Currently on initial load of the viewer, the first thing you see is star-filled space. Would like to prevent it from loading the space so that there could be a more seamless transition from a 2D map to a 3D map. Is there anyway to turn it off?
Hi! You can set the background to undefined and set it to the color you like.
An example in Sandcastle here.
Hi, that link doesn’t work, can you post the correct one? Thanks for the help.
