加载房屋json文件3dtile过程百分百报错并出现unity编辑器崩溃,但这个问题在虚幻ue中尚未出现仅仅只有报错
格式是B3DM
unity版本是2021.3.45f1 cesiumforunity版本1.14.0
Can you provide a link to the tileset that failed to load so that we can test it out on our end to see what might be wrong? You can send it via private message if you can’t share it publicly.
我的b3dm文件本身有部分数据错误遗漏,可能是导致崩溃的一部分原因,如果是的最好能忽略掉错误数据部分解析
Hi @dwbcxy886,
It seems likely this is caused by a bad b3dm file, though we shouldn’t be crashing in any case. It’s hard to identify the root cause based on your screenshots, though. If you could provide a b3dm that triggers the same problem, that would be very helpful. If you could extract the glTF from the b3dm and then run the glTF Validator on it, that would be very helpful, too.
