Hello everyone,
I’ve uploaded a couple of .b3dm files to cesium ion and I’m having problems with the visualization, the files doesn’t seem to be streaming or rendering the 3D model. I have other files from a month back and those ones work fine. All the files have been generated with the same software (DJI Terra).
Do you have some idea of what can be causing this ?
Thank you. Best regards,
Franco
I apologize that you are seeing this error. Can you please provide me with the asset id of the asset that you are seeing this incorrect behavior for?
Ankit
The source file here seems to be a capture asset and not .b3dms. The job in this instance failed due to a known limitation on our current generation pipeline to handle assets like these. We are in the process of developing a new tiling pipeline which should would help fix these types of issues. I have added this thread to an internal tracking issue and will update you once the new pipeline is out.
Ankit
Hi Ankit,
Is this limitation new ? Cause the old files that I’ve uploaded before are also from a drone capture.
Thanks. Regards,
Franco
I apologize for the confusion here. I mixed up the asset id you had provided and was looking at the wrong asset. Looking at the asset id 2222702 it is loading a tileset. Would you be able to provide the error that you are seeing? And also what you are expecting the asset to look like?
Ankit
