Why would Cesium.Cartesian3.distance() be returning a NaN?
Trying to compute the distance between two Cartesian3 points using Cesium.Cartesian3.distance() but returning NaN
Sandcastle.addToolbarButton(‘Calculate Distance’, function() {
    clickPositions = removeDup(clickPositions); // Removes any duplicate values in the clickPositions array
    // Adds an if loop to check there are only two points in the array
    if (clickPositions.length = 2) {
        var distance = (new Cesium.Cartesian3.fromArray(clickPositions[0]), new Cesium.Cartesian3.fromArray(clickPositions[1]));
        console.log("Distance: " + distance);
        confirm("First point is: " + clickPositions[0] +
            "\nSecond Point is: " + clickPositions[1] +
            "\nDistance: " + distance);
    } else {
        confirm("You have clicked on more than two points");
[<img src="https://lh3.googleusercontent.com/-yMUc6waTxN8/WX9QksUsxBI/AAAAAAAAA4M/sgHGQJgc6Gc5KF40c6GjcapDFy3vC79hACLcBGAs/s320/Screen%2BShot%2B2017-07-31%2Bat%2B16.43.26.png" border="0" width="320" height="132">](https://lh3.googleusercontent.com/-yMUc6waTxN8/WX9QksUsxBI/AAAAAAAAA4M/sgHGQJgc6Gc5KF40c6GjcapDFy3vC79hACLcBGAs/s1600/Screen%2BShot%2B2017-07-31%2Bat%2B16.43.26.png)
Trying to measure the distance between two points, in order to measure the height of a building for example.
Cesium ver: 1.34, OS: MacOS Sierra, Browser: Chrome
Any help would be appreciated.
Chris
Hi Chris,
In the code sample you’ve supplied, you are not actually using the function. Here’s the documentation if needed: https://cesiumjs.org/Cesium/Build/Documentation/Cartesian3.html#.distance
Gabby
