for directory ‘E:/loads/LumaAIStarterProject_5.3_2023_10_26/Content/Developers/убийцаа/Collections/’ took 0.00s
LogFileCache: Scanning file cache for directory ‘E:/loads/LumaAIStarterProject_5.3_2023_10_26/Content/Collections/’ took 0.00s
LogEngine: Initializing Engine…
LogStats: UGameplayTagsManager::InitializeManager - 0.000 s
LogInit: Initializing FReadOnlyCVARCache
LogWorldSubsystemInput: UEnhancedInputDeveloperSettings::bEnableWorldSubsystem is false, the world subsystem will not be created!
LogChaos: FPhysicsSolverBase::AsyncDt:-1.000000
LogAIModule: Creating AISystem for world Untitled
LogNetVersion: Set ProjectVersion to 1.0.0.0. Version Checksum will be recalculated on next use.
LogInit: Texture streaming: Enabled
LogAnalytics: Display: [UEEditor.Rocket.Release] APIServer = https://datarouter.ol.epicgames.com/. AppVersion = 5.3.2-29314046+++UE5+Release-5.3
LogAudio: Display: Initializing Audio Device Manager…
LogAudio: Display: Loading Default Audio Settings Objects…
LogAudio: Display: No default SoundConcurrencyObject specified (or failed to load).
LogAudio: Display: AudioInfo: ‘BINKA’ Registered
LogAudio: Display: AudioInfo: ‘PCM’ Registered
LogAudio: Display: AudioInfo: ‘ADPCM’ Registered
LogAudio: Display: AudioInfo: ‘OGG’ Registered
LogAudio: Display: AudioInfo: ‘OPUS’ Registered
LogAudio: Display: Audio Device Manager Initialized
LogAudio: Display: Creating Audio Device: Id: 1, Scope: Shared, Realtime: True
LogAudioMixer: Display: Audio Mixer Platform Settings:
LogAudioMixer: Display: Sample Rate: 48000
LogAudioMixer: Display: Callback Buffer Frame Size Requested: 1024
LogAudioMixer: Display: Callback Buffer Frame Size To Use: 1024
LogAudioMixer: Display: Number of buffers to queue: 2
LogAudioMixer: Display: Max Channels (voices): 32
LogAudioMixer: Display: Number of Async Source Workers: 0
LogAudio: Display: AudioDevice MaxSources: 32
LogAudio: Display: Audio Spatialization Plugin: None (built-in).
LogAudio: Display: Audio Reverb Plugin: None (built-in).
LogAudio: Display: Audio Occlusion Plugin: None (built-in).
LogAudioMixer: Display: Initializing audio mixer using platform API: ‘XAudio2’
LogAudioMixer: Display: Using Audio Hardware Device Динамики (Realtek High Definition Audio)
LogAudioMixer: Display: Initializing Sound Submixes…
LogAudioMixer: Display: Creating Master Submix ‘MasterSubmixDefault’
LogAudioMixer: Display: Creating Master Submix ‘MasterReverbSubmixDefault’
LogAudioMixer: FMixerPlatformXAudio2::StartAudioStream() called. InstanceID=1
LogAudioMixer: Display: Output buffers initialized: Frames=1024, Channels=2, Samples=2048, InstanceID=1
LogAudioMixer: Display: Starting AudioMixerPlatformInterface::RunInternal(), InstanceID=1
LogInit: FAudioDevice initialized with ID 1.
LogAudioMixer: Display: FMixerPlatformXAudio2::SubmitBuffer() called for the first time. InstanceID=1
LogAudio: Display: Audio Device (ID: 1) registered with world ‘Untitled’.
LogAudioMixer: Initializing Audio Bus Subsystem for audio device with ID 1
LogCsvProfiler: Display: Metadata set : largeworldcoordinates=“1”
LogInit: Undo buffer set to 32 MB
LogInit: Transaction tracking system initialized
LogSourceControl: Display: Uncontrolled Changelist persistency file loaded …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Saved/SourceControl/UncontrolledChangelists.json
LogSourceControl: Uncontrolled asset enumeration started…
LogSourceControl: Uncontrolled asset enumeration finished in 0.001894 seconds (Found 176 uncontrolled assets)
BlueprintLog: New page: Editor Load
LocalizationService: Localization service is disabled
TimingProfiler: Initialize
TimingProfiler: OnSessionChanged
LoadingProfiler: Initialize
LoadingProfiler: OnSessionChanged
NetworkingProfiler: Initialize
NetworkingProfiler: OnSessionChanged
MemoryProfiler: Initialize
MemoryProfiler: OnSessionChanged
LogAndroidRuntimeSettings: Display: Enabled Package for Meta Quest devices.
