The default tilt in 2.5D view for Cesium v1.22.1 seems to be different than previous versions.
It kinda looks like 2D, except that you have the ability to change the tilt using CTRL.
Is something going wrong, or did the default tilt indeed change?
You can check on http://www.mabouali.com/nonwp2/assets/web/cesium_v1.22.1_dojo_v1.11.2.html
Regards
hannah
June 28, 2016, 2:58pm
2
This is a known issue. We have a pull request open to fix it here: https://github.com/AnalyticalGraphicsInc/cesium/pull/3983
It needs a little bit more cleanup so I’m not sure if it will make it into the 1.23 release in July, but should be fixed by the 1.24 release in August.
Hannah
This was fixed in #4501 , which will be in Cesium 1.30 on February 1.
Patrick
