Auto rotation causes problem in VR mode
I want some suggestion related to auto rotation in VR mode. i include terrain provider and when i go into VR mode, after fwe seconds auto rotation changes the view.
plz help me to disable the auto rotation in VR mode.
Thanks in advance.
I don’t know of anything in Cesium that would cause the camera to rotate automatically. It could be a bug, but I wasn’t able to reproduce it. Can you paste a code sample that reproduces the problem?
Hannah
hello hannah,
Thanks for ur reply.
Here is my code check it in VR mode. It causes problem with camera angle. and can u tell me how to disable the axis rotation.
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
    <meta name="description" content="Configure viewer to add a button enabling look at a mobile device with cardboard.">
    <meta name="cesium-sandcastle-labels" content="Beginner, Showcases">
    <title>Cesium Demo</title>
    <script type="text/javascript" src="../Sandcastle-header.js"></script>
    <script type="text/javascript" src="../../../ThirdParty/requirejs-2.1.20/require.js"></script>
    <script type="text/javascript">
        require.config({
                           baseUrl : '../../../Source',
                           waitSeconds : 60
    </script>
</head>
<body class="sandcastle-loading" data-sandcastle-bucket="bucket-requirejs.html">
<style>
    @import url(../templates/bucket.css);
</style>
<div id="cesiumContainer" class="fullSize"></div>
<div id="loadingOverlay"><h1>Loading...</h1></div>
<div id="toolbar"></div>
<script id="cesium_sandcastle_script">
function startup(Cesium) {
    'use strict';
//Sandcastle_Begin
    baseLayerPicker : false,
    homeButton : false,
    navigationHelpButton : false,
      timeline : false,
      animation : false,
      selectionIndiactor : false,
      scene3DOnly : true,
      bottomContainer : false,
    geocoder : false,
    vrButton : true
// Click the VR button in the bottom right of the screen to switch to VR mode.
     var camera = viewer.camera;
        viewer.camera.flyTo({
        destination : Cesium.Cartesian3.fromDegrees(79.06666666, 30.73388888, 50)
  var cesiumTerrainProviderMeshes = new Cesium.CesiumTerrainProvider({
    url : ‘https://assets.agi.com/stk-terrain/world’,
    requestWaterMask : true,
  destination : camera,
    requestVertexNormals : true
viewer.terrainProvider = cesiumTerrainProviderMeshes;
var scene = viewer.scene;
var canvas = viewer.canvas;
canvas.setAttribute('tabindex', '0'); // needed to put focus on the canvas
canvas.onclick = function() {
    canvas.focus();
var ellipsoid = scene.globe.ellipsoid;
  // disable the default event handlers
  scene.screenSpaceCameraController.enableRotate = false;
  scene.screenSpaceCameraController.enableTranslate = false;
  scene.screenSpaceCameraController.enableZoom = false;
  scene.screenSpaceCameraController.enableTilt = false;
  scene.screenSpaceCameraController.enableLook = false;
  scene.screenSpaceCameraController.inertiaSpin = 0.0;
  scene.screenSpaceCameraController.inertiaTranslate = 0.0;
var startMousePosition;
var mousePosition;
var flags = {
    looking : false,
    moveForward : false,
    moveBackward : false,
    moveUp : false,
    moveDown : false,
    moveLeft : false,
    moveRight : false
var handler = new Cesium.ScreenSpaceEventHandler(canvas);
handler.setInputAction(function(movement) {
    flags.looking = true;
    mousePosition = startMousePosition = Cesium.Cartesian3.clone(movement.position);
}, Cesium.ScreenSpaceEventType.LEFT_DOWN);
    mousePosition = movement.endPosition;
handler.setInputAction(function(position) {
    flags.looking = false;
}, Cesium.ScreenSpaceEventType.LEFT_UP);
function getFlagForKeyCode(keyCode) {
    switch (keyCode) {
        case 38:
        return 'moveForward';
    case 40:
        return 'moveBackward';
    case 33:
        return 'moveUp';
    case 34:
        return 'moveDown';
    case 39:
        return 'moveRight';
    case 37:
        return 'moveLeft';
    default:
        return undefined;
function onKey(e){
if(e.keyCode == 227){
  return 'moveForward'}
document.addEventListener('keydown', function(e) {
    var flagName = getFlagForKeyCode(e.keyCode);
    if (typeof flagName !== 'undefined') {
        flags[flagName] = true;
}, false);
document.addEventListener('keyup', function(e) {
        flags[flagName] = false;
}, false);
viewer.clock.onTick.addEventListener(function(clock) {
    if (flags.looking) {
        var width = canvas.clientWidth;
        var height = canvas.clientHeight;
        // Coordinate (0.0, 0.0) will be where the mouse was clicked.
        var x = (mousePosition.x - startMousePosition.x) / width;
        var y = -(mousePosition.y - startMousePosition.y) / height;
        var lookFactor = 0.05;
        camera.lookRight(x * lookFactor);
        camera.lookUp(y * lookFactor);
    // Change movement speed based on the distance of the camera to the surface of the ellipsoid.
    var cameraHeight = ellipsoid.cartesianToCartographic(camera.position).height;
    var moveRate = cameraHeight / 100.0;
    if (flags.moveForward) {
        camera.moveForward(moveRate);
    if (flags.moveBackward) {
        camera.moveBackward(moveRate);
    if (flags.moveUp) {
        camera.moveUp(moveRate);
    if (flags.moveDown) {
        camera.moveDown(moveRate);
    if (flags.moveLeft) {
        camera.moveLeft(moveRate);
    if (flags.moveRight) {
        camera.moveRight(moveRate);
window.addEventListener('keydown', onkey, true);
//Sandcastle_End
    Sandcastle.finishedLoading();
if (typeof Cesium !== "undefined") {
    startup(Cesium);
} else if (typeof require === "function") {
    require(["Cesium"], startup);
</script>
</body>
</html>
hi hannah
i asked this question earlier.
can u help me with this issue?
Thanks!!
Sorry I missed your question before.
I don’t understand what you’re trying to do with the clock ontick event. I’m guessing that is why your camera is moving.
-Hannah