The following settings have been applied:
LogAndroidRuntimeSettings: Display: Support arm64: 1.
LogAndroidRuntimeSettings: Display: Support Vulkan: 1.
LogAndroidRuntimeSettings: Display: Support x86_64: 0.
LogAndroidRuntimeSettings: Display: Support Vulkan Desktop: 0.
LogAndroidRuntimeSettings: Display: Support OpenGL ES3.2: 0.
LogFileCache: Scanning file cache for directory ‘E:/loads/LumaAIStarterProject_5.3_2023_10_26/Content/’ took 0.00s
LogCesium: Display: Caching Cesium requests in C:/Users/убийцаа/AppData/Local/UnrealEngine/5.3/cesium-request-cache.sqlite
LogLevelSequenceEditor: LevelSequenceEditor subsystem initialized.
LogAssetRegistry: Display: Triggering cache save on discovery complete
LogInit: Display: Engine is initialized. Leaving FEngineLoop::Init()
LogUnrealEdMisc: Loading editor; pre map load, took 5.365
Cmd: MAP LOAD FILE=“…/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Content/Main.umap” TEMPLATE=0 SHOWPROGRESS=1 FEATURELEVEL=3
LightingResults: New page: Lighting Build
LogWorld: UWorld::CleanupWorld for Untitled, bSessionEnded=true, bCleanupResources=true
LogSlate: InvalidateAllWidgets triggered. All widgets were invalidated
MapCheck: New page: Map Check
LogAudio: Display: Audio Device unregistered from world ‘None’.
LogUObjectHash: Compacting FUObjectHashTables data took 0.32ms
LogAudio: Display: Audio Device (ID: 1) registered with world ‘Main’.
LogAIModule: Creating AISystem for world Main
LogCesium: Loading tileset from URL https://tile.googleapis.com/v1/3dtiles/root.json?key=AIzaSyASPYjp1nzT3XXW11Jt20lQa41cdGptRTI
LogCesium: Loading tileset from URL https://tile.googleapis.com/v1/3dtiles/root.json?key=AIzaSyASPYjp1nzT3XXW11Jt20lQa41cdGptRTI done
LogCesium: Loading tileset for asset ID 1
LogCesium: Loading tileset for asset ID 1 done
LogEditorServer: Finished looking for orphan Actors (0.000 secs)
LogUObjectHash: Compacting FUObjectHashTables data took 0.38ms
Cmd: MAP CHECKDEP NOCLEARLOG
MapCheck: Map check complete: 0 Error(s), 0 Warning(s), took 0,076ms to complete.
LogUnrealEdMisc: Total Editor Startup Time, took 5.588
LogShaderCompilers: Display: ================================================
LogShaderCompilers: Display: === FShaderJobCache stats ===
LogShaderCompilers: Display: Total job queries 0, among them cache hits 0 (0.00%)
LogShaderCompilers: Display: Tracking 0 distinct input hashes that result in 0 distinct outputs (0.00%)
LogShaderCompilers: Display: RAM used: 240,00 B of 1,60 GiB budget. Usage: 0.00%
LogShaderCompilers: Display: === Shader Compilation stats ===
LogShaderCompilers: Display: Shaders Compiled: 0
LogShaderCompilers: Display: Jobs assigned 0, completed 0 (0%)
LogShaderCompilers: Display: Time at least one job was in flight (either pending or executed): 0.00 s
LogSlate: Updating window title bar state: overlay mode, drag disabled, window buttons hidden, title bar hidden
LogSlate: Took 0.000054 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/Slate/Fonts/DroidSansMono.ttf’ (77K)
LogPakFile: Initializing PakPlatformFile
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/StarterContent.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_FirstPerson.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_FirstPersonBP.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_HandheldARBP.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_ThirdPerson.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_ThirdPersonBP.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_TopDown.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_TopDownBP.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_VehicleAdvBP.upack’, mount point: ‘root:/’
LogPakFile: Display: Mounted Pak file ‘E:/epic/UE_5.3/FeaturePacks/TP_VirtualRealityBP.upack’, mount point: ‘root:/’
LogSlate: Took 0.000078 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/Slate/Fonts/Roboto-Regular.ttf’ (155K)
LogSlate: Took 0.000095 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/Slate/Fonts/Roboto-Italic.ttf’ (157K)
LogViewport: Scene viewport resized to 1170x584, mode Windowed.
