What is the cause of this problem?
Some computers do not have this problem, and some computers have this problem when Cesium is initialized.
RuntimeError: Program failed to link. Link log: C:\fakepath(134.9-30): error X3004: undeclared identifier 'AtmoshpereColor'
Warning:D3D shader compilation failed with default flags. (vs_3_0)
Retrying with avoid flow control
C:\fakepath(134.9-30): error X3004: undeclared identifier 'webgl_cd16f13802bc8948'
Warning:D3D shader compilation failed with avoid flow control flags. (vs_3_0)
Retrying with prefer flow control
Warning:D3D shader compilation failed with prefer flow control flags. (vs_3_0)
Failed to create D3D shaders.
  version 1.51. window64. Google Chrome
https://photos.google.com/photo/AF1QipO6QW_tpYfdWSJi5Qi8H-LLD95LtKPXWwAIMpiI
It might be that WebGL isn’t supported on those computers, or they have some driver bug. Try running WebGL report on them (http://webglreport.com/) and also make sure to update the browser/graphics drivers.
