z-order i3dm and VectorData-Polygons
I have added vector data polygons (*.vctr) and i3dm data to the scene. The pixels of i3dm data are overlayed by vector data. But I expect to see the trees as they are, without the red color from vector data.
I tried to change the order of primitives.add, but it does not change the draw order.
Can I configure something to change the z-order?
I found a todo "Future work Polygon z-order": https://github.com/AnalyticalGraphicsInc/cesium/pull/4665 may be it is a known issue?
        terrainProvider: Cesium.createWorldTerrain()
var flstTileset = new Cesium.Cesium3DTileset({
    url: ‘https://raw.githubusercontent.com/vitjok/testfile/master/vectordata/’
flstTileset.style = new Cesium.Cesium3DTileStyle({
    color: ‘rgba(255, 0, 0, 0.3)’
var vctr = viewer.scene.primitives.add(flstTileset);
var treeTileset = new Cesium.Cesium3DTileset({
    url: ‘https://raw.githubusercontent.com/vitjok/testfile/master/i3dm/’
var tree = viewer.scene.primitives.add(treeTileset);
viewer.zoomTo(flstTileset);
I want to see the Polygons on the terrain and the trees over the terrain and over the Polygons.
Cesium 1.46
Windows 10
Chrome 67.0.3396.87
code example in Sandcastle: https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/#c=vZLBSgMxEIZfJexlt1AStfRS1yLoUVBo0cte0mTaRrNJmcymtOK7m+22uFXEmyEQMjP/zDeTRIksGtgCshvmYMvuIJim5s8HW5Grw/XOO5LGAeZD9l45dlwEiMn8hD4aDTg5iRWCJHjxaPW8CykGlavoY3CdDhdTzaUNNDcWAtB54e4Y3R+dxbFcg3bC8jXRJkyEQLnlK0PrZtEEQJXowBFXvhbR0Kt/EwSBlimDqGVIlCKCIo9akhR55Q4cPQIeaGfhd45Z6z6RKG99ajXH1UIWV+PxkF10m48Gp9xth1FRO9NuuDwocMA3aGpDJkLgUuuih/A1GUKAf5yMGela9Lnb+n9w9xA77qTswvfe13P/vbFsmJWHEU875FtTbzxSi15wnpDqjU0fJohFo97Sc6gQWlkpTqJSm8iMvqmyb/+xypiyMoTkWTbWzsweqmxaihR/JrNeauNWjxHQyl0bsr6cPnRGznkp0vWniry3C4m9jJ8
Hi Maximus,
We have added geometry z-ordering in Cesium 1.46, however as you pointed out, it has no made it’s way into vector tiles yet (as they are still experimental). 3D Tiles Issue #69 covers adding it to the specification, I’ll bump that issue with this request.
Gabby
Hi Gabby,
I just noticed, that the sample does not work anymore (in current Version I have to append tileset.json to the url option).
And then (more important) I noticed a post about ClassificationType.TERRAIN https://cesiumjs.org/forum/#!msg/cesium-dev/1ptAh6n82KM/1kEFweikAQAJ (by Dan Bagnell).
This option seams to fix the issue.
Sample code:
    classificationType: Cesium.ClassificationType.TERRAIN,
    url: 'https://raw.githubusercontent.com/vitjok/testfile/master/vectordata/tileset.json'
    color: 'rgba(255, 0, 0, 0.3)'
    url: 'https://raw.githubusercontent.com/vitjok/testfile/master/i3dm/tileset.json'
Maximus
Perfect, thanks for the update! Setting the classification type to terrain will indeed work in this case, good thinking.