LogAssetRegistry: Display: Asset registry cache written as 25.3 MiB to …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Intermediate/CachedAssetRegistry_*.bin
LogStall: Startup…
LogStall: Startup complete.
LogLoad: (Engine Initialization) Total time: 6.13 seconds
LogLoad: (Engine Initialization) Total Blueprint compile time: 0.00 seconds
LogAssetRegistry: AssetRegistryGather time 0.0651s: AssetDataDiscovery 0.0172s, AssetDataGather 0.0193s, StoreResults 0.0287s.
LogCollectionManager: Fixed up redirectors for 0 collections in 0.000003 seconds (updated 0 objects)
LogContentStreaming: Texture pool size now 1000 MB
LogSlate: Took 0.000085 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/Slate/Fonts/Roboto-Bold.ttf’ (160K)
LogPython: registering <class ‘ControlRigWorkflows.workflow_deformation_rig_preset.provider’>
Running Python start-up script ‘E:/epic/UE_5.3/Engine/Plugins/Animation/ControlRig/Content/Python/init_unreal.py’: 0.022507 secs
LogConsoleManager: Warning: Console variable ‘FX.AllowGPUSorting’ used in the render thread. Rendering artifacts could happen. Use ECVF_RenderThreadSafe or don’t use in render thread.
LogSlate: Took 0.000075 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/Slate/Fonts/Roboto-Regular.ttf’ (155K)
LogUObjectHash: Compacting FUObjectHashTables data took 0.47ms
LogWindowsTextInputMethodSystem: Activated input method: Англійська (США) - (Keyboard).
LogTurnkeySupport: Project requires temp target (Text3D plugin is enabled)
LogLauncherProfile: Unable to use promoted target - …/…/…/…/…/loads/LumaAIStarterProject_5.3_2023_10_26/Binaries/Win64/UnrealGame-Win64-Shipping.target does not exist.
LogMonitoredProcess: Running Serialized UAT: [ cmd.exe /c ““E:/epic/UE_5.3/Engine/Build/BatchFiles/RunUAT.bat” -ScriptsForProject=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” Turnkey -command=VerifySdk -platform=Win64 -UpdateIfNeeded -EditorIO -EditorIOPort=49997 -project=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” BuildCookRun -nop4 -utf8output -nocompileeditor -skipbuildeditor -cook -project=“E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject” -unrealexe=“E:\epic\UE_5.3\Engine\Binaries\Win64\UnrealEd
itor-Cmd.exe” -platform=Win64 -installed -stage -archive -package -build -pak -iostore -compressed -prereqs -archivedirectory=“C:/Users/убийцаа/Desktop/vr_test” -clientconfig=Shipping -nodebuginfo” -nocompile -nocompileuat ]
UATHelper: Packaging (Windows): Running AutomationTool…
UATHelper: Packaging (Windows): Using bundled DotNet SDK version: 6.0.302
UATHelper: Packaging (Windows): Starting AutomationTool…
UATHelper: Packaging (Windows): Parsing command line: -ScriptsForProject=E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject Turnkey -command=VerifySdk -platform=Win64 -UpdateIfNeeded -EditorIO -EditorIOPort=49997 -project=E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject BuildCookRun -nop4 -utf8output -nocompileeditor -skipbuildeditor -cook -project=E:/loads/LumaAIStarterProject_5.3_2023_10_26/LumaAIStarterProject.uproject -unrealexe=E:\epic\UE_5.3\Engine\Binaries\Win64\UnrealEditor-Cmd.exe -platform=Win64 -installed -stage -archive -package -bu
ild -pak -iostore -compressed -prereqs -archivedirectory=C:/Users/㡨?栠/Desktop/vr_test -clientconfig=Shipping -nodebuginfo -nocompile -nocompileuat
UATHelper: Packaging (Windows): Initializing script modules…
LogSlate: Took 0.011382 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/Slate/Fonts/DroidSansFallback.ttf’ (3848K)
LogSlate: Last resort fallback font was requested. Font: ‘…/…/…/Engine/Content/Slate/Fonts/DroidSansFallback.ttf’, Character: ‘㡨 (U+3868)’
LogSlate: Took 0.016243 seconds to synchronously load lazily loaded font ‘…/…/…/Engine/Content/SlateDebug/Fonts/LastResort.ttf’ (5269K)
UATHelper: Packaging (Windows): Total script module initialization time: 0.09 s.
