I created wall geometry with same height and varying altitude but the height is varying. Please find the attached sandcastle screenshot and sample code.Could you please let me know whether it is the expected behavior or not?
Thanks for the reply. As you could see in the sample code I attached the minimum heights array values for both the wall entities are same but there is difference in rendering one of the is showing as vertical bar and other one is like a curve. Could you please explain the behavior?
Your walls have vastly different heights. And I also think there is an error in your data. One of your longitude coordinates for the green wall is 90 instead of -90.
