When I run this code in the sandcastle, the billboards are not in the same place?
Sandcastle.declare(addBillboard);
var scene = viewer.scene;
var billBoardCollection1 = scene.primitives.add(
new Cesium.BillboardCollection({scene: scene}));
//This billboard is not centered vertically (vertical origin has no effect really)
billBoardCollection1.add({
position : Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883),
image: '../images/facility.gif',
verticalOrigin: Cesium.VerticalOrigin.CENTER,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND
//this original example is centered in vertically
viewer.entities.add({
billboard :{
image : '../images/facility.gif'
HeightReference is required to clamp billboards to ground when using terrain.
Passing a scene to the billboard collection is required for heightReference.
What do I need to do get the billboard's origin vertically centered?
Also I noticed when the billboards are at the edge (far left or right) they appear in different positions relative to each other. The non centered billboard from the collection changes position.
Thanks