UATHelper: Packaging (Windows): Executing commands…
UATHelper: Packaging (Windows): Installed Sdk validity:
UATHelper: Packaging (Windows): Win64: (Status=Valid, MinAllowed_Sdk=10.0.00000.0, MaxAllowed_Sdk=10.9.99999.0, Current_Sdk=10.0.22621.0, Allowed_AutoSdk=10.0.18362.0, Current_AutoSdk=, Flags=“InstalledSdk_ValidVersionExists”)
UATHelper: Packaging (Windows): Scanning for envvar changes…
UATHelper: Packaging (Windows): … done!
UATHelper: Packaging (Windows): Cleaning Temp Paths…
UATHelper: Packaging (Windows): BUILD SUCCESSFUL
UATHelper: Packaging (Windows): Setting up ProjectParams for E:\loads\LumaAIStarterProject_5.3_2023_10_26\LumaAIStarterProject.uproject
UATHelper: Packaging (Windows): ********** BUILD COMMAND STARTED **********
UATHelper: Packaging (Windows): Running: E:\epic\UE_5.3\Engine\Binaries\ThirdParty\DotNet\6.0.302\windows\dotnet.exe “E:\epic\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll” LumaAIStarterProject Win64 Shipping -Project=E:\loads\LumaAIStarterProject_5.3_2023_10_26\LumaAIStarterProject.uproject -Manifest=E:\loads\LumaAIStarterProject_5.3_2023_10_26\Intermediate\Build\Manifest.xml -remoteini=“E:\loads\LumaAIStarterProject_5.3_2023_10_26” -skipdeploy -log=“C:\Users\убийцаа\AppData\Roaming\Unreal Engine\AutomationTool\Logs\E+epic+UE_5.3\UBT-LumaAIStarterProject-Win64-Shipping.
txt”
UATHelper: Packaging (Windows): Log file: C:\Users\㡨�栠\AppData\Roaming\Unreal Engine\AutomationTool\Logs\E+epic+UE_5.3\UBT-LumaAIStarterProject-Win64-Shipping.txt
UATHelper: Packaging (Windows): Creating makefile for LumaAIStarterProject (no existing makefile)
UATHelper: Packaging (Windows): No Visual C++ installation was found. Please download and install Visual Studio 2022 or 2019 with C++ components.
UATHelper: Packaging (Windows): Total execution time: 0.55 seconds
UATHelper: Packaging (Windows): Visual Studio 2022 x64 must be installed in order to build this target.
UATHelper: Packaging (Windows): Took 0,67s to run dotnet.exe, ExitCode=6
UATHelper: Packaging (Windows): UnrealBuildTool failed. See log for more details. (C:\Users\убийцаа\AppData\Roaming\Unreal Engine\AutomationTool\Logs\E+epic+UE_5.3\UBT-LumaAIStarterProject-Win64-Shipping.txt)
UATHelper: Packaging (Windows): AutomationTool executed for 0h 0m 2s
UATHelper: Packaging (Windows): AutomationTool exiting with ExitCode=6 (6)
UATHelper: Packaging (Windows): BUILD FAILED
PackagingResults: Error: Unknown Error
The log says:
So, either you don’t have VS 2022 installed - or it can’t find it. You can download and install it for free.
Thanks a lot , success , everything works fine
