Hi! I’m working on the development of a number of functions that should allow users to put 3D figures on the map by clicking and moving the mouse. The standard technology for that is the usage of “Cesium.CallbackProperty” that works well in most cases and I cannot understand why “polylineVolume” doesn’t follow the rule.
The code consists of three parts: firstly a global object is defined to enable common acceess to the parameters of the figure, secondly a polyline figure with call backs is declared, and lastly input actions are described to define mouse event instructions.
Right after the launch of the code the polyline appears as expected, but when I try to change its positon and size with mouse, the polyline object disappears and never shows up again.
Thank you in advance,
Oleg
//------------------------------- START VIEWER ---------------------------------
infoBox: true,
baseLayerPicker: false,
navigationHelpButton: false,
geocoder: true,
animation: false,
timeline: false,
homeButton: false,
vrButton: true,
scene3DOnly : true,
shadows: true,
terrainShadows : Cesium.ShadowMode.ENABLED
//---------------------------- SET UP ENVIRONMENT ------------------------------
var terrainProvider = new Cesium.CesiumTerrainProvider({
url : ‘https://assets.agi.com/stk-terrain/world’,
requestVertexNormals: true,
requestWaterMask: true
var scene = viewer.scene;
var globe = scene.globe;
var skyAtmosphere = scene.skyAtmosphere;
viewer.terrainProvider = terrainProvider;
globe.enableLighting = true;
globe.depthTestAgainstTerrain = true;
skyAtmosphere.brightnessShift = 1.0;
skyAtmosphere.saturationShift = 0.33;
viewer.camera.flyTo({destination: Cesium.Cartesian3.fromDegrees(15.15, 25, 3000)});
//-------------------------------- Parameters ----------------------------------
var tubeParameters = {tubeEnds: [15, 25, 530, 15.3, 25, 530], r: 100};
//--------------------------------- Polyline -----------------------------------
function computeCircle(radius) {
var positions = ;
for (var i = 0; i < 360; i = i + 5) {
var radians = Cesium.Math.toRadians(i);
positions.push(new Cesium.Cartesian2(radius * Math.cos(radians), radius * Math.sin(radians)));
return positions;
var redTube = viewer.entities.add({
polylineVolume : {
positions : new Cesium.CallbackProperty(function() {
return Cesium.Cartesian3.fromDegreesArrayHeights(tubeParameters.tubeEnds);
}, false),
shape : new Cesium.CallbackProperty(function() {
return computeCircle(tubeParameters.r);
}, false),
shape : computeCircle(100),
material : Cesium.Color.RED
//-------------------------------- Input Actions -------------------------------
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.RIGHT_CLICK);
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.MOUSE_MOVE);
var tubeBuilt = true;
var handlerA = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handlerA.setInputAction(
function (click) {
tubeBuilt = !tubeBuilt;
if(!tubeBuilt){
redTube.polylineVolume.shape = computeCircle(0);
var cartesian = scene.pickPosition(click.position);
if (scene.pickPositionSupported && Cesium.defined(cartesian)) {
var cartographic = Cesium.Cartographic.fromCartesian(cartesian);
var longitude = Cesium.Math.toDegrees(cartographic.longitude);
var latitude = Cesium.Math.toDegrees(cartographic.latitude);
var altitude = cartographic.height;
tubeParameters.tubeEnds[0] = longitude;
tubeParameters.tubeEnds[1] = latitude;
tubeParameters.tubeEnds[2] = altitude;
}, Cesium.ScreenSpaceEventType.RIGHT_CLICK
var handlerB = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handlerB.setInputAction(
function (movement) {
if(!tubeBuilt){
var cartesian = scene.pickPosition(movement.endPosition);
tubeParameters.tubeEnds[3] = longitude;
tubeParameters.tubeEnds[4] = latitude;
tubeParameters.tubeEnds[5] = tubeParameters.tubeEnds[2];
var pointA = Cesium.Cartesian3.fromDegrees(tubeParameters.tubeEnds[0], tubeParameters.tubeEnds[1], tubeParameters.tubeEnds[2]);
var pointB = Cesium.Cartesian3.fromDegrees(tubeParameters.tubeEnds[3], tubeParameters.tubeEnds[4], tubeParameters.tubeEnds[5]);
tubeParameters.r = Cesium.Cartesian3.distance(pointA, pointB);
}, Cesium.ScreenSpaceEventType.MOUSE_MOVE
