I’m in early stages of creating a survival gps game and im trying to create tons of zombies on map that chase the user.
Im using SampledPositionProperty which gets updated every 1 second.
Because everything changes in real-time and i dont know where entity will be next second, thus i decided to use forwardExtrapolationType = Cesium.ExtrapolationType.HOLD;
Now problem arises with large number of entities - FPS goes down the drain.
Performance in mind, what could be other alternatives to update entities position ?
Some code:
function zombieCreate(lon,lat,height){
var position = Cesium.Cartesian3.fromDegrees(lon, lat, height);
var zombiePositions = new Cesium.SampledPositionProperty();
zombiePositions.forwardExtrapolationType = Cesium.ExtrapolationType.HOLD;
zombiePositions.addSample( Cesium.JulianDate.fromDate(new Date()), position);
var walker = viewer.entities.add({
name : 'Green circle at height with outline',
position : zombiePositions,
ellipse : {
semiMinorAxis : 5.0,
semiMajorAxis : 5.0,
outlineWidth : 0,
material : new Cesium.ImageMaterialProperty({
image : 'SampleData/pin4.png',
transparent: true
granularity : 0.0523598776,
numberOfVerticalLines :2,
height : 1
return walker;
function zombieMove(walker){
for (i in walker){
var dist = 15;
var positionSamples = walker[i].position;
var carto = Cesium.Ellipsoid.WGS84.cartesianToCartographic(walker[i].position.getValue(Cesium.JulianDate.fromDate(new Date())));
var zombieLon = Cesium.Math.toDegrees(carto.longitude);
var zombieLat = Cesium.Math.toDegrees(carto.latitude);
//GET DIRECTION WHERE Z MOVES TO V
var zombieBearing = geolib.getBearing(
{latitude: zombieLat, longitude: zombieLon},
{latitude: usrLat, longitude: usrLon}
var initialPoint = {lat: zombieLat, lon: zombieLon}
var newPositon = (geolib.computeDestinationPoint(initialPoint, dist, zombieBearing));
//ADD NEW SAMPLES
var time = Cesium.JulianDate.addSeconds( Cesium.JulianDate.fromDate(new Date()), 1, Cesium.JulianDate.fromDate(new Date()));
var position = Cesium.Cartesian3.fromDegrees(newPositon.longitude, newPositon.latitude, 1);
positionSamples.addSample(time, position);
walker[i].position = positionSamples;
walker[i].ellipse.stRotation = Cesium.Math.toRadians(zombieBearing);
//Gets update from navigator.geolocation
var usrLat;
var usrLon;
var zombies = ;
//GENERATE RANDOM ZOMBIES
for(var i=0;i<250;i++){
if(Math.random()){
zombies.push(zombieCreate(usrLon+(((Math.random() * 0.009) + 0.001)),usrLat+(((Math.random() * 0.009) + 0.001)), 1));
}else{
zombies.push(zombieCreate(usrLon+(((Math.random() * 0.009) - 0.001)),usrLat+(((Math.random() * 0.009) + 0.001)), 1));
//LOOP
setInterval(function (){ zombieMove(zombies); },1000);
