Hi! Here is a visual problem:
I wrote a customShader and I applied it to my custom primitive to perform raymaching process.
void main()
vec3 rayDir = normalize( vDirection );
vec2 bounds = hitBox( vOrigin, rayDir );if ( bounds.x > bounds.y ) discard; bounds.x = max( bounds.x, 0.0 ); vec3 p = vOrigin + bounds.x * rayDir; p = vec3(p.x / dim.x, p.y / dim.y, p.z / dim.z); vec3 inc = 1.0 * dim / abs(rayDir ); float delta = min(min( inc.x, min(inc.y, inc.z)), 50000.0); //keep delta small enough delta /= 400.0; // Nice little seed from // https://blog.demofox.org/2020/05/25/casual-shadertoy-path-tracing-1-basic-camera-diffuse-emissive/ uint seed = uint( gl_FragCoord.x ) * uint( 1973 ) + uint( gl_FragCoord.y ) * uint( 9277 ); vec3 size = vec3( textureSize( map, 0 ) ); float randNum = randomFloat( seed ) * 2.0 - 1.0; p += rayDir * ( 0.1 / size ); // vec3 result = rayDir * delta; vec4 ac = vec4(0.0); vec3 color; float opacity; float d; float col; for ( float t = bounds.x; t < bounds.y; t += delta ) { d = round(getValue( p + 0.5 ) * 70.0); col = shading( p + 0.5, delta ) * 0.3 + 1.0; opacity = (d - threshold) / (70.0 - threshold); opacity = opacity * opacity * opacity * 1.2; if(d > 10. && d > threshold){ if( d < 15.){ color = vec3(1, 160, 246); } else if(d < 20.){ color = vec3(0, 236, 236); } else if(d < 25.){ color = vec3(0, 216, 0); } else if(d < 30.){ color = vec3(1, 144, 0); } else if(d < 35.){ color = vec3(255, 255, 0); } else if(d < 40.){ color = vec3(231, 192, 0); } else if(d < 45.){ color = vec3(255, 144, 0); } else if(d < 50.){ color = vec3(255, 0, 0); } else if(d < 55.){ color = vec3(214, 0, 0); } else if(d < 60.){ color = vec3(192, 0, 0); } else if(d < 65.){ color = vec3(255, 0, 240); } else if(d < 70.){ color = vec3(150, 0, 180); } else if(d >= 70.){ color = vec3(173, 144, 240); } color /= 255.; if (!isActive) ac += (1.0 - ac.a) * vec4(color * opacity * col, opacity); } if(isActive) { if((p.x > lon - 0.0005 && p.x < lon + 0.0005) || (p.y > lat - 0.0005 && p.y < lat + 0.0005) || (p.z > alt - 0.01 && p.z < alt + 0.01)) { if(d > 10.0) { ac = vec4(color, 1.0); } else{ ac = vec4(0.8, 0.8, 0.8, 0.0); } } } if ( ac.a >= 0.95 ) break; p += vec3(result.x / dim.x, result.y / dim.y, result.z / dim.z) ;// } fragColor = ac;//"out_FragColor" only in TRANSLUCENT pass, else def: in vec4 fragColor if ( ac.a == 0.0 ) discard;}
However, it shows strange ripple effect which is noticeable when camera ray is perpendicular to Z axis:
I tryied jittering and increaing sampling steps, but it didn’t resolve the problem.
