When I opened Enable Water Mask, the editor status was good, but there was an issue after packaging. I used the 1.31.2 plugin, but when upgrading to version 2.0, the same problem still occurred. What should I do!
Hi @yangjiahaoTemp,
Sorry that you’re experiencing trouble with the plugin. I’m not sure what could be wrong from a glance. Could you please provide more information?
- What version of Unreal Engine are you using?
- What dataset are you using? Is this Cesium World Terrain, or a different terrain tileset?
- What platform are you packaging for?
- Do you see any logs or errors when the game runs?
- When this happens, does it always happen in the same spot?
I also noticed that you’re using a much older version of the plugin. It would be great if you could upgrade to the latest version, so that we can try to more accurately reproduce your problem. If you’re worried about things breaking, you can make a backup copy of your project to be safe. Thank you!
